Hey there,
I stumbled about the following problem last week and couldn’t resolve it on my own. I am working in a DG setting and want to interpolate a given function to a finer mesh. For that I am using a nonmatching interpolation, which works fine as long as the solution is continuous.
However, I found some behavior I could not explain, when I was trying to interpolate discontinuous functions. I then tried a cell-wise approach and the behavior looked even stranger. In the following MWE I tried to boil this down into a 1D case (later I’m more interested in a 2D version of that).
import dolfinx as dfx
mesh_coarse = dfx.mesh.create_interval(MPI.COMM_WORLD, 4, (0, 1.0))
mesh_fine = dfx.mesh.create_interval(MPI.COMM_WORLD, 12, (0, 1.0))
fem_type = "DG"
V_h = dfx.fem.FunctionSpace(mesh_coarse, (fem_type, 1))
V_ref = dfx.fem.FunctionSpace(mesh_fine, (fem_type, 1))
u_h = dfx.fem.Function(V_h)
u_h.x.array[:] = np.arange(len(u_h.x.array)) # a coarse function with some jumps
V_h_x = np.array([coord[0] for coord in V_h.tabulate_dof_coordinates()])
V_ref_x = np.array([coord[0] for coord in V_ref.tabulate_dof_coordinates()])
u_h_int = dfx.fem.Function(V_ref)
u_h_glob_int = dfx.fem.Function(V_ref)
interpolation_data = dfx.fem.create_nonmatching_meshes_interpolation_data(
V_ref.mesh._cpp_object, V_ref.element, V_h.mesh._cpp_object, padding=1e-9
u_h_glob_int.interpolate(u_h, nmm_interpolation_data=interpolation_data)
c_map = V_ref.mesh.topology.index_map(V_ref.mesh.topology.dim)
num_cells = c_map.size_local + c_map.num_ghosts
for cell in range(num_cells):
u_h_int.interpolate(
u_h,
nmm_interpolation_data=interpolation_data,
cells=np.array([cell]).astype(np.int32),
plt.plot(V_h_x, u_h.x.array, marker="x", label="uh")
plt.plot(V_ref_x, u_h_int.x.array, marker="x", label="uh cellwise interpolated")
plt.plot(V_ref_x, u_h_glob_int.x.array, marker="x", label="uh interpolated")
plt.legend()
The code generates the following plot:
I somehow want the green line to capture the jumps of the blue line, which is indeed possible in this setting (the fine mesh is a refinement of the coarse one). Note, that I plotted over coords[0], so the green line has the same amount of points as the orange one (my try on a cell-wise interpolation). As you see, the cell-wise approach didn’t work at all, and I’m not completely sure why. I also tried doing the interpolation a seperate Function instance and adding the relevant data to u_h_int, but the result was basically the same.
My two main questions are:
- Is it possible to calculate a cell-wise interpolation in a DG context?
- How can I capture jumps, when interpolating bewteen meshes?
Thanks a lot in advance ![]()
