Hello FEniCS community,
I’m working on implementing an entropy viscosity method for shock capturing in the 1D Inviscid Burgers’ equation using FEniCSx. However, I’m encountering an error when trying to run my code. Here’s a brief overview of what I’m trying to do:
- I’m using a DG(1) space on a 1D mesh.
- I’ve implemented the entropy viscosity as described in equation 2.3 to 2.6 in https://people.tamu.edu/~guermond//PUBLICATIONS/MS/non_stationnary_jlg_rp_bp.pdf.
- The error occurs when trying to create the nonlinear problem.
I am not sure if this is the right way to implement the norm:
\left\|E\left(u_h\right)-\bar{E}\left(u_h\right)\right\|_{\infty, \Omega}
, average:
and also the min condition.
\nu_h:=S\left(\min \left(\nu_{\max }, \nu_E\right)\right), with S = I the identity.
Attached is my attempt at implementing the entropy viscosity for capturing shock:
from dolfinx.fem import Function, FunctionSpace, dirichletbc, locate_dofs_topological
from ufl import FacetNormal, dx, ds, dS, TestFunction, TrialFunction, grad, inner, max_value, jump, avg, sin, cos, exp, as_vector, CellDiameter, conditional
import dolfinx.fem.petsc
import dolfinx.nls.petsc
# Domain parameters
x_R, x_L = 1.0, 0.0
N_el = 2**7
L = x_R - x_L
cell_size = L / N_el
# Time marching parameters
T = 0.5
dt = 1e-3
# Create mesh and function space
domain = mesh.create_interval(MPI.COMM_WORLD, N_el, [x_L, x_R])
V = FunctionSpace(domain, ("DG", 1))
dt_ufl = fem.Constant(domain, dt)
# Initial condition
def initial_condition(x):
return np.maximum(np.sin(2.0 * np.pi * x[0]), 0.0)
u0 = Function(V)
u0.interpolate(initial_condition)
inlet_value = fem.Constant(domain, 0.0)
# Boundary conditions
def inlet(x):
return np.isclose(x[0], x_L)
def outlet(x):
return np.isclose(x[0], x_R)
inlet_facets = mesh.locate_entities_boundary(domain, domain.topology.dim - 1, inlet)
outlet_facets = mesh.locate_entities_boundary(domain, domain.topology.dim - 1, outlet)
inlet_dofs = locate_dofs_topological(V, domain.topology.dim - 1, inlet_facets)
outlet_dofs = locate_dofs_topological(V, domain.topology.dim - 1, outlet_facets)
bc_inlet = dirichletbc(inlet_value, inlet_dofs, V)
phi = TestFunction(V)
n = FacetNormal(domain)
def Fc(u):
return u**2 / 2
def E(u):
return 0.5 * u**2
def F(u):
return (1 / 3) * u**3
# Entropy viscosity parameters
c_E = 1.0
c_max = 0.5
def entropy_residual(u, u_old):
return (E(u) - E(u_old)) / dt + ufl.div(F(u))
def entropy_viscosity(u, u_old):
h = CellDiameter(domain)
D_h = entropy_residual(u, u_old)
E_avg = fem.assemble_scalar(fem.form(E(u) * dx(domain))) / fem.assemble_scalar(fem.form(1 * dx(domain)))
E_diff = E(u) - E_avg
E_diff_max = fem.assemble_scalar(fem.form(ufl.max_value(abs(E_diff), 1e-15) * dx(domain)))
nu_E = c_E * h**2 * abs(D_h) / E_diff_max
nu_max = c_max * h * max_value(abs(u), abs(u_old))
nu_h = ufl.conditional(ufl.lt(nu_E, nu_max), nu_E, nu_max)
return nu_h
def numerical_flux(u_p, u_m, n):
C = max_value(abs(u_p), abs(u_m))
flux = (Fc(u_p) + Fc(u_m)) / 2 + C / 2 * (u_p - u_m)
return flux
def domain_flux(u):
interior_flux = inner(numerical_flux(u("+"), u("-"), n("+")), phi("+") - phi("-")) * dS
inlet_flux = numerical_flux(u, inlet_value, n) * phi * ds(1)
outlet_flux = numerical_flux(u, u, n) * phi * ds(2)
return interior_flux + inlet_flux + outlet_flux
def volume_term(u, u_old):
nu_h = entropy_viscosity(u, u_old)
return (inner(u - u_old, phi) - dt_ufl * inner(as_vector([Fc(u)]), grad(phi)) + dt_ufl * inner(nu_h * grad(u), grad(phi))) * dx(domain)
# Time-stepping
u_old = Function(V)
u_old.interpolate(initial_condition)
t = 0
while t < T - 0.5 * dt:
t += float(dt)
F = volume_term(u, u_old) + dt_ufl * domain_flux(u)
J = ufl.derivative(F, u)
problem = fem.petsc.NonlinearProblem(F, u, bcs=[bc_inlet])
solver = dolfinx.nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.solve(u)
u.x.scatter_forward()
u_old.x.array[:] = u.x.array[:].copy()
print(f"t = {t:.3f}")
print("Simulation completed.")
The error I’m getting is:
ValueError: Component and shape length don’t match.
The full traceback is:
File "/home/jy384/projects/UnimodalSROB/examples/burgers/burgersFEniCSx_Inviscid_TimeStep.py", line 180, in <module>
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/dolfinx/fem/petsc.py", line 897, in __init__
self._L = _create_form(
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/dolfinx/fem/forms.py", line 249, in form
return _create_form(form)
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/dolfinx/fem/forms.py", line 244, in _create_form
return _form(form)
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/dolfinx/fem/forms.py", line 186, in _form
ufcx_form, module, code = jit.ffcx_jit(
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/dolfinx/jit.py", line 51, in mpi_jit
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/dolfinx/jit.py", line 201, in ffcx_jit
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 276, in compile_forms
raise e
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 256, in compile_forms
impl = _compile_objects(
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 383, in _compile_objects
_, code_body = ffcx.compiler.compile_ufl_objects(
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ffcx/compiler.py", line 108, in compile_ufl_objects
analysis = analyze_ufl_objects(ufl_objects, options["scalar_type"]) # type: ignore
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ffcx/analysis.py", line 94, in analyze_ufl_objects
form_data = tuple(_analyze_form(form, scalar_type) for form in forms)
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ffcx/analysis.py", line 94, in <genexpr>
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ffcx/analysis.py", line 180, in _analyze_form
form_data = ufl.algorithms.compute_form_data(
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/algorithms/compute_form_data.py", line 278, in compute_form_data
form = preprocess_form(form, complex_mode)
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/algorithms/compute_form_data.py", line 232, in preprocess_form
form = apply_algebra_lowering(form)
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/algorithms/apply_algebra_lowering.py", line 150, in apply_algebra_lowering
return map_integrand_dags(LowerCompoundAlgebra(), expr)
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/algorithms/map_integrands.py", line 86, in map_integrand_dags
return map_integrands(
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/algorithms/map_integrands.py", line 29, in map_integrands
mapped_integrals = [
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/algorithms/map_integrands.py", line 30, in <listcomp>
map_integrands(function, itg, only_integral_type) for itg in form.integrals()
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/algorithms/map_integrands.py", line 39, in map_integrands
return itg.reconstruct(function(itg.integrand()))
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/algorithms/map_integrands.py", line 87, in <lambda>
lambda expr: map_expr_dag(function, expr, compress), form, only_integral_type
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/corealg/map_dag.py", line 35, in map_expr_dag
(result,) = map_expr_dags(
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/corealg/map_dag.py", line 103, in map_expr_dags
r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/algorithms/apply_algebra_lowering.py", line 111, in div
return a[..., i].dx(i)
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/exproperators.py", line 383, in _getitem
all_indices, slice_indices, repeated_indices = create_slice_indices(
File "/home/jy384/miniconda3/envs/fenicsx/lib/python3.11/site-packages/ufl/index_combination_utils.py", line 167, in create_slice_indices
raise ValueError("Component and shape length don't match.")
ValueError: Component and shape length don't match.
Has anyone encountered a similar issue or can provide guidance on how to properly implement the entropy viscosity in this context?
Thank you in advance for any help or insights!
