Hi, I have unit square as my domain and divided it into two subdomains with different material properties using MeshFunction(), I want to calculate the maximum value of \sigma_{yy} (sigma(u)[1, 1] in my case) differently for different subdomains having 2 different material properties. I am able to calculate the maximum value over whole domain using :-
stress = sigma(u)[1, 1]
Vs = FunctionSpace(mesh, 'DG', 0)
stress = local_project(stress, Vs)
print(stress.vector().max())
But not able to do it for 2 subdomains separately.
Here is my MWE :-
domain = Rectangle(Point(0, 0),Point(1, 1))
mesh = generate_mesh(domain, 10)
V = VectorFunctionSpace(mesh, 'CG', 2)
tol = 1E-14
class Omega_0(SubDomain):
return x[1] <= 0.5 + tol
class Omega_1(SubDomain):
return x[1] >= 0.5 - tol
materials = MeshFunction('size_t', mesh, 2)
subdomain_0 = Omega_0()
subdomain_1 = Omega_1()
subdomain_0.mark(materials, 0)
subdomain_1.mark(materials, 1)
materials.set_all(0)
class al(UserExpression):
def __init__(self, materials, al0, al1, **kwargs):
super().__init__(**kwargs)
self.materials = materials
self.k_0 = al0
self.k_1 = al1
if self.materials[cell.index] == 0:
values[0] = self.k_0
values[0] = self.k_1
def value_shape(self):
return ()
E1 = 21e3
nu1 = 0.33
E2 = 210e3
nu2 = 0.25
E = al(materials, E1, E2, degree = 0)
nu = al(materials, nu1, nu2, degree = 0)
lambda_ = E*nu/(1+nu)/(1-2*nu)
mu = E/2./(1+nu)
class bottom(SubDomain):
return on_boundary and near(x[1], 0., 1e-8)
class top(SubDomain):
return on_boundary and near(x[1], 1., 1e-8)
boundaries = MeshFunction("size_t", mesh, mesh.geometry().dim() - 1)
bottom().mark(boundaries, 1)
top().mark(boundaries, 2)
bc_top = DirichletBC(V.sub(1), Constant(0.01), boundaries, 2)
bc_bottom = DirichletBC(V.sub(1), Constant(0.), boundaries, 1)
bc = [bc_bottom, bc_top]
def sigma(u):
return lambda_*tr(epsilon(u))*Identity(d) + 2*mu*epsilon(u)
d = u.geometric_dimension()
f = Constant((0, 0))
T = Constant((0, 0))
L = dot(f, v)*dx + dot(T, v)*ds
dv = TrialFunction(V)
v_ = TestFunction(V)
a_proj = inner(dv, v_)*dx
b_proj = inner(v, v_)*dx
solver.factorize()
if u is None:
solver.solve_local_rhs(u)
return u
return
solve(a == L, u, bc)
I would appreciate any pointers in the direction of how I could achieve 2 different max values in 2 different subdomains.
Thanks.
