Hi everyone,
In the following MWE, I am computing the residual and the jacobian of an energy W with respect to the variable t as:
W = ufl.tr(ufl.grad(m(t))*ufl.grad(m(t)).T)*dv
W_residual_t = ufl.derivative(W, t, t_test)
W_jacobian_t = ufl.derivative(W_residual_t, t, t_trial)
This works as expected.
Now I need to reformulate the problem as follows:
W_residual_t = dW/dt = dW/dm * dm/dt
… similarly for W_jacobian_t
I tried to use ufl.diff, but I ran in errors when I try to build the residual or the jacobian.
In particular, the following lines of code
W = makeW(ufl.variable(t))
dW_dm = ufl.diff(W,ufl.variable(m(t)))
dm_dt = ufl.diff(m(ufl.variable(t)), ufl.variable(t))
W_residual_t = ufl.dot(dW_dm,dm_dt)
give the error: AttributeError: ‘Form’ object has no attribute ‘ufl_shape’.
Can you please help me figure out how can I do this?
I append below the MWE.
Many thanks!
import os
import sys
import petsc4py
from dolfinx import fem, mesh, la
domain = mesh.create_box(comm=MPI.COMM_WORLD, points=[[0.0, 0.0, 0.0], [1, 1, 1]], n=[10, 10, 10], cell_type=mesh.CellType.tetrahedron)
dv = ufl.Measure("dx", domain=domain,metadata = {'quadrature_degree' : 4})
V_t = fem.VectorFunctionSpace(domain,("CG", 1), dim=3)
t, t_test, t_trial = fem.Function(V_t), ufl.TestFunction(V_t), ufl.TrialFunction(V_t)
def m(t):
return ufl.as_vector([ufl.sin(t[0])*ufl.cos(t[1]),
ufl.sin(t[0])*ufl.sin(t[1]),
ufl.cos(t[0])])
def makeW(t):
return ufl.tr(ufl.grad(m(t))*ufl.grad(m(t)).T)*dv
# -------------------- THIS IS THE PART OF THE CODE THAT I WOULD LIKE TO MODIFY ----------------------
# This works
# W = makeW(t)
# # !!! I would like to replace this with dW/dt = dW/dm*dm/dt
# W_residual_t = ufl.derivative(W, t, t_test)
# # !!! I would like to replace this with d2W/dt2 = dW/dm*d2m/dt2
# W_jacobian_t = ufl.derivative(W_residual_t, t, t_trial)
# This does not work
dofs_domain, dofs_borders = V_t.dofmap.index_map, V_t.dofmap.index_map_bs
b = la.create_petsc_vector(dofs_domain, dofs_borders)
J = fem.petsc.create_matrix(fem.form(W_jacobian_t))
class SNESProblem:
def __init__(self, F, u, bcs, J=None):
V = u.function_space
du = ufl.TrialFunction(V)
self.L = fem.form(F)
if J is None:
self.a = fem.form(ufl.derivative(F, u, du))
self.a = fem.form(J)
self.bcs = bcs
self._F, self._J = None, None
self.u = u
def F(self, snes, x, F):
x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
x.copy(self.u.vector)
self.u.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
with F.localForm() as f_local:
f_local.set(0.0)
fem.petsc.assemble_vector(F, self.L)
fem.petsc.apply_lifting(F, [self.a], bcs=[self.bcs], x0=[x], scale=-1.0)
F.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
fem.petsc.set_bc(F, self.bcs, x, -1.0)
F.ghostUpdate(addv=PETSc.InsertMode.INSERT,mode=PETSc.ScatterMode.FORWARD)
def J(self, snes, x, J, P):
J.zeroEntries()
fem.petsc.assemble_matrix(J, self.a, bcs=self.bcs)
J.assemble()
problem = SNESProblem(W_residual_t, t, [], J= W_jacobian_t)
solver_snes = PETSc.SNES().create()
solver_snes.setType("vinewtonrsls")
solver_snes.setFunction(problem.F, b)
solver_snes.setJacobian(problem.J, J)
solver_snes.setTolerances(rtol=1.0e-9, max_it=50)
solver_snes.getKSP().setType("preonly")
solver_snes.getKSP().setTolerances(rtol=1.0e-9)
solver_snes.getKSP().getPC().setType("lu")
solver_snes.solve(None, t.vector)
print("Done")
