How to assemble 'matrix' only once with dolfinx 0.7.3?
Hello everyone,
Dolfinx version is 0.7.3 and have been installed with conda.
Other version I need in the minimal code (at the bottom of the post) are :
  • numpy : 1.26.4
  • mpi4py : 3.1.6
  • ufl : 2.23.2.0
  • pyvista : 0.44.2
For the context, I’m solving an acoustic equation with Neumann or Robin boundary condition (but not dirichlet).
I solve it in the laplace domain according to time (like some people do in the harmonic domain).
Consequently, I must solve one problem for each Laplace parameter s.
A weak formulation gives something like :
∀s ,  a(u,v) + s²b(u,v)  = L(v)
which in term of matrix gives :
∀s , (K + s²M).U = L
Then, for each s-value, the problem is solved using an iteratived domain decomposition method.
This implie to assemble the FE “matrix” too many times.
Consequently, i would like to “save/compute once” the Finite Element objects.
For one s-value (for one frequency), i have tried to follow the Solving a time-dependent problem — FEniCS 22 tutorial tutorial.
Q1) Problem of version to assemble the second member
Due to the version difference,
# Create the problem  A_form ~ (K+s²M)
problem = LinearProblem(A_form, L_form, bcs = [ ])
# Solve the problem
uh = problem.solve()
# Create a function
func = fem.Function(V)
I can’t use the ‘.x.petsc_vec’ method for a solution of a problem (uh) or on a function (func).
I can assemble the bilinear form once as in the tutorial
  • How can I code something like in the tutorial for the second member ?
I do not plan to change version now since we are in code validation step.
Q2) My actual best choice to optimize my code
If i define the dolfinx form like :
# Bilinear form
a_form = inner(nabla_grad(u),nabla_grad(v))*dx
b_form = inner(u,v)*dx
# Linear form
L_form = inner(f,v)*dx
# Or just  general A_form of the problem
A_form = inner(nabla_grad(u),nabla_grad(v))*dx + s**2 * inner(u,v)*dx
To optimize my code, I would like to :
  1. Assemble the two form once and for all cause these two objects do not depend on the frequency/s-value and i dont have dirichlet bc.
  • af = assemble(form(a_form)),
  • bf = assemble(form(b_form))
  1. Sum them at each frequency/s-value such that :
    af + s²bf
  • Is it possible to do something like that ?
Here is the minimal code I’m using to achieve my goal :
## Library
from dolfinx import fem, la, mesh, plot
import pyvista as pv
## Parameters
s = 3       # Laplace parameter
## Domain parameter
length, height = 10, 3
Nx, Ny = 80, 60
extent = [[0.0, 0.0], [length, height]]
domain = mesh.create_rectangle(MPI.COMM_WORLD, extent, [Nx, Ny], mesh.CellType.quadrilateral)
## Finite Element Space/functions
V = fem.FunctionSpace(domain,("P",2,(3,)))
u = ufl.TrialFunction(V)
## Define a manufactured solution
def Solution(x):
    X = np.zeros_like(x)
    X[0] = x[0]
    X[1] = np.cos(x[0]+x[2]**2)
    X[2] = 0.0
    return X
sol = fem.Function(V)
sol.interpolate(Solution)
## Solve the problem directly
# Linear form L(v)
L_form = (ufl.inner(ufl.nabla_grad(sol),ufl.nabla_grad(v)) + s**2 *ufl.inner(sol,v))* ufl.dx
# Bilinear form A(u,v)
A_form = (ufl.inner(ufl.nabla_grad(u),ufl.nabla_grad(v)) + s**2 * ufl.inner(u,v))* ufl.dx
# Solve the problem
## Avoid multiple assembly
    ## Assemble the bilinear form
compiled_a = fem.form(A_form)
A = fem.petsc.assemble_matrix(compiled_a,bcs=[])
    ## Assemble RHS : the linear form
compiled_L = fem.form(L_form)
L = fem.petsc.assemble_vector(compiled_L)
Thanks in advance.
I guess you are close. You already know how to use fem.petsc.assemble_matrix to assemble a matrix. Now you just need to call it twice, once on the form with af and another time on the form with bf. The resulting type is petsc4py.PETSc.Mat, and you can look into their documentation on how to sum them (the method will usually be called axpy). Finally, call the petsc4py.PETSc.KSP solver yourself rather than using LinearProblem (there are several demos in dolfinx that use that, search for KSP in the demos of your version)
Dear francesco-ballarin,
Thank you for your fast reply.
My phd supervisor recently started use FEniCSx (version 9.3) and has followed the time-dependant tutorial to save / assemble matrix once.
As a conclusion, saving Finite Element matrix may save 0.1-0.2 sec in my case which is not worth it.
Thanks again.
