I’m installing dolfinx using spack and I am running into errors compiling openblas. I’m unclear how the skylake option gets inserted. The following is the part of the error message.
==> No binary for openblas-0.3.19-rdwlta3ahtrlz4r52eqs6ukx7zog46eh found: installing from source
==> Using cached archive: /storage/coda1/p-tf74/0/emolel3/spack/var/spack/cache/_source-cache/archive/94/947f51bfe50c2a0749304fbe373e00e7637600b0a47b78a51382aeb30ca08562.tar.gz
==> No patches needed for openblas
==> openblas: Executing phase: 'edit'
==> openblas: Executing phase: 'build'
==> Error: ProcessError: Command exited with status 2:
'make' '-j16' 'CC=/storage/coda1/p-tf74/0/emolel3/spack/lib/spack/env/intel/icc' 'FC=/storage/coda1/p-tf74/0/emolel3/spack/lib/spack/env/intel/ifort' 'MAKE_NB_JOBS=0' 'ARCH=x86_64' 'TARGET=SKYLAKEX' 'USE_LOCKING=1' 'USE_OPENMP=0' 'USE_THREAD=0' 'RANLIB=ranlib' 'libs' 'netlib' 'shared'
5 errors found in build log:
2878 /storage/coda1/p-tf74/0/emolel3/spack/lib/spack/env/intel/icc -c -O2 -DSMALL_MATRIX_OPT -DMAX_STACK_ALLOC=2048 -DUSE_LOCKING -wd981 -DF_INTERFACE_INTEL -fPIC -DNO_WARMUP -DMAX_CPU_NUMBER=24
-DMAX_PARALLEL_NUMBER=1 -DBUILD_SINGLE=1 -DBUILD_DOUBLE=1 -DBUILD_COMPLEX=1 -DBUILD_COMPLEX16=1 -DVERSION=\"0.3.19\" -msse3 -mssse3 -msse4.1 -mavx -mavx2 -march=skylake-avx512 -UASMNAME -U
ASMFNAME -UNAME -UCNAME -UCHAR_NAME -UCHAR_CNAME -DASMNAME=csrot_k -DASMFNAME=csrot_k_ -DNAME=csrot_k_ -DCNAME=csrot_k -DCHAR_NAME=\"csrot_k_\" -DCHAR_CNAME=\"csrot_k\" -DNO_AFFINITY -I.. -
UDOUBLE -DCOMPLEX -DCOMPLEX -DCOMPLEX -UDOUBLE ../kernel/x86_64/zrot_sse.S -o csrot_k.o
2879 icc: command line warning #10121: overriding '-march=cascadelake' with '-march=skylake-avx512'
2880 /storage/coda1/p-tf74/0/emolel3/spack/lib/spack/env/intel/icc -c -O2 -DSMALL_MATRIX_OPT -DMAX_STACK_ALLOC=2048 -DUSE_LOCKING -wd981 -DF_INTERFACE_INTEL -fPIC -DNO_WARMUP -DMAX_CPU_NUMBER=24
ASMFNAME -UNAME -UCNAME -UCHAR_NAME -UCHAR_CNAME -DASMNAME=cscal_k -DASMFNAME=cscal_k_ -DNAME=cscal_k_ -DCNAME=cscal_k -DCHAR_NAME=\"cscal_k_\" -DCHAR_CNAME=\"cscal_k\" -DNO_AFFINITY -I.. -
UDOUBLE -DCOMPLEX -DCOMPLEX -UDOUBLE ../kernel/x86_64/../arm/zscal.c -o cscal_k.o
2881 icc: command line warning #10121: overriding '-march=cascadelake' with '-march=skylake-avx512'
2882 icc: command line warning #10121: overriding '-march=cascadelake' with '-march=skylake-avx512'
2883 icc: command line warning #10121: overriding '-march=cascadelake' with '-march=skylake-avx512
