Variational formulation of elasticity problem when using different function types
Hi there,
I am trying to define regions with different material properties, on which to solve an elasticity problem with displacement defined as a CG2 function.
When mu and lambda are also set using CG2 functions, the model runs fine, but I feel material properties should be defined element-wise. (MWE1)
MWE1:
from dolfinx import mesh, fem, plot, io, nls,log
from dolfinx.fem import FunctionSpace,VectorFunctionSpace, Function,TensorFunctionSpace, Constant
from ufl import TestFunction, TrialFunction, dx, inner,grad, Measure,derivative,system
import time
startT = time.time()
L = 15.0
l= 10.0
d= 5.0
domain = mesh.create_box(MPI.COMM_WORLD,[[0.0,0.0,0.0], [L, l, d]], [15,20,5], mesh.CellType.hexahedron)
V = fem.VectorFunctionSpace(domain, ("CG", 2))
Vdim1=fem.FunctionSpace(domain, ("CG", 2))
xdmf = io.XDMFFile(domain.comm, "YoungsModulus.xdmf", "w")
xdmf.write_mesh(domain)
def bottom(x):
    return np.isclose(x[1], 0)
def top(x):
    return np.isclose(x[1], l)
fdim = domain.topology.dim -1
bottom_facets = mesh.locate_entities_boundary(domain, fdim, bottom)
top_facets = mesh.locate_entities_boundary(domain, fdim, top)
marked_facets = np.hstack([bottom_facets, top_facets])
marked_values = np.hstack([ np.full_like(bottom_facets, 1), np.full_like(top_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
u_bc = np.array((0,) * domain.geometry.dim, dtype=PETSc.ScalarType)
bottom_dofs = fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.find(1))
bc1=fem.dirichletbc(u_bc, bottom_dofs, V)
loaded_boundary_dofs_z = fem.locate_dofs_topological(V.sub(1), facet_tag.dim, facet_tag.find(2))
u_AD = ScalarType(-0.1)
bc2 = fem.dirichletbc(u_AD, loaded_boundary_dofs_z, V.sub(1))
bcs = [bc1,bc2]
B = fem.Constant(domain, PETSc.ScalarType((0, 0, 0)))
T = fem.Constant(domain, PETSc.ScalarType((0, 0, 0)))
u = fem.Function(V)
d = len(u)
I = ufl.variable(ufl.Identity(d))
F = ufl.variable(I + ufl.grad(u))
C = ufl.variable(F.T * F)
Ic = ufl.variable(ufl.tr(C))
J  = ufl.variable(ufl.det(F))
E_gel = fem.Constant(domain,PETSc.ScalarType(150))
pr_gel = fem.Constant(domain,PETSc.ScalarType(0.3))
E_miner = fem.Constant(domain,PETSc.ScalarType(15000))
E_field=Function(Vdim1)
mu_field=Function(Vdim1)
lmbda_field=Function(Vdim1)
    return ufl.sym(ufl.grad(u))
coord=Vdim1.tabulate_dof_coordinates()
Evalues=E_field.x.array
for i, (x,y,z) in enumerate(coord):
    if y<=5.2:
        Evalues[i]=E_miner.value
        Evalues[i]=E_gel.value
E_field.x.array[:]=Evalues
lmbda_field.x.array[:] = E_field.x.array*pr_gel.value/((1+pr_gel.value)*(1-2*pr_gel.value))
mu_field.x.array[:] = E_field.x.array/(2*(1+pr_gel.value))
psi = (mu_field / 2) * (Ic - 3) - mu_field * ufl.ln(J) + (lmbda_field / 2) * (ufl.ln(J))**2
P = ufl.diff(psi, F)
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
F = ufl.inner(ufl.grad(v), P)*dx - ufl.inner(v, B)*dx - ufl.inner(v, T)*ds(2)
problem = fem.petsc.NonlinearProblem(F, u, bcs)
solver = nls.petsc.NewtonSolver(domain.comm, problem)
# Set Newton solver options
solver.atol = 1e-8
solver.rtol = 1e-8
# Solve problem in time steps
tval0 = 0
T.value[2] = tval0
num_its, converged = solver.solve(u)
assert(converged)
u.x.scatter_forward()
xdmf.write_function(E_field, 1)
xdmf.close()
endT = time.time()
print("The time of execution of above program is :",(endT-startT),flush=True)
When mu and lambda are defined using DG0 functions, and displacement with (Lagrange,1) the model also runs but plotting material properties shows a layer of elements with arbitrary low Youngs modulus (MWE2).
MWE2:
import time
L = 15.0
l= 10.0
d= 5.0
"""V = fem.VectorFunctionSpace(domain, ("CG", 2))
Vdim1=fem.FunctionSpace(domain, ("CG", 2))"""
V = fem.VectorFunctionSpace(domain, ("Lagrange", 1))
Vdim1=fem.FunctionSpace(domain, ("Lagrange", 1))
Q = FunctionSpace(domain, ("DG", 0))
xdmf = io.XDMFFile(domain.comm, "YoungsModulusDG.xdmf", "w")
def Omega_0(x):
    return x[1] <= 5.2
def Omega_1(x):
    return x[1] > 5.2
Young=Function(Q)
mu_field=Function(Q)
lmbda_field=Function(Q)
cells_0 = mesh.locate_entities(domain, domain.topology.dim, Omega_0)
cells_1 = mesh.locate_entities(domain, domain.topology.dim, Omega_1)
Young.x.array[cells_0] = np.full_like(cells_0, E_miner.value, dtype=PETSc.ScalarType)
Young.x.array[cells_1] = np.full_like(cells_1, E_gel.value, dtype=PETSc.ScalarType)
xdmf.write_function(Young, 1)
xdmf.close()
def bottom(x):
def top(x):
bcs = [bc1,bc2]
u = fem.Function(V)
d = len(u)
lmbda_field.x.array[:] = Young.x.array*pr_gel.value/((1+pr_gel.value)*(1-2*pr_gel.value))
mu_field.x.array[:] = Young.x.array/(2*(1+pr_gel.value))
solver.atol = 1e-8
solver.rtol = 1e-8
tval0 = 0
T.value[2] = tval0
assert(converged)
endT = time.time()
pritype or paste code here
Finally, when mu and lambda are defined using DG0 functions, and displacement with CG2, the solver throws error: RuntimeError: Failed to successfully call PETSc function ‘KSPSolve’. PETSc error code is: 76,
I realise I am most likely facing dimension inconsistencies but I am really confused as to how to best address this problem.
Thank you in advance for your help.
This only gives you all cells where every vertex satisfies the constraint.
This means that in the transfer region where some vertices are in omega 0 and others in omega 1 you have cells that fall outside each category.
See A question about Function numerical setting - #3 by hherlyng
Oh I see, thank you very much, that solved my issue.
