I have an explicit time evolution scheme that I would like to iterate by applying a bilinear form to a solution vector (repeatedly). From the elasticity tutorial it appears that one may assemble a PETSc matrix A from a bilinear form a. In that tutorial a PETSc vector b is also created from a linear form L, to which A could then be applied (although in that tutorial they solve the system). Additionally, in the Cahn-Hilliard demo, they directly manipulate the solution vectors via u0.x.array[:] = u.x.array.
I would like to apply a matrix A to a solution vector u0.x.array[:] in order to update the next timestep u. Is this possible to do in Fenics on a distributed system without generating a bunch of copies? Is there some canonical way to do this?
