Hello, I am trying to figure out how to relate face indices on a BoundaryMesh with the relevant indices on the parent mesh. In the minimal code below I attempt to extract the faces on the bottom of a cube using MeshFunction but I must not be understanding how BoundaryMesh.entity_map() works. Any help as to why the first example doesn’t work but the second one does would be very much appreciated… Thank you!
# volumetric mesh and its boundary mesh
vmesh = UnitCubeMesh(10, 10, 10)
bmesh = BoundaryMesh(vmesh, "exterior")
# meshfunctions of dimension 2 for the volumetric/boundary mesh
mfv = MeshFunction("size_t", vmesh, 2)
mfb = MeshFunction("size_t", vmesh, 2)
# maps face indices on the boundary mesh to indices on the full mesh
facemap = bmesh.entity_map(2)
# expect smv to extract all faces on the boundary pointing downward from vmesh
for f in faces(bmesh):
if Facet(vmesh, cellmap[f.index()]).normal().z() < -0.5:
mfv[facemap[f.index()]] = 1
smv = SubMesh(vmesh,mfv,1)
# meanwhile somehow this code works
# expect mf to have value "1" for each face on boundary mesh pointing downward
mfb[f] = 1
smb = SubMesh(bmesh,mfb,1)
vtkfile("smv.pvd") << smv
vtkfile("smb.pvd") << smb
SubMesh from mfv:
[since I am a new user it won’t let me upload a screenshot of the SubMesh from mfb but the result is as expected (just the bottom surface of the cube)]
Edit: This is on the latest stable version of fenics using docker
