Hey there,
I just shifted from dolfinx 0.6.0 to the new version 0.7.1 and found some behavior I could not explain myself. In version 0.6.0 I could interpolate between meshes (as in the following MWE)
import dolfinx as dfx
print("dolfinx version:", dfx.__version__)
mesh1 = dfx.mesh.create_unit_interval(MPI.COMM_SELF, 10)
V1 = dfx.fem.FunctionSpace(mesh1, ("CG", 1))
mesh2 = dfx.mesh.create_interval(MPI.COMM_WORLD, 5, (0.0, 0.5))
V2 = dfx.fem.FunctionSpace(mesh2, ("CG", 1))
func1 = dfx.fem.Function(V1)
func1.x.array[:] = np.arange(len(V1.tabulate_dof_coordinates()))
print("func1.x.array", func1.x.array)
func2 = dfx.fem.Function(V2)
func2.interpolate(func1)
print("func2.x.array", func2.x.array)
and get
dolfinx version: 0.6.0
func1.x.array [ 0. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10.]
func2.x.array [0. 1. 2. 3. 4. 5.]
Now, in the new version, running the same code as above, I get
dolfinx version: 0.7.1
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
Did something change in the interpolation interface from 0.6 to 0.7? I tried looking up the “User facing changes” of v0.7.0 and found #2414, but I’m not sure what I can do to get my code running again. Specifically, I used the installation via conda for both versions.
Thanks a lot ![]()
