Domain with multiple different orthotropic materials in dolphinx
Hi everyone, Hi interested,
I trying to build some example to experiment and learn how to approach problems with multiple domains.
Therefore, I would like to build a stackup of different materials with different behaviours.
This is done with the following code:
Define the material stackup
from pymaterial.materials import IsotropicMaterial, TransverselyIsotropicMaterial, OrthotropicMaterial
mat0 = {
    "name": "steal",
    "thickness": 0.3,
    "stiff_tens": IsotropicMaterial(Em=2e11,nu=0.3, density=7850).get_stiffness() # from ANSYS
mat2 = {
    "name": "E-glass",
    "thickness": 0.3,
    "stiff_tens": OrthotropicMaterial(E_x=4.5e10,
                                       E_y=1e10,
                                       E_z=1e10,
                                       nu_xy=0.3,
                                       nu_yz=0.4,
                                       nu_xz=0.3,
                                       G_xy=5e9,
                                       G_yz=3.8462e9,
                                       G_xz=5e9,
                                       density=2000
                                       ).get_stiffness() # from ANSYS Epoxy E-Glass UD
mat3 = {
    "name": "carbon fibre",
    "thickness": 0.3,
    "stiff_tens": OrthotropicMaterial(E_x=2.3e11,
                                      E_y=2.3e10,
                                      E_z=2.3e10,
                                      nu_xy=0.2,
                                      nu_yz=0.4,
                                      nu_xz=0.2,
                                      G_xy=9e9,
                                      G_yz=8.2143e9,
                                      G_xz=9e9,
                                      density=1800
                                      ).get_stiffness() # from ANSYS Carbon Fiber (230 GPa)
stack = [
    mat1,
    mat2,
    mat3
Build the model and load it into fenics
model = gmsh.model()
name = "Material Stack"
model.add(name)
model.setCurrent(name)
width, length = 1, 1
thickness = 0
gdim = 3  # Geometric dimension of the mesh
model_rank = 0
mesh_comm = MPI.COMM_WORLD
    boxes = []
    coms = []
    for i in range(len(stack)):
        elem = stack[i]
        elem_thickness = elem["thickness"]
        start_height = thickness
        end_height = thickness + elem_thickness
        boxes.append(model.occ.addBox(0, 0, start_height, width, length, elem_thickness))
        thickness = end_height
        coms.append([width/2, length/2, start_height + elem_thickness/2])
    model.occ.synchronize()
    for i in range(len(boxes)-1):
        model.occ.fragment([(3,boxes[i])], [(3,boxes[i+1])])
    for dim_,id_ in model.getEntities(3):
        com = gmsh.model.occ.getCenterOfMass(dim_, id_)
        # print(com)
        for i in range(len(coms)):
            if not np.allclose(com, coms[i]):
                continue
            tag = i
            model.addPhysicalGroup(3, [id_], tag=tag)
            model.setPhysicalName(3, tag, stack[i]["name"])
            break
    model.mesh.generate(dim=3)
    # gmsh.model.mesh.optimize("Netgen")
# Create DOLFINx distributed mesh
from dolfinx.io.gmshio import model_to_mesh
mesh, cell_markers, facet_markers = model_to_mesh(model, mesh_comm, model_rank)
gmsh.finalize()
Defining the problem
In the particular case one approach would be to define a Tensorfunction which represents the stiffness tensor C.
Like:
    return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def strain2voigt(e):
    """e is a 2nd-order tensor, returns its Voigt vectorial representation"""
    return ufl.as_vector([e[0,0],e[1,1],2*e[0,1]])
def voigt2stress(s):
    s is a stress-like vector (no 2 factor on last component)
    returns its tensorial representation
    return ufl.as_tensor([[s[0], s[2]],
                     [s[2], s[1]]])
def sigma(u):
    return voigt2stress(ufl.dot(stiff_tens, strain2voigt(epsilon(u))))
and
from dolfinx.fem import VectorFunctionSpace, TrialFunction, TestFunction
V = VectorFunctionSpace(mesh, ('Lagrange', 1))
u = ufl.TrialFunction(V)
u = Function(V, name='Displacement')
a = ufl.inner(sigma(u), epsilon(v))* ufl.dx
The problem: generating the spacial dependent tensor function
But whatever I tried to build such a tensor function it did not work:
from dolfinx.fem import TensorFunctionSpace, Function, Constant
Q = TensorFunctionSpace(mesh, ("CG", 2))  # CG-Lagrange element, 2-degree of freedom (2nd order element)
stiff_tens=Function(Q)# often symbolized by "C"
material_tags = np.unique(cell_markers.values)
for tag in material_tags:
    cells = cell_markers.find(tag)
    if tag < len(stack):
        material = stack[i]
        stiff_tens.x.array[cells]=np.array(list([material["stiff_tens"]])*len(cells), dtype=ScalarType)
which throws the following error:
ValueError                                Traceback (most recent call last)
Cell In[61], line 12
     10 if tag < len(stack):
     11     material = stack[i]
---> 12     stiff_tens.x.array[cells]=np.array(list([material["stiff_tens"]])*len(cells), dtype=ScalarType)
ValueError: shape mismatch: value array of shape (402,6,6) could not be broadcast to indexing result of shape (402,)
Another question:
dolphin had something called Subdomains, where I could also define other partial differential equations on. For me this means that I could perform the integration with one stiffness tensor over each material domain separetly and then add all matrices together. How would this look in dolphinx or is this not possible?
Thanks in advance!
First I have to fix some small mistakes, I made in my post above and because I did not find an edit option I post my fixes here:
The model creation was missing a sync
name = "Battery Stack"
model.add(name)
thickness = 0
model_rank = 0
    boxes = []
    coms = []
        elem = stack[i]
    model.occ.synchronize()  # <-- Inserted this to fix an issue with the mesh
        # print(com)
                continue
            tag = i
            break
gmsh.finalize()
Voigt notation had to account for three dimensions
def strain2voigt(e, dim: int = 3):
    if dim == 3:
        return ufl.as_vector([e[0,0],e[1,1],e[2,2],2*e[1,2], 2*e[0,2],2*e[0,1]])
def voigt2stress(s, dim: int = 3):
    if dim == 3:
                              [s[0], s[5], s[4]],
                              [s[5], s[1], s[3]],
                              [s[4], s[3], s[2]]
                                [s[0], s[2]],
                                [s[2], s[1]]
def sigma(u, stiff_tens):
With the help of the following to post assemble matrix of subdomain I tried to assemble the stiffness matrix over each subdomain:
V = VectorFunctionSpace(mesh, ('CG', 2)) # CG-Lagrange element, 2-degree of freedom (2nd order element)
stiffnesses = []
        material = stack[tag]
        dx_domain = ufl.Measure('dx', domain=mesh, subdomain_data=cell_markers.find(tag), subdomain_id=tag)
        stiffness = ufl.as_matrix(material["stiff_tens"])
        a = ufl.inner(sigma(u, stiffness), epsilon(v))* dx_domain
        stiffnesses.append(a)
This worked (kind of) until I wanted to solve my problem:
mat = stiffnesses
result = mat[0] + mat[1] + mat[2] # trying to add the different domains back together
problem = LinearProblem(result, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
results in:
AssertionError                            Traceback (most recent call last)
Cell In[18], line 5
      3 mat = stiffnesses
      4 result = mat[0] + mat[1] + mat[2]
----> 5 problem = LinearProblem(result, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
      6 uh = problem.solve()
File /usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/petsc.py:566, in LinearProblem.__init__(self, a, L, bcs, u, petsc_options, form_compiler_options, jit_options)
    538 def __init__(self, a: ufl.Form, L: ufl.Form, bcs: typing.List[DirichletBCMetaClass] = [],
    539              u: typing.Optional[_Function] = None, petsc_options={}, form_compiler_options={}, jit_options={}):
    540     """Initialize solver for a linear variational problem.
    541
    542     Args:
    564                                                "pc_factor_mat_solver_type": "mumps"})
    565     """
--> 566     self._a = _create_form(a, form_compiler_options=form_compiler_options, jit_options=jit_options)
    567     self._A = create_matrix(self._a)
    569     self._L = _create_form(L, form_compiler_options=form_compiler_options, jit_options=jit_options)
File /usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/forms.py:176, in form(form, dtype, form_compiler_options, jit_options)
    173         return list(map(lambda sub_form: _create_form(sub_form), form))
    174     return form
--> 176 return _create_form(form)
--> 138     assert all([id(d) == id(data[0]) for d in data])
    139     subdomains[integral_type] = data[0]
    141 mesh = domain.ufl_cargo()
AssertionError:
Can someone, PLEASE, tell me how to merge the matrixies of the different domains back together? OR is there a better way?
Additionally, I also tried to assemble each matrix before I add them together, but the code from the @dokken - tutorial did not work in this case:
dolfinx.fem.petsc.assemble_matrix(mat[0], bcs=[bc])
returns:
TypeError                                 Traceback (most recent call last)
Cell In[23], line 1
----> 1 dolfinx.fem.petsc.assemble_matrix(mat[0], bcs=[bc])
File /usr/lib/python3.10/functools.py:889, in singledispatch..wrapper(*args, **kw)
    885 if not args:
    886     raise TypeError(f'{funcname} requires at least '
    887                     '1 positional argument')
--> 889 return dispatch(args[0].__class__)(*args, **kw)
File /usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/petsc.py:340, in assemble_matrix(a, bcs, diagonal, constants, coeffs)
    336 @functools.singledispatch
    337 def assemble_matrix(a: typing.Any, bcs: typing.List[DirichletBCMetaClass] = [],
    338                     diagonal: float = 1.0,
    339                     constants=None, coeffs=None) -> PETSc.Mat:
--> 340     return _assemble_matrix_form(a, bcs, diagonal, constants, coeffs)
File /usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/petsc.py:351, in _assemble_matrix_form(a, bcs, diagonal, constants, coeffs)
    343 @assemble_matrix.register(FormMetaClass)
    344 def _assemble_matrix_form(a: form_types, bcs: typing.List[DirichletBCMetaClass] = [],
    345                           diagonal: float = 1.0,
    346                           constants=None, coeffs=None) -> PETSc.Mat:
    347     """Assemble bilinear form into a matrix. The returned matrix is not
    348     finalised, i.e. ghost values are not accumulated.
Did you forget to `#include `? Or ,
, , etc. Some automatic
conversions are optional and require extra headers to be included
when compiling your pybind11 module.
And the error message does not help me much.
Use a DG-0 function and interpolate the stiffness for each subdomain into the appropriate block of cells, e.g.:
import dolfinx as dfx
# Create mesh and function space for stiffness tensor
mesh = dfx.mesh.create_unit_square(MPI.COMM_WORLD, 2, 1)
T = dfx.fem.TensorFunctionSpace(mesh, ("DG", 0), shape=(3, 3))
stiffness = dfx.fem.Function(T)
# Locate cells corresponding to each domain
tol = 1e-6
dom1 = dfx.mesh.locate_entities(mesh, mesh.topology.dim, lambda x: x[0] < 0.5 + tol)
dom2 = dfx.mesh.locate_entities(mesh, mesh.topology.dim, lambda x: x[0] > 0.5 - tol)
# Interpolate stiffnesses for each domain
def tensor(x, a):
    I = np.eye(3).reshape((3 * 3, 1))
    return np.broadcast_to(a * I, (3 * 3, x.shape[1]))
stiffness.interpolate(lambda x: tensor(x, 1.0), dom1)
stiffness.interpolate(lambda x: tensor(x, 2.0), dom2)
# Export the stiffness tensor for verification
with dfx.io.XDMFFile(MPI.COMM_WORLD, "stiffness.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_function(stiffness)
# Example usage in a bilinear form
V = dfx.fem.VectorFunctionSpace(mesh, ("CG", 1))
a = ufl.inner(
    ufl.dot(ufl.as_matrix(stiffness), strain2voigt(epsilon(u))),
    strain2voigt(epsilon(v))
) * ufl.dx
Note that stiffness.interpolate requires a Python function that takes one argument, x, and returns an array of shape (tensor_size, x.shape[1]), where tensor_size is the size of your stiffness tensor. E.g. for the 3x3 stiffness matrix in my 2D example, the size is 3 \times 3 = 9.
Thank you so much!
For everyone interested, here is the complete code:
mat0 = {
    "thickness": 0.3,
    "stiff_tens": IsotropicMaterial(Em=2e11,nu=0.3, density=7850).get_stiffness() # steel from ANSYS
mat1 = {
    "thickness": 0.3,
                                       E_y=1e10,
                                       E_z=1e10,
                                       nu_xy=0.3,
                                       nu_yz=0.4,
                                       nu_xz=0.3,
                                       G_xy=5e9,
                                       G_yz=3.8462e9,
                                       G_xz=5e9,
                                       density=2000
mat2 = {
    "thickness": 0.3,
                                      E_y=2.3e10,
                                      E_z=2.3e10,
                                      nu_xy=0.2,
                                      nu_yz=0.4,
                                      nu_xz=0.2,
                                      G_xy=9e9,
                                      G_yz=8.2143e9,
                                      G_xz=9e9,
                                      density=1800
stack = [
    mat0,
    mat1,
    mat2
thickness = 0
model_rank = 0
# generate mesh
model.add(name)
    boxes = []
    coms = []
        elem = stack[i]
        results = model.occ.fragment([(3,boxes[i])], [(3,boxes[i+1])])
        print(results)
        # print(com)
                continue
            tag = i
            break
gmsh.finalize()
# assemble siffness tensor
T = dolfinx.fem.TensorFunctionSpace(mesh, ("DG", 0), shape=(6, 6))
stiffness = dolfinx.fem.Function(T)
def tensor(x, tens):
    tens_reshaped = tens.reshape((6 * 6, 1))
    return np.broadcast_to(tens_reshaped, (6 * 6, x.shape[1]))
    domain = cell_markers.find(tag)
        stiffness.interpolate(lambda x: tensor(x, material["stiff_tens"].astype(np.float32)), domain)
# helpers
    if dim == 3:
    if dim == 3:
                              [s[0], s[5], s[4]],
                              [s[5], s[1], s[3]],
                              [s[4], s[3], s[2]]
                                [s[0], s[2]],
                                [s[2], s[1]]
# problem
from dolfinx.fem import FunctionSpace
element = ufl.VectorElement('CG', mesh.ufl_cell(), 2)# CG-Lagrange element, 2-degree of freedom (2nd order element)
a = ufl.inner(
) * ufl.dx
# loading
from dolfinx.fem import Constant
body_force = Constant(mesh, ScalarType((0, 0, 0))) # force on body
def surface_force(x):
    return np.isclose(x[1], length)
fdim = mesh.topology.dim - 1
traction_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, surface_force)
traction = Constant(mesh, ScalarType((0, 10/((0.3*3)*width), 0))) # force on surface
ds = ufl.Measure("ds", domain=mesh)
L = ufl.inner(body_force, v) * ufl.dx + ufl.inner(traction, v) * ds
# boundary conditions
def clamped_boundary(x):
    return np.isclose(x[1], 0)
boundary_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, clamped_boundary)
u_D = np.array([0,0,0], dtype=ScalarType)
bc = dolfinx.fem.dirichletbc(u_D, dolfinx.fem.locate_dofs_topological(V, fdim, boundary_facets), V)
# solve
# export
from dolfinx import io
from pathlib import Path
with io.XDMFFile(mesh.comm, Path("/home/fenics/shared/") / "output.xdmf", "w") as xdmf:
    xdmf.write_meshtags(cell_markers)
    uh.name = "Deformation"
    xdmf.write_function(uh)
Why dont you use the symmetry=True flag of the TensorFunctionSpace?
No reason. If you want symmetry, you can use symmetry=True. There was an issue where symmetric tensors weren’t working, but it appears to be fixed.
I think it is not fixed!
With:
T = dolfinx.fem.TensorFunctionSpace(mesh, ("DG", 0), shape=(6, 6), symmetry=True) # added symmetry flag
stiffness = dolfinx.fem.Function(T, dtype=ScalarType)
        stiffness.interpolate(lambda x: tensor(x, material["stiff_tens"].astype(ScalarType)), domain)
and the the rest staying the same
I get a simillar looking issue, when trying to do:
UFLException                              Traceback (most recent call last)
Cell In[29], line 4
      1 from dolfinx.fem.petsc import LinearProblem
----> 4 problem = LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
      5 uh = problem.solve()
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/petsc.py:566, in LinearProblem.__init__(self, a, L, bcs, u, petsc_options, form_compiler_options, jit_options)
    541
    542     Args:
    565     """
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/forms.py:176, in form(form, dtype, form_compiler_options, jit_options)
    174     return form
    133 "Write error message and raise an exception."
    134 self._log.error(*message)
--> 135 raise self._exception_type(self._format_raw(*message))
UFLException: Expecting pulled back expression with shape '(6, 6)', got '(21,)'
I have the latest docker image of dolfinx:stabel with:
Version: 0.6.0
Summary: DOLFINx Python interface
Home-page: UNKNOWN
Author: FEniCS Project
Author-email:
License: UNKNOWN
Location: /usr/local/dolfinx-complex/lib/python3.10/dist-packages
Requires: cffi, fenics-ffcx, fenics-ufl, mpi4py, numpy, petsc4py
Required-by:
and I am not sure in which version the fixed it
Ok. It seems like, the 6.0.0 version is several month old. and the fix was only added recently so its probably not implemented yet (June 2023). If I am mistaken, please correct me!
You can try the dolfinx/dolfinx:nightly docker image and see if the error goes away.
