Hi all,
I would like to calculate the contact area for the problem in the demo:
> """This demo program uses of the interface to SNES solver for
> variational inequalities to solve a contact mechanics problems in
> FEnics. The example considers a heavy hyperelastic circle in a box
> of the same size"""
> # Copyright (C) 2012 Corrado Maurini
> # This file is part of DOLFIN.
> # DOLFIN is free software: you can redistribute it and/or modify
> # it under the terms of the GNU Lesser General Public License as published by
> # the Free Software Foundation, either version 3 of the License, or
> # (at your option) any later version.
> # DOLFIN is distributed in the hope that it will be useful,
> # but WITHOUT ANY WARRANTY; without even the implied warranty of
> # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
> # GNU Lesser General Public License for more details.
> # You should have received a copy of the GNU Lesser General Public License
> # along with DOLFIN. If not, see <http://www.gnu.org/licenses/>.
> # Modified by Corrado Maurini 2013
> # First added: 2012-09-03
> # Last changed: 2013-11-21
> from dolfin import *
> # Check that DOLFIN is configured with PETSc and CGAL
> if not has_petsc():
> print "DOLFIN must be compiled with PETSc to run this demo."
> exit(0)
> # Create mesh
> mesh = Mesh("../circle_yplane.xml.gz")
> V = VectorFunctionSpace(mesh, "Lagrange", 1)
> # Define functions
> du = TrialFunction(V) # Incremental displacement
> v = TestFunction(V) # Test function
> u = Function(V) # Displacement from previous iteration
> B = Constant((0.0, -0.05)) # Body force per unit volume
> # Kinematics
> I = Identity(V.cell().d) # Identity tensor
> F = I + grad(u) # Deformation gradient
> C = F.T*F # Right Cauchy-Green tensor
> # Invariants of deformation tensors
> Ic = tr(C)
> J = det(F)
> # Elasticity parameters
> E, nu = 10.0, 0.3
> mu, lmbda = Constant(E/(2*(1 + nu))), Constant(E*nu/((1 + nu)*(1 - 2*nu)))
> # Stored strain energy density (compressible neo-Hookean model)
> psi = (mu/2)*(Ic - 2) - mu*ln(J) + (lmbda/2)*(ln(J))**2
> # Total potential energy
> Pi = psi*dx - dot(B, u)*dx
> # Compute first variation of Pi (directional derivative about u in the
> # direction of v)
> F = derivative(Pi, u, v)
> # Compute Jacobian of F
> J = derivative(F, u, du)
> # Symmetry condition (to block rigid body rotations)
> tol = mesh.hmin()
> def symmetry_line(x):
> return abs(x[0]) < DOLFIN_EPS
> bc = DirichletBC(V.sub(0), 0., symmetry_line,method="pointwise")
> # The displacement u must be such that the current configuration x+u
> # remains in the box [xmin,xmax] x [umin,ymax]
> constraint_u = Expression(("xmax - x[0]","ymax - x[1]"), \
> xmax=1.0+DOLFIN_EPS, ymax=1.0)
> constraint_l = Expression(("xmin - x[0]","ymin - x[1]"), \
> xmin=-1.0-DOLFIN_EPS, ymin=-1.0)
> umin = interpolate(constraint_l, V)
> umax = interpolate(constraint_u, V)
> # Define the solver parameters
> snes_solver_parameters = {"nonlinear_solver": "snes",
> "snes_solver" : { "linear_solver" : "lu",
> "maximum_iterations": 20,
> "report": True,
> "error_on_nonconvergence": False,
> # Set up the non-linear problem
> problem = NonlinearVariationalProblem(F, u, bc, J=J)
> # Set up the non-linear solver
> solver = NonlinearVariationalSolver(problem)
> solver.parameters.update(snes_solver_parameters)
> info(solver.parameters, True)
> # Solve the problem
> (iter, converged) = solver.solve(umin, umax)
> # Check for convergence
> if not converged:
> warning("This demo is a complex nonlinear problem. Convergence is not guaranteed when modifying some parameters or using PETSC 3.2.")
> # Save solution in VTK format
> file = File("displacement.pvd")
> file << u
> # plot the current configuration
> plot(u, mode="displacement", wireframe=True, title="Displacement field")
> interactive()
I would appreciate any hints on the implementation of contact area.
Sorry if the question/solution is obvious but my understanding of finite element is limited.
Thanks
