Computation of the curvature of a general shape
Dear FEniCSx community,
I’m struggling with the computation of the curvature of a surface of a geometry. A great amount of work has been done so far, and I’ve been able to create a functioning code to compute the curvature of a sphere. However, I would need my code to be more general. In order to do so, the only thing I’m changing is the way of computing the normal of my surface.
Unfortunately, I haven’t figured out how to convert the dolfin code to a dolfinx one, that would be robust.
Here is my code :
from dolfinx.io import gmshio
import dolfinx.mesh as msh
from dolfinx import fem, plot
from dolfinx.fem import petsc
import pyvista
def create_sphere_mesh(R=0.3, lc=0.03):
    model_name = "sphere"
    comm = MPI.COMM_WORLD
    model_rank = 0
    model = gmsh.model()
    gmsh.model.add(model_name)
    # Create a sphere of radius R centered at the origin
    gmsh.model.occ.addSphere(0, 0, 0, R)
    gmsh.model.occ.synchronize()
    # Physical groups: volume (3D) and external surface (2D)
    gmsh.model.addPhysicalGroup(3, [1], tag=1)
    gmsh.model.addPhysicalGroup(2, [1], tag=2)  # external surface
    # Mesh generation settings
    gmsh.option.setNumber("Mesh.CharacteristicLengthMax", lc)
    gmsh.model.mesh.generate(3)
    model.mesh.setOrder(2)
    # Save the mesh to file
    gmsh.write(model_name + ".msh")
    # Import mesh into DOLFINx
    mesh_data = gmshio.model_to_mesh(model, comm, model_rank)
    final_mesh = mesh_data.mesh
    cell_tags = mesh_data.cell_tags
    facet_tags = mesh_data.facet_tags
    print(f'facet_tags.indices : {facet_tags.indices}')
    print(f'facet_tags.values : {facet_tags.values}')
    # Close gmsh
    gmsh.finalize()
    tdim = final_mesh.topology.dim
    fdim = tdim - 1
    xref = [0.0, 0.05, 0.0]
    submesh, entity_map = msh.create_submesh(final_mesh, fdim, facet_tags.find(2))[0:2]
    entity_maps_mesh = [entity_map]
    mesh_info = [final_mesh, cell_tags, facet_tags, xref]
    submesh_info = [submesh, entity_maps_mesh]
    return mesh_info, submesh_info
def compute_normal_vector(submesh):
    Compute the normal vector field on a surface mesh.
    For a 2D surface embedded in 3D, we compute the normal using the cross product
    of tangent vectors derived from the parametrization.
    Returns:
        n_func: Function containing the normal vector at each point
    gdim = submesh.geometry.dim
    tdim = submesh.topology.dim
    V_vector = fem.functionspace(submesh, ("CG", 1, (gdim,)))
    n_func = fem.Function(V_vector)
    # Get mesh coordinates
    x = ufl.SpatialCoordinate(submesh)
    # For a 2D surface in 3D, we compute the normal as the cross product
    # of the tangent vectors obtained from the Jacobian
    # The cell normal can be computed using the cross product of coordinate gradients
    # Create DG0 space to compute cell-wise normals
    V_DG = fem.functionspace(submesh, ("DG", 0, (gdim,)))
    n_dg = fem.Function(V_DG)
    # Compute the Jacobian of the mapping
    J = ufl.Jacobian(submesh)
    # For a 2D manifold in 3D, J is a 3x2 matrix
    # The two columns are tangent vectors to the surface
    # Normal = tangent1 × tangent2
    if tdim == 2 and gdim == 3:
        t1 = ufl.as_vector([J[0, 0], J[1, 0], J[2, 0]])
        t2 = ufl.as_vector([J[0, 1], J[1, 1], J[2, 1]])
        # Cross product
        n_cross = ufl.as_vector([
            t1[1] * t2[2] - t1[2] * t2[1],
            t1[2] * t2[0] - t1[0] * t2[2],
            t1[0] * t2[1] - t1[1] * t2[0]
        # Normalize
        norm_n = ufl.sqrt(ufl.dot(n_cross, n_cross))
        n_normalized = n_cross / norm_n
        raise ValueError(f"Expected 2D surface in 3D space, got tdim={tdim}, gdim={gdim}")
    # Project to DG0 space first
    u_dg = ufl.TrialFunction(V_DG)
    v_dg = ufl.TestFunction(V_DG)
    a_dg = ufl.inner(u_dg, v_dg) * ufl.dx
    L_dg = ufl.inner(n_normalized, v_dg) * ufl.dx
    problem_dg = petsc.LinearProblem(a_dg, L_dg, u=n_dg, petsc_options={"ksp_type": "preonly",
                                                         "pc_type": "lu",
                                                         "pc_factor_mat_solver_type":
                                                           "mumps"}, petsc_options_prefix="dg")
    problem_dg.solve()
    # Now interpolate from DG0 to CG1 (averaging at nodes)
    u_cg = ufl.TrialFunction(V_vector)
    v_cg = ufl.TestFunction(V_vector)
    a_cg = ufl.inner(u_cg, v_cg) * ufl.dx
    L_cg = ufl.inner(n_dg, v_cg) * ufl.dx
    problem_cg = petsc.LinearProblem(a_cg, L_cg, u=n_func, petsc_options={"ksp_type": "preonly",
                                                        "pc_type": "lu",
                                                        "mumps"}, petsc_options_prefix="cg")
    problem_cg.solve()
    # Normalize the normal vector at each node
    n_values = n_func.x.array.reshape(-1, gdim)
    norms = np.sqrt(np.sum(n_values**2, axis=1))
    norms[norms < 1e-10] = 1.0
    n_values /= norms[:, np.newaxis]
    n_func.x.array[:] = n_values.flatten()
    return n_func
def harry_plotter(space, sol, str_value, show_edges = True):
    u_topology, u_cell_types, u_geometry = plot.vtk_mesh(space)
    u_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
    u_grid.point_data[str_value] = sol.x.array.real
    u_grid.set_active_scalars(str_value)
    u_plotter = pyvista.Plotter()
    u_plotter.add_mesh(u_grid, show_edges=show_edges)
    u_plotter.view_xy()
    if not pyvista.OFF_SCREEN:
        u_plotter.show()
def compute_mean_curvature(submesh, n_func=None):
    Calculate mean curvature H = div_s(n) on an arbitrary surface.
    The surface divergence is: div_s(n) = div(n) - n^T · (∇n) · n
    Parameters:
        submesh: The surface mesh (2D manifold in 3D space)
        n_func: Optional pre-computed normal vector. If None, it will be computed.
    Returns:
        H_func: Function containing the mean curvature
    V_scalar = fem.functionspace(submesh, ("CG", 1))
    # Compute normal vector if not provided
    if n_func is None:
        print("Computing normal vector...")
        n_func = compute_normal_vector(submesh)
    # Calculate mean curvature H = div_s(n)
    # Surface divergence: div_s(n) = trace((I - n⊗n) · ∇n)
    # This equals: div(n) - (n · ∇n) · n
    H_func = fem.Function(V_scalar)
    # Test and trial functions
    u = ufl.TrialFunction(V_scalar)
    v = ufl.TestFunction(V_scalar)
    # Compute gradient of normal vector
    grad_n = ufl.grad(n_func)
    # Surface divergence using the formula
    # div_s(n) = div(n) - n^T · grad(n) · n
    # where div(n) = trace(grad(n))
    div_n = ufl.tr(grad_n)
    normal_derivative = ufl.dot(n_func, ufl.dot(grad_n, n_func))
    div_s_n = div_n - normal_derivative
    # Variational form: project div_s(n) onto V_scalar
    a = ufl.inner(u, v) * ufl.dx
    L = ufl.inner(div_s_n, v) * ufl.dx
    # Solve the linear system
    problem = petsc.LinearProblem(a, L, u=H_func, petsc_options={"ksp_type": "preonly",
                                                        "pc_type": "lu",
                                                        "mumps"}, petsc_options_prefix="kappa")
    problem.solve()
    # Calculate statistics
    H_values = H_func.x.array.real
    H_mean = np.mean(H_values)
    H_std = np.std(H_values)
    H_min = np.min(H_values)
    H_max = np.max(H_values)
    harry_plotter(V_scalar, H_func, 'kappa', show_edges = True)
    print("\n" + "="*60)
    print("MEAN CURVATURE RESULTS")
    print("="*60)
    print(f"Average mean curvature: {H_mean:.6f}")
    print(f"Standard deviation: {H_std:.6f}")
    print(f"Min value: {H_min:.6f}")
    print(f"Max value: {H_max:.6f}")
    print("="*60 + "\n")
    return H_func, n_func
if __name__ == "__main__":
    # Create the curved cubic domain
    print("Creating curved cubic mesh...")
    #mesh_info, submesh_info = curvedcubic_domain(side_box=0.11, radius=0.1, lc=8e-3)
    mesh_info, submesh_info = create_sphere_mesh(R=0.3, lc=0.02)
    submesh = submesh_info[0]
    print(f"Submesh (surface) has {submesh.topology.index_map(2).size_local} triangles")
    print(f"Submesh (surface) has {submesh.topology.index_map(0).size_local} vertices")
    # Compute mean curvature
    print("\nComputing mean curvature on the surface...")
    H_func, n_func = compute_mean_curvature(submesh)
If the n_func is defined thanks to
r = ufl.sqrt(x[0]**2 + x[1]**2 + x[2]**2)
n_analytical = ufl.as_vector([x[0]/r, x[1]/r, x[2]/r])
n_expr = fem.Expression(n_analytical, V_vector.element.interpolation_points)
n_func.interpolate(n_expr)
then there is no problem. But this is specific to a sphere…
The first long code can be executed without error, and it helps at visualizing the value of the curvature on the structure too.
I give you the outputs:
Average mean curvature: -0.058697
Standard deviation: 16.334957
Min value: -63.747906
Max value: 71.704344
Many thanks for the help.
All the best,
Pierre.
You could try using the code from
which computes the curvature at the quadrature points of the facets.
