Compute function maximum/minimum on subdomains
Hi all!
I’m trying to compute the maximum/minimum of a function on a specific subdomain (ie. not over the whole geometry).
I’m currently doing this:
def calculate_minimum_volume(u, cell_function, subdomain_id):
    V = u.function_space()
    dofmap = V.dofmap()
mesh = V.mesh()
mini = u.vector().max()
for cell in cells(mesh):
    if cell_function[cell.index()] == subdomain_id:
        dofs = dofmap.cell_dofs(cell.index())
        for dof in dofs:
            try:
                [dof][0]
                if u.vector()[dof][0] < mini:
                    mini = u.vector()[dof][0]
            except:
                if u.vector()[dof] < mini:
return mini
mesh = UnitSquareMesh(5, 5)
mf = MeshFunction("size_t", mesh, 2, 0)
domain = CompiledSubDomain('x[1] > 0.5')
domain.mark(mf, 1)
print(calculate_minimum_volume(u, mf, 1))
Though on big meshes it can take ages. Do you guys know a better way of doing this ?
Cheers,
Rem
The following seems snappy enough
def minimum(f, subdomains, subd_id):
    '''Minimum of f over subdomains cells marked with subd_id'''
    V = f.function_space()
    dm = V.dofmap()
    subd_dofs = np.unique(np.hstack(
        [dm.cell_dofs(c.index()) for c in SubsetIterator(subdomains, subd_id)]))
    return np.min(f.vector().get_local()[subd_dofs])
if __name__ == '__main__':
    domain = CompiledSubDomain('x[1] > 0.5 - DOLFIN_EPS')
    f = Expression('x[0]+x[1]', degree=1)
    # Check scaling
    for n in (8, 16, 32, 64, 128, 256):
        mesh = UnitSquareMesh(n, n)
        u = interpolate(f, V)
        mf = MeshFunction('size_t', mesh, 2, 0)
        domain.mark(mf, 1)
        t = Timer('minimum')
        min_value = minimum(u, mf, 1)
        dt = t.stop()
        print dt, min_value
Works like 100 times faster. Thanks!
I’ve tried to change this function to get the maximum but it doesn’t seem to be working :confused:
Do you know what I’ve done wrong ?
def maximum(f, subdomains, subd_id):
    '''Maximum of f over subdomains cells marked with subd_id'''
    dm = V.dofmap()
    return np.max(f.vector().get_local()[subd_dofs])
The error message is:
index -2147483648 is out of bounds for axis 0 with size 10201
I cannot reproduce your behavior. Just by changing Mirok’s code to maximum:
    dm = V.dofmap()
    # Check scaling
        domain.mark(mf, 1)
        t = Timer('max')
        max_value = maximum(u, mf, 1)
        dt = t.stop()
        print( dt, max_value)
I get the following output
Iterating over subset, found 64 entities out of 128.
0.00044637500000000005 2.0
Iterating over subset, found 256 entities out of 512.
0.000759978 2.0
Iterating over subset, found 1024 entities out of 2048.
0.0024261440000000003 2.0
Iterating over subset, found 4096 entities out of 8192.
0.009333566 2.0
Iterating over subset, found 16384 entities out of 32768.
0.035768256000000005 2.0
Iterating over subset, found 65536 entities out of 131072.
0.13794973700000002 2.0
