dolfinx: 0.8.0
# Define the 3x3 force and rotation matrices
K_fx = np.array([[K_fxfx, K_fxfy, K_fxfz],
[K_fyfx, K_fyfy, K_fyfz],
[K_fzfx, K_fzfy, K_fzfz]])
K_mx = np.array([[K_mxfx, K_mxfy, K_mxfz],
[K_myfx, K_myfy, K_myfz],
[K_mzfx, K_mzfy, K_mzfz]])
# Initialize a 6x6 zero matrix
K_combined = np.zeros((6, 6))
# Place the 3x3 matrices in the appropriate positions
K_combined[:3, :3] = K_fx
K_combined[3:, 3:] = K_mx
print(K_combined)
\begin{bmatrix}
K_{fxfx} & K_{fxfy} & K_{fxfz} & K_{fxmx} & K_{fxmy} & K_{fxmz} \\
K_{fyfx} & K_{fyfy} & K_{fyfz} & K_{fymx} & K_{fymy} & K_{fymz} \\
K_{fzfx} & K_{fzfy} & K_{fzfz} & K_{fzmx} & K_{fzmy} & K_{fzmz} \\
K_{mxfx} & K_{mxfy} & K_{mxfz} & K_{mxmx} & K_{mxmy} & K_{mxmz} \\
K_{myfx} & K_{myfy} & K_{myfz} & K_{mymx} & K_{mymy} & K_{mymz} \\
K_{mzfx} & K_{mzfy} & K_{mzfz} & K_{mzmx} & K_{mzmy} & K_{mzmz}
\end{bmatrix}
So then, I have this formula, which is supposed to be a description of how to combine the forces and moments compartments, and I am really not sure if this is the correct way yet of doing things however it does look like it has a chance to work so far in my assesment…
Is it possible to do this type of formulation with dolfinx?
So far I made an attempt at doing a similar type of thing but there seems to be a difficulty at solution time. I’m not sure what went wrong here yet, so far the ufl system is still a bit mysterious to me and I have the gist of what those computations mean but there must be something thats causing a congruency and or shape issue at solution time?
Could I get some help with this?
from dolfinx import mesh, fem
import basix
from dolfinx.fem import dirichletbc, locate_dofs_geometrical
L = 72
W = 4.0
# Define the mesh with tetrahedral cells
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
[20, 6, 6], cell_type=mesh.CellType.tetrahedron)
# Define elements for displacements and rotations
element_disp = basix.ufl.element("Lagrange", domain.topology.cell_name(), 1, shape=(3,))
element_rot = basix.ufl.element("Lagrange", domain.topology.cell_name(), 1, shape=(3,))
# Create function spaces for displacements and rotations
V_disp = fem.functionspace(domain, element_disp)
V_rot = fem.functionspace(domain, element_rot)
# Create functions to hold the force vectors at each node
force_disp = fem.Function(V_disp)
force_rot = fem.Function(V_rot)
# Initialize the force vectors to zero
force_disp.vector.set(0.3)
force_rot.vector.set(0.0)
# Define functions for displacement and rotation
u_disp = fem.Function(V_disp)
u_rot = fem.Function(V_rot)
v_disp = fem.Function(V_disp)
v_rot = fem.Function(V_rot)
# Define UFL expressions for the displacement and rotation components
grad_u_disp = ufl.grad(u_disp) # Gradient of displacement u
grad_v_disp = ufl.grad(v_disp) # Gradient of displacement v
# Symmetric part of the gradient (strain tensor) for displacements
epsilon_u = ufl.sym(grad_u_disp)
epsilon_v = ufl.sym(grad_v_disp)
# Bilinear form for displacements
a_disp = fem.form(ufl.inner(epsilon_u, epsilon_v) * ufl.dx)
# (Example) Bilinear form for rotations, assuming small rotations
a_rot = fem.form(ufl.inner(u_rot, v_rot) * ufl.dx)
# Total bilinear form (sum of displacement and rotation contributions)
a = fem.form(ufl.inner(epsilon_u, epsilon_v) * ufl.dx + ufl.inner(u_rot, v_rot) * ufl.dx)
# Define the linear form (force vector)
L_disp = fem.form(ufl.dot(force_disp, v_disp) * ufl.dx)
L_rot = fem.form(ufl.dot(force_rot, v_rot) * ufl.dx)
# Define the total linear form
L = fem.form(ufl.dot(force_disp, v_disp) * ufl.dx + ufl.dot(force_rot, v_rot) * ufl.dx)
# Define the boundary condition
def boundary(x):
return np.isclose(x[0], 0)
# Define the Dirichlet boundary value for vector-valued spaces
zero_disp = fem.Constant(domain, PETSc.ScalarType((0.0, 0.0, 0.0)))
zero_rot = fem.Constant(domain, PETSc.ScalarType((0.0, 0.0, 0.0)))
# Apply Dirichlet boundary conditions to the displacements and rotations
bc_disp = dirichletbc(zero_disp, locate_dofs_geometrical(V_disp, boundary), V_disp)
bc_rot = dirichletbc(zero_rot, locate_dofs_geometrical(V_rot, boundary), V_rot)
# Combine boundary conditions
bcs = [bc_disp, bc_rot]
# Define the linear problem
problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
# Solve the linear problem
u_sol = problem.solve()
# Split the solution into displacement and rotation components
u_disp, u_rot = u_sol.split()
# Output the results
print(f"Displacement:\n{u_disp.x.array}")
print(f"Rotation:\n{u_rot.x.array}")
print(f'dolfinx version: {dolfinx.__version__}')
