I met this problem when using dolfinx to solve the example navier-stokes cylinder code in singularity image.Here are the full info:
Info : Meshing 1D...
Info : [ 0%] Meshing curve 1 (Line)
Info : [ 20%] Meshing curve 2 (Line)
Info : [ 40%] Meshing curve 3 (Line)
Info : [ 60%] Meshing curve 4 (Line)
Info : [ 80%] Meshing curve 5 (Ellipse)
Info : Done meshing 1D (Wall 0.0153243s, CPU 0.015318s)
Info : Meshing 2D...
Info : Meshing surface 1 (Plane, Frontal-Delaunay for Quads)
Info : Simple recombination completed (Wall 0.00701936s, CPU 0.001787s): 103 quads, 16 triangles, 0 invalid quads, 0 quads with Q < 0.1, avg Q = 0.82361, min Q = 0.425555
Info : Simple recombination completed (Wall 0.00738811s, CPU 0.007389s): 460 quads, 0 triangles, 0 invalid quads, 0 quads with Q < 0.1, avg Q = 0.865979, min Q = 0.499255
Info : Done meshing 2D (Wall 0.0314113s, CPU 0.017752s)
Info : Refining mesh...
Info : Meshing order 2 (curvilinear on)...
Info : [ 0%] Meshing curve 1 order 2
Info : [ 20%] Meshing curve 2 order 2
Info : [ 40%] Meshing curve 3 order 2
Info : [ 50%] Meshing curve 4 order 2
Info : [ 70%] Meshing curve 5 order 2
Info : [ 90%] Meshing surface 1 order 2
Info : Done meshing order 2 (Wall 0.00410315s, CPU 0.004102s)
Info : Done refining mesh (Wall 0.00449388s, CPU 0.004493s)
Info : 1952 nodes 2069 elements
Info : Done meshing order 2 (Wall 0.0181345s, CPU 0.018131s)
Info : Optimizing mesh (Netgen)...
Info : Done optimizing mesh (Wall 1.43936e-06s, CPU 4e-06s)
In file included from libffcx_elements_176c32e09ce7bc0aaf86ff2f49da2c5de8ae012e.c:50:
/usr/include/python3.10/pyconfig.h:3:12: fatal error: x86_64-linux-gnu/python3.10/pyconfig.h: No such file or directory
3 | # include <x86_64-linux-gnu/python3.10/pyconfig.h>
compilation terminated.
File "/usr/lib/python3.10/distutils/unixccompiler.py", line 117, in _compile
self.spawn(compiler_so + cc_args + [src, '-o', obj] +
File "/usr/lib/python3.10/distutils/ccompiler.py", line 910, in spawn
spawn(cmd, dry_run=self.dry_run)
File "/usr/lib/python3.10/distutils/spawn.py", line 91, in spawn
raise DistutilsExecError(
distutils.errors.DistutilsExecError: command '/home/wulong/anaconda3/envs/drl/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
File "/usr/local/lib/python3.10/dist-packages/cffi/ffiplatform.py", line 51, in _build
dist.run_command('build_ext')
File "/usr/lib/python3.10/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/usr/lib/python3.10/distutils/command/build_ext.py", line 340, in run
self.build_extensions()
File "/usr/lib/python3.10/distutils/command/build_ext.py", line 449, in build_extensions
self._build_extensions_serial()
File "/usr/lib/python3.10/distutils/command/build_ext.py", line 474, in _build_extensions_serial
self.build_extension(ext)
File "/usr/lib/python3.10/distutils/command/build_ext.py", line 529, in build_extension
objects = self.compiler.compile(sources,
File "/usr/lib/python3.10/distutils/ccompiler.py", line 574, in compile
self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
File "/usr/lib/python3.10/distutils/unixccompiler.py", line 120, in _compile
raise CompileError(msg)
distutils.errors.CompileError: command '/home/wulong/anaconda3/envs/drl/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
What should I do to cope with it.
