Implementation of the Penalty approach in dolfinx - Hertzian contact
Hello everyone,
I am currently trying to transfer the " Hertzian contact with a rigid indenter using a penalty approach" example (Comet-FEniCS Example) into FEniCSx but I have difficulties formulating the penalty-formulation.
So far the code looks like this and fails in the last line:
from dolfinx import fem, mesh
N=30
domain = mesh.create_unit_cube(MPI.COMM_WORLD, N, N, N//2)
def bottom(x):
    return np.isclose(x[1],0)
def top(x):
    return np.isclose(x[1], N//2)
fdim = domain.topology.dim -1
bottom_facets = mesh.locate_entities_boundary(domain,fdim,bottom)
top_facets = mesh.locate_entities_boundary(domain,fdim,top)
marked_facets = np.hstack([bottom_facets, top_facets])
marked_values = np.hstack([np.full_like(bottom_facets, 1), np.full_like(top_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
metadata = {"quadrature_degree":4}
ds = ufl.Measure('ds',domain=domain,subdomain_data=facet_tag.find(2),metadata=metadata)
V = fem.VectorFunctionSpace(domain, ("CG",1))
u = fem.Function(V, name="Displacement")
du = ufl.TrialFunction(V)
u_ = ufl.TestFunction(V)
u_zero = np.array((0,)*domain.geometry.dim, dtype=ScalarType)
tdim = domain.topology.dim
fdim = tdim - 1
bc = fem.dirichletbc(u_zero, fem.locate_dofs_topological(V, fdim, facet_tag.find(1)), V)
R = 0.5
d = 0.02
circle = fem.Function(V)
circle.interpolate(lambda x: np.stack((x[0], x[1], -d+(pow(x[0],2)+pow(x[1], 2))/2/R)))
E = fem.Constant(domain, ScalarType(10.))
nu = fem.Constant(domain, ScalarType(0.3))
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
def eps(v):
    return ufl.sym(ufl.grad(v))
def sigma(v):
    return lmbda*ufl.tr(eps(v))*ufl.Identity(3) + 2.0*mu*eps(v)
def ppos(x):
    return (x+np.abs(x))/2.
pen = fem.Constant(domain, ScalarType(1e4))
form = ufl.inner(sigma(u), eps(u_))*ufl.dx + pen*ufl.dot(u_[2], ppos(u[2]-circle))*ds
The error I get is the following:
ufl.log.UFLException: Can't add expressions with different shapes.
Since it is no longer possible to use the Expression class, I interpolated an anonymous in 3D. I am sure there is a proper way of implementing this expression but I have not found something comparable.
This Post comes quite close to my problem, but there was no answer to:
“Are there particular ways that penalty methods have to be set up in FEniCSx if the level of penetration is a function of absolute position as opposed to the displacement (as is done in the Hertzian contact example)?”
I use FEniCSx 0.6.0 inside a Docker container.
Many thanks in advance!
You could simply use the ufl.SpatialCoordinate to define your circle, i.e.
N = 30
def bottom(x):
    return np.isclose(x[1], 0)
def top(x):
bottom_facets = mesh.locate_entities_boundary(domain, fdim, bottom)
top_facets = mesh.locate_entities_boundary(domain, fdim, top)
ds = ufl.Measure('ds', domain=domain,
                 subdomain_data=facet_tag.find(2), metadata=metadata)
V = fem.VectorFunctionSpace(domain, ("CG", 1))
fdim = tdim - 1
R = 0.5
d = 0.02
circle = -d+(pow(x[0], 2)+pow(x[1], 2))/2/R
mu = E/2/(1+nu)
def eps(v):
def sigma(v):
def ppos(x):
    return (x+abs(x))/2.
form = ufl.inner(sigma(u), eps(u_))*ufl.dx + pen * \
Thanks Dokken!
After setting up the nonlinear problem i now have a TypeError…
This code:
J = ufl.derivative(form, u, du)
problem = fem.petsc.NonlinearProblem(form, u, bcs=[bc], J=J)
leads to this error:
  File "/home/fenics/shared/mwe.py", line 62, in <module>
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/petsc.py", line 683, in __init__
    self._L = _create_form(F, form_compiler_options=form_compiler_options,
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/forms.py", line 176, in form
    return _create_form(form)
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/forms.py", line 171, in _create_form
    return _form(form)
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/forms.py", line 165, in _form
    return formcls(ufcx_form, V, coeffs, constants, subdomains, mesh, module.ffi, code)
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/forms.py", line 51, in __init__
    super().__init__(ffi.cast("uintptr_t", ffi.addressof(self._ufcx_form)),
TypeError: __init__(): incompatible constructor arguments.
this is because your definition of ds is wrong.
See following working code:
N = 30
def bottom(x):
def top(x):
                 subdomain_data=facet_tag, subdomain_id=2, metadata=metadata)
fdim = tdim - 1
R = 0.5
d = 0.02
circle = -d+(x[0]**2+x[1]**2)/2/R
mu = E/2/(1+nu)
def eps(v):
def sigma(v):
def ppos(x):
Could you please share the full working code?
In case someone wants to use the code.
It works now.
import math
from dolfinx import fem, mesh, log
from petsc4py.PETSc import ScalarType, Options
from dolfinx import nls
N=30
domain = mesh.create_box(MPI.COMM_WORLD,[[0.0,0.0,0.0], [1.0, 1.0, -1.0]], [N, N, N//2], mesh.CellType.hexahedron)
def top(x):
    return np.isclose(x[2], 0)
def symmetry_x(x):
    return np.isclose(x[0], 0)
def symmetry_y(x):
def bottom(x):
    return np.isclose(x[2], -1.0)
def wall_x(x):
     return np.isclose(x[0], 1.0)
def wall_y(x):
     return np.isclose(x[1], 1.0)
fdim = tdim - 1
symx_facets = mesh.locate_entities_boundary(domain, fdim, symmetry_x)
symy_facets = mesh.locate_entities_boundary(domain, fdim, symmetry_y)
wallx_facets = mesh.locate_entities_boundary(domain, fdim, wall_x)
wally_facets = mesh.locate_entities_boundary(domain, fdim, wall_y)
marked_facets = np.hstack([bottom_facets, top_facets, symx_facets, symy_facets, wallx_facets, wally_facets])
marked_values = np.hstack([np.full_like(bottom_facets, 1), np.full_like(top_facets, 2), np.full_like(symx_facets, 3), \
                           np.full_like(symy_facets, 4), np.full_like(wallx_facets, 5), np.full_like(wally_facets, 6)])
ds = ufl.Measure('ds',domain=domain, subdomain_data=facet_tag, metadata=metadata)
V2 = fem.FunctionSpace(domain, ("CG", 1))
V0 = fem.FunctionSpace(domain, ("DG", 0))
gap = fem.Function(V2, name="Gap")
p = fem.Function(V0, name="Contact pressure")
symx_dof = fem.locate_dofs_topological(V.sub(0), fdim, symx_facets)
symy_dof = fem.locate_dofs_topological(V.sub(1), fdim, symy_facets)
bc1 = fem.dirichletbc(u_zero, fem.locate_dofs_topological(V, fdim, facet_tag.find(1)), V)
bc2 = fem.dirichletbc(ScalarType(0), symx_dof, V.sub(0))
bc3 = fem.dirichletbc(ScalarType(0), symy_dof, V.sub(1))
bc = [bc1, bc2, bc3]
R = 0.5
d = 0.02
mu = E/2/(1+nu)
def eps(v):
def sigma(v):
def ppos(x):
pen = fem.Constant(domain, ScalarType(1e5))
    ufl.dot(u_[2], ppos(u[2]-circle))*ds(2)
problem = fem.petsc.NonlinearProblem(form, u, bc, J=J)
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
ksp = solver.krylov_solver
opts = Options()
ksp.setFromOptions()
n, converged = solver.solve(u)
assert(converged)
sig = sigma(u)[2, 2]
stress_expr = fem.Expression(sig, V0.element.interpolation_points())
stresses = fem.Function(V0)
stresses.interpolate(stress_expr)
maxstress = max(np.abs(stresses.vector.array))
gap = circle-u[2]
gap_expr = fem.Expression(gap, V2.element.interpolation_points())
gapval = fem.Function(V2)
gapval.interpolate(gap_expr)
maxgap = max(np.abs(gapval.vector.array))
a = math.sqrt(R*d)
F = 4/3.*float(E)/(1-float(nu)**2)*a*d
p0 = 3*F/(2*math.pi*a**2)
with XDMFFile(MPI.COMM_WORLD, "cube_dolfinx.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain)
    xdmf.write_meshtags(facet_tag)
    xdmf.write_function(u, 0.)
print(f'Contactarea:           {a:.3f} mm²')
print(f'Force:                 {F:.3f} N')
print(f'max Pressure:          {p0:.3f} MPa')
print(f'Computed max Pressure: {maxstress:.3} MPa')
is here a subdomain_id=2 missing?
EDIT: I see it in your form: form = ufl.inner(sigma(u), eps(u_))*ufl.dx + pen * \ ufl.dot(u_[2], ppos(u[2]-circle))*ds(2)
I assume it does the same work as
subdomain_id=2
Exactly. Both expressions should work in theory…
I tried both but the verision in the MWE allows to call multiple ds() in the formulation without defining a new measure each time.
At least as I understand it.
Ah, yes it is so. Thank you!
