Can't run FEniCS after updating Docker
Hi
I updated Docker desktop and currently have version 2.1.0.0. The problem I face is when I try to run FEnicS
Terminal> fenicsproject run
No active host found
What happens if you run:
docker -ti —rm -v $(pwd):/home/fenics/shared quay.io/fenicsproject/stable
Is there a solution to this ? I have this problem on mac osx when using fenicsproject script.
And I get an error directly running docker
$ docker -ti —rm -v $(pwd):/home/fenics/shared quay.io/fenicsproject/stable
unknown shorthand flag: 't' in -ti
It seems there is a mistake in that command, run is missing.
You can try again with : docker run -ti --rm -v $(pwd):/home/fenics/shared quay.io/fenicsproject/stable
Thank you , it works.
Then there is something wrong with the fenicsproject script.
This problem continues for me. The fenicsproject script does not work, “No active host found”. I reinstalled docker but did not help. Has anybody found a solution. I am on mac.
I had the same issue and I am on Mac, too. For me it helped going back to an older version of Docker. I am now using
Docker Community Edition 18.03.1-ce-mac65 2018-04-30
which you can download at
I suspect that the fenicsproject script does not correctly detect the Docker Desktop installation. Changing line 40 of /usr/local/bin/fenicsproject by changing ‘Docker for Mac’ to ‘Docker Desktop’ solved the problem for me.
How exactly do you do this?
The fenicsproject script is out of date and the users are encouraged to use the docker syntax directly, as explained in section 2 of 2. Introduction — FEniCS Containers 1.0 documentation
