Constrained problem with PETScKrylov
I am solving a 3D elasticity problem with PETScKrylov solver and trying to introduce constraints.
This 3D elasticity is coupled with a deformation gradient dependent phase field parameter, c. This parameter is a ''vector" of n elements (each denoting a separate variant of the phase)
I need help to introduce the following constraints in my code, but I am not sure whether it would be possible:
  1. Each component c_i needs to be within 0 and 1 (inclusive).
  2. Sum of all c_i is also between 0 and 1.
Thank you!
P.S. I am aware that PETScSNES solver allows for lower and upper bounds. But this solver didn’t converge at all so switched over to PETScKrylov.
