Hi everone!
I’m trying to solve a flow around a cylinder with FEniCSx.
The boundaty conditions:
u=(1,0) at inflow and walls
u=(0,0) around the cylinder
p=0 at outflow
This is my code:
import math
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym, MixedElement)
create_vector, create_matrix, set_bc)
from dolfinx.fem import (Constant, Function, FunctionSpace,
assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc)
##########################################################################################################3
# Read the mesh
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "Mesh/mesh.xdmf", "r") as xdmf:
domain = xdmf.read_mesh()
# Definition of Spaces. (dim and polinomial type)
v_cg1 = VectorElement("CG", domain.ufl_cell(), 2)
s_cg1 = FiniteElement("CG", domain.ufl_cell(), 1)
V = dolfinx.fem.FunctionSpace(domain, v_cg1)
Q = dolfinx.fem.FunctionSpace(domain, s_cg1)
Z = MixedElement([v_cg1, s_cg1])
W = dolfinx.fem.FunctionSpace(domain, Z)
# Boundary subdomains and coditions
# Definition of subdomains
x_1 = -40
x_2 = 50
y_1 = -40
y_2 = 40
def upstream(x):
return np.isclose(x[0],x_1)
def downstream(x):
return np.isclose(x[0],x_2)
def walls(x):
return np.logical_or(np.isclose(x[1],y_1),np.isclose(x[1],y_2))
def cylinder(x):
return np.logical_and(np.greater(x[0]**2+x[1]**2, 0.2),np.less(x[0]**2+x[1]**2, 1))
fdim = domain.topology.dim -1
up_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, upstream)
down_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, downstream)
wall_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, walls)
cylinder_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, cylinder)
def u_exact(x):
values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
values[0] = 1
return values
u_icondition = Function(V)
p_icondition = Function(Q)
u_cylindercondition = Function(V)
u_icondition.interpolate(u_exact)
up_f = dolfinx.fem.locate_dofs_topological(W.sub(0), fdim, up_facets)
wall_f = dolfinx.fem.locate_dofs_topological(W.sub(0), fdim, wall_facets)
cylinder_f = dolfinx.fem.locate_dofs_topological(W.sub(0), fdim, cylinder_facets)
down_f = dolfinx.fem.locate_dofs_topological(W.sub(1), fdim, down_facets)########################################################################################################
x_1 = -40
x_2 = 50
y_1 = -40
y_2 = 40
def upstream(x):
def downstream(x):
def walls(x):
def cylinder(x):
def u_exact(x):
values[0] = 1
return values
# Bounday conditions
bc_u = dirichletbc(u_icondition, up_f)
bc_w = dirichletbc(u_icondition, wall_f)
bc_cylinder = dirichletbc(u_cylindercondition, cylinder_f)
bc_p = dirichletbc(p_icondition, down_f)
bc = [bc_u, bc_w, bc_cylinder, bc_p]
mu = Constant(domain, PETSc.ScalarType(0.02))
n = FacetNormal(domain)
return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
return 2*mu*epsilon(u) - p*Identity(len(u))
w = Function(W)
u, p = ufl.split(w)
m = TestFunction(W)
v, q = ufl.split(m)
F = dot(dot(u,nabla_grad(u)),v)*dx + div(u)*q*dx + inner(sigma(u,p),epsilon(v))*dx + dot(p*n, v)*ds - dot(mu*nabla_grad(u)*n, v)*ds
J = ufl.derivative(F, w)
residual = dolfinx.fem.form(F)
jacobian = dolfinx.fem.form(J)
deltax = dolfinx.fem.Function(Wsssssssssssssssssssssssssssssssssssssssssssssssssssss)
A = dolfinx.fem.petsc.create_matrix(jacobian)
L = dolfinx.fem.petsc.create_vector(residual)
solver.setOperators(A)
i = 0
dx_norm = []
max_iterations = 25
while i < max_iterations:
# Assemble Jacobian and residual
with L.localForm() as loc_L:
loc_L.set(0)
A.zeroEntries()
dolfinx.fem.petsc.assemble_matrix(A, jacobian, bcs=bc)
dolfinx.fem.petsc.assemble_vector(L, residual)
L.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
L.scale(-1)
# Compute b - J(u_D-u_(i-1))
dolfinx.fem.petsc.apply_lifting(L, [jacobian], [bc], x0=[w.vector], scale=1)
# Set dx|_bc = u_{i-1}-u_D
dolfinx.fem.petsc.set_bc(L, bc, w.vector, 1.0)
L.ghostUpdate(addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD)
# Solve linear problem
solver.solve(L, deltax.vector)
deltax.x.scatter_forward()
# Update u_{i+1} = u_i + delta x_i
w.x.array[:] += deltax.x.array
i += 1
# Compute norm of update
correction_norm = deltax.vector.norm(0)
# Compute L2 error comparing to the analytical solution
#L2_error.append(np.sqrt(mesh.comm.allreduce(dolfinx.fem.assemble_scalar(error), op=MPI.SUM)))
dx_norm.append(correction_norm)
print(f"Iteration {i}: Correction norm {correction_norm}")
if correction_norm < 1e-10:
break
and the mesh is here: 446.5 KB folder on MEGA
It finishes at the first iteration and return 0.0
I dont find the problem. does anyone know why?
Thank you in advance!
