Hi all,
What is the equivalent code if Q is a MixedSpace and I wish to assign the values (like below) only to a function defined on Q.sub(1) subspace.
Code taken from here .
Q = FunctionSpace(mesh, ("DG", 0))
kappa = Function(Q)
bottom_cells = ct.find(bottom_marker)
kappa.x.array[bottom_cells] = np.full_like(bottom_cells, 1, dtype=ScalarType)
top_cells = ct.find(top_marker)
kappa.x.array[top_cells] = np.full_like(top_cells, 0.1, dtype=ScalarType)
Thanks for your time.
Hi @dokken ,
Perhaps, I should have been more clear with my query. What I need is to be able to assign values to a function using a cell tag like “ct.find(12)”, where the integer 12 is an identifier/marker of a region in the mesh prepared using GMSH’s physical surface utility.
As of now this gives results in an error:
kappa = fem.Function(V=MixedSpace)
W, Wmap = MixedSpace.sub(1).collapse()
bottom_cells = ct.find(14)
kappa.x.array[Wmap] = np.full_like(bottom_cells, 1, dtype=PETSc.ScalarType)
top_cells = ct.find(13)
kappa.x.array[Wmap] = np.full_like(top_cells, 0.1, dtype=PETSc.ScalarType)
dokken
March 7, 2023, 8:46am
4
Please provide a reproducible code, so that I can see the actual error message and the cause of it.
dokken
March 7, 2023, 10:08am
5
You are missing a step here, as you need to actually assign the data (ie. 1 and 0.1) to a function in W, and then assign that array to kappa.
If you dont want to do that, you need to use the correct subset of Wmap, i.e. Wmap[bottom_cells] and Wmap[top_cells] in your assignment.
Hi @dokken ,
The mesh file is located here in zenodo.
And here is my attempt:
from ufl import (MixedElement)
from dolfinx import (fem, io)
from dolfinx.io.gmshio import read_from_msh
External mesh loading
domain, ct, ft = read_from_msh(
filename="mesh.msh",
comm=MPI.COMM_WORLD,
rank=0, gdim=2
gdim = domain.topology.dim
fdim = gdim - 1
n = ufl.FacetNormal(
domain=domain
surf_upside = 14
surf_dnside = 13
line_noslip = 12
Spaces and Functions
degree = 2
DG_elem = ufl.VectorElement(
family="Discontinuous Lagrange",
cell=domain.ufl_cell(),
degree=degree
CG_elem = ufl.FiniteElement(
family="Lagrange",
degree=degree - 1
MixedSpace = fem.FunctionSpace(
mesh=domain,
element=MixedElement([DG_elem, CG_elem])
v, q = ufl.TestFunctions(
function_space=MixedSpace
state = fem.Function(
V=MixedSpace,
name="Current state"
Load and assign the initial condition
# def init_h(x):
# down_idx = x[1] > 0.4
# values = np.full((x.shape[1],), 0.3)
# values[down_idx] = 0.01
# return values
# state.sub(1).interpolate(lambda x: init_h(x))
space1, map1 = state.sub(1).collapse()
bottom_cells = ct.find(13)
space1[map1[bottom_cells]] = np.full_like(map1[bottom_cells], 1, dtype=PETSc.ScalarType)
top_cells = ct.find(14)
space1[map1[top_cells]] = np.full_like(map1[top_cells], 0.1, dtype=PETSc.ScalarType)
with io.XDMFFile(comm=MPI.COMM_WORLD,
filename="state.xdmf",
file_mode="w",
encoding=io.XDMFFile.Encoding.HDF5) as xdmf:
xdmf.write_mesh(mesh=domain)
xdmf.write_function(u=state.sub(1).collapse())
In order to assign an initial condition to a variable that lies in the second subspace of the mixed space, I have specified two physical surfaces in GMSH. Orange part denotes cells with tag 13. Green part denotes cells with tag 14. Therefore, in the code, I wish to load the mesh, identify the regions with cell tags and assign different values to them. I wish to achieve the result like the commented code (when uncommented) but with cell tags and not with geometrical condition.
Thank you for your patience!
dokken
March 8, 2023, 2:51pm
7
This link does not work.
Also, you are saying that you want to set this to the second space in the mixed space, but that is a CG-1 function, not a DG-0 function as the original question related to.
Here is a MWE that produces what you want.
Make sure you spend some time considering the differences between your code and this one:
from dolfinx import (fem, io, mesh)
domain = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
one_side = mesh.locate_entities(
domain, domain.topology.dim, lambda x: np.logical_and(x[0] < 0.5, x[1] < 0.75))
all_cells_on_procs = domain.topology.index_map(
domain.topology.dim).size_local + domain.topology.index_map(domain.topology.dim).num_ghosts
cells = np.arange(all_cells_on_procs, dtype=np.int32)
surf_upside = 14
surf_dnside = 13
markers = np.full_like(cells, surf_upside, dtype=PETSc.ScalarType)
markers[one_side] = surf_dnside
ct = mesh.meshtags(domain, domain.topology.dim, cells, markers)
degree = 2
degree=degree
marker_el = ufl.FiniteElement(
cell=domain.ufl_cell(), degree=0)
mesh=domain,
element=ufl.MixedElement([DG_elem, marker_el])
state = fem.Function(MixedSpace, name="Current_state")
space1, map1 = MixedSpace.sub(1).collapse()
map1 = np.asarray(map1, dtype=np.int32)
bottom_cells = ct.find(surf_dnside)
state.x.array[map1[bottom_cells]] = np.full_like(
map1[bottom_cells], 1., dtype=PETSc.ScalarType)
top_cells = ct.find(surf_upside)
state.x.array[map1[top_cells]] = np.full_like(
file_mode="w",
Dear @dokken ,
Your help is invaluable.
The code solved my problem.
Sorry, the page had not been published previously. The mesh can be found here now.
Thanks again!
I think I understand the difference but for degree=2 and “Lagrange” for the second space, why does the code give error. For higher degrees it works. Am I missing something!
surf_upside = 14
surf_dnside = 13
degree = 2
degree=degree
family="Lagrange",
degree=degree-1
mesh=domain,
element=ufl.MixedElement([DG_elem, CG_elem])
file_mode="w",
dokken
March 8, 2023, 3:52pm
10
You are trying to assign data based on the cell indices.
Then you need a function-space that is one-to-one with the cell indices. Only DG-0 is this, as it is a constant per element. Using any other function space to get data that is defined as a constant per cell does not make sense.
You are right!
I need to be careful while assigning the values with this method.
