Computing surface integral on 3D domain closed by 2D triangles
Hello community,
I have the following setting: I intend to compute the volume by means of a surface integral over an enclosed boundary on a 3D body, which works.
Now, I have a body where this integration surface is open. So - I use a 2D Delauney triangulation to close the surface. Therefore, I have additional boundary elements (triangles) in my XDMF file, but no additional volume elements (tetrahedras) or nodes. Fine.
Now, if I perform the integration on this part of the surface (the “only triangle” one, meaning triangles that do not belong to a volume element), the value is always zero.
The following MWE reflects this (a 3D profile closed by 2D triangles at each end), where I just compute the area of a face.
#!/usr/bin/env python3
from dolfinx import Function, VectorFunctionSpace
from dolfinx.fem import assemble_scalar
from ufl import FacetNormal, ds, dot
comm = MPI.COMM_WORLD
# read in xdmf mesh - domain
with XDMFFile(comm,'domain.xdmf','r',encoding=XDMFFile.Encoding.ASCII) as infile:
    mesh = infile.read_mesh(name="Grid")
# read in xdmf mesh - boundary
mesh.topology.create_connectivity(2, mesh.topology.dim)
with XDMFFile(comm,'boundary.xdmf','r',encoding=XDMFFile.Encoding.ASCII) as infile:
    mt_s = infile.read_meshtags(mesh, name="Grid_surf")
# reference normal on mesh facets
n0 = FacetNormal(mesh)
V = VectorFunctionSpace(mesh, ("CG", 1))
one = Function(V)
one.vector.set(1.0)
# 8, 9 are the triangulated closures, should yield area 1
# 4, 5, 6, 7 are the outer faces, should yield 2.25 each
ds_ = ds(subdomain_data=mt_s, subdomain_id=9)
# surface form
surfaceform = -dot(one,n0)*ds_
surface = assemble_scalar(surfaceform)
print(surface)
The domain and boundary xdmf files are:
domain.xdmf
<Xdmf Version="3.0">
  <Domain>
    <Grid Name="Grid">
      <Geometry GeometryType="XYZ">
        <DataItem DataType="Float" Dimensions="24 3" Format="XML" Precision="8">
          0.0 0.0 1.5
          0.0 0.0 0.0
          0.0 1.5 1.5
          0.0 1.5 0.0
          1.5 0.0 0.0
          1.5 0.0 1.5
          1.5 1.5 1.5
          1.25 0.25 1.5
          0.25 0.25 1.5
          1.25 1.25 1.5
          0.25 1.25 1.5
          1.5 1.5 0.0
          1.25 0.25 0.0
          0.25 0.25 0.0
          1.25 1.25 0.0
          0.25 1.25 0.0
          0.0 0.75 0.75
          0.75 0.0 0.75
          0.75 1.5 0.75
          1.5 0.75 0.75
          0.75 0.25 0.75
          1.25 0.75 0.75
          0.75 1.25 0.75
          0.25 0.75 0.75
        </DataItem>
      </Geometry>
      <Topology NodesPerElement="4" NumberOfElements="48" TopologyType="tetrahedron">
        <DataItem DataType="Int" Dimensions="48 4" Format="XML" Precision="4">
          8 17 0 5
          15 1 3 16
          10 18 6 2
          8 16 2 0
          11 3 18 14
          5 6 9 19
          17 13 1 4
          12 19 11 4
          7 21 12 5
          2 15 23 10
          20 12 5 7
          11 14 9 21
          12 21 11 19
          12 11 21 14
          2 23 8 10
          2 8 23 16
          5 20 8 17
          20 5 8 7
          5 21 9 7
          21 5 9 19
          13 0 17 1
          13 17 12 4
          13 12 17 20
          5 12 17 4
          5 17 12 20
          15 16 2 23
          15 2 16 3
          15 16 13 1
          15 13 16 23
          0 13 16 1
          9 19 11 21
          9 11 19 6
          11 9 18 6
          10 9 18 22
          10 18 9 6
          2 15 18 3
          14 15 18 22
          14 18 15 3
          12 19 5 21
          12 5 19 4
          9 18 14 11
          18 9 14 22
          16 13 8 23
          16 8 13 0
          17 13 8 0
          17 8 13 20
          10 15 18 2
          10 18 15 22
        </DataItem>
      </Topology>
      <Attribute AttributeType="Scalar" Center="Cell" Name="materials">
        <DataItem DataType="Int" Dimensions="48" Format="XML" Precision="4">
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
          1
        </DataItem>
      </Attribute>
    </Grid>
  </Domain>
</Xdmf>
boundary.xdmf
  <Domain>
    <Grid Name="Grid_surf">
          0.0 0.0 1.5
          0.0 0.0 0.0
          0.0 1.5 1.5
          0.0 1.5 0.0
          1.5 0.0 0.0
          1.5 0.0 1.5
          1.5 1.5 1.5
          1.25 0.25 1.5
          0.25 0.25 1.5
          1.25 1.25 1.5
          0.25 1.25 1.5
          1.5 1.5 0.0
          1.25 0.25 0.0
          0.25 0.25 0.0
          1.25 1.25 0.0
          0.25 1.25 0.0
          0.0 0.75 0.75
          0.75 0.0 0.75
          0.75 1.5 0.75
          1.5 0.75 0.75
          0.75 0.25 0.75
          1.25 0.75 0.75
          0.75 1.25 0.75
          0.25 0.75 0.75
        </DataItem>
      </Geometry>
      <Topology NodesPerElement="3" NumberOfElements="52" TopologyType="triangle">
        <DataItem DataType="Int" Dimensions="52 3" Format="XML" Precision="4">
          2 0 8
          0 5 8
          2 10 6
          2 8 10
          9 5 6
          8 5 7
          7 5 9
          10 9 6
          3 15 1
          1 13 4
          1 15 13
          3 11 14
          3 14 15
          12 11 4
          13 12 4
          12 14 11
          8 23 10
          13 23 8
          10 23 15
          15 23 13
          7 20 8
          12 20 7
          8 20 13
          13 20 12
          7 9 21
          12 7 21
          9 14 21
          14 12 21
          9 10 22
          14 9 22
          10 15 22
          15 14 22
          1 0 16
          0 2 16
          3 1 16
          2 3 16
          0 1 17
          5 0 17
          1 4 17
          4 5 17
          2 18 3
          6 18 2
          3 18 11
          11 18 6
          4 19 5
          11 19 4
          5 19 6
          6 19 11
          10 8 9
          7 8 9
          14 13 12
          15 13 14
        </DataItem>
      </Topology>
      <Attribute AttributeType="Scalar" Center="Cell" Name="boundaries_surf">
        <DataItem DataType="Int" Dimensions="52" Format="XML" Precision="4">
          1
          1
          1
          1
          1
          1
          1
          1
          2
          2
          2
          2
          2
          2
          2
          2
          3
          3
          3
          3
          3
          3
          3
          3
          3
          3
          3
          3
          3
          3
          3
          3
          4
          4
          4
          4
          5
          5
          5
          5
          6
          6
          6
          6
          7
          7
          7
          7
          8
          8
          9
          9
        </DataItem>
      </Attribute>
    </Grid>
  </Domain>
</Xdmf>
Setting subdomain_id in ds_ to 4, 5, 6, or 7 (outer faces), we each get the desired area of 2.25. Setting subdomain_id to 8 or 9 yields 0, even though these surfaces should give an area of 1.0.
Does someone have an idea why this is not working? Is there some check internally whether a facet belongs to a volume element, and if not, it is ignored?
I’d appreciate any advice!
Best,
Marc
As far as I see, this is not possible in a straightforward manner. FacetNormal only returns the normal to the 3D mesh, not respecting what additional (2D) elements are in the boundary file. Guess one could read in the boundary file as separate mesh object and then use the CellNormal function (FacetNormal of 2D elements is a normal to the edges, lying in-plane with the element), but then one needs to distinguish over what part integration is performed, rendering things complicated.
Best approach is certainly just using a 3D lid volume which is not part of any volume integral (so is not “seen” by the mechanical problem), but of which the inward pointing surface is part of the boundary integral.
Just in case anyone else might have a similar problem…
