Hello everyone,
Following my attempts of mixing dolfinx, dolfinx_mpc and scifem packages all together, I came up with some issues regarding the convergence of the problem. To this end, I created a benchmark with a MWE, i.e., a 3D periodic poisson problem, to mimic the convergence issue that I encountered. In this benchmark, I compare the imposition of 3D periodic BCs and dirichlet BCs on master surfaces to the imposition of dirichlet BCs on all faces (w.o. periodic BCs). This is the script:
from __future__ import annotations
from typing import Union
import dolfinx.fem as fem
from dolfinx import default_scalar_type, plot
from dolfinx.common import Timer
from dolfinx.fem import Function, assemble_scalar, form
from dolfinx.mesh import CellType, create_unit_cube, locate_entities_boundary, meshtags, exterior_facet_indices
from numpy.typing import NDArray
from ufl import (
SpatialCoordinate,
TestFunction,
TrialFunction,
derivative,
dx,
grad,
inner
from dolfinx_mpc import NonlinearProblem, LinearProblem, MultiPointConstraint
def benchmark_periodic3D(celltype: CellType, N: int, periodic: bool):
# Create mesh and finite element
mesh = create_unit_cube(MPI.COMM_WORLD, N, N, N, celltype)
tdim = mesh.topology.dim
V = fem.functionspace(mesh, ("Lagrange", 2))
tol = float(5e2 * np.finfo(default_scalar_type).resolution)
print(f'\nTolerance: {tol}, Celltype: {celltype}, Nº cells: {mesh.topology.index_map(mesh.topology.dim).size_local}')
def dirichlet_boundary_total(x: NDArray[Union[np.float32, np.float64]]) -> NDArray[np.bool_]:
return np.logical_or(
np.logical_or(
np.logical_or(np.isclose(x[0], 0.0, atol=tol), np.isclose(x[0], 1.0, atol=tol)),
np.logical_or(np.isclose(x[1], 0.0, atol=tol), np.isclose(x[1], 1.0, atol=tol))
np.logical_or(np.isclose(x[2], 0.0, atol=tol), np.isclose(x[2], 1.0, atol=tol))
def dirichlet_boundary_periodic(x: NDArray[Union[np.float32, np.float64]]) -> NDArray[np.bool_]:
np.logical_or(np.isclose(x[0], 0.0, atol=tol), np.isclose(x[1], 0.0, atol=tol)),
# Create Dirichlet boundary condition
u_L = Function(V)
u_L.interpolate(lambda x: -1.0/6.0 * ((x[0]-0.5)**2 + (x[1]-0.5)**2 + (x[2]-0.5)**2))
dirichletboundary = dirichlet_boundary_periodic if periodic else dirichlet_boundary_total
geometrical_dofs = fem.locate_dofs_geometrical(V, dirichletboundary)
bc = fem.dirichletbc(u_L, geometrical_dofs)#, V)
bcs = [bc]
def PeriodicBoundary(axis):
Full surface minus dofs constrained by BCs
return lambda x: np.isclose(x[axis], 1.0, atol=tol)
def create_periodic_map(axis):
def periodic_relation(x):
out_x = np.zeros(x.shape)
for i in range(3):
out_x[i] = x[i] - 1.0 if i == axis else x[i]
return out_x
return periodic_relation
with Timer("~~Periodic: Compute mpc condition"):
mpc = MultiPointConstraint(V)
for axis in range(3):
facets = locate_entities_boundary(mesh, mesh.topology.dim - 1, PeriodicBoundary(axis))
arg_sort = np.argsort(facets)
mt = meshtags(mesh, mesh.topology.dim - 1, facets[arg_sort], np.full(len(facets), axis+1, dtype=np.int32))
mpc.create_periodic_constraint_topological(V, mt, axis+1, create_periodic_map(axis), bcs)
mpc.finalize()
u = Function(mpc.function_space, name="Solution_u")
x = SpatialCoordinate(mesh)
f = 1.0
F = inner(grad(u), grad(v)) * dx - inner(f, v) * dx
J = derivative(F, u, TrialFunction(V))
u_ = TrialFunction(V)
a = inner(grad(u_), grad(v)) * dx
L = inner(f, v) * dx
u_soln = -1.0/6.0 * ((x[0]-0.5)**2 + (x[1]-0.5)**2 + (x[2]-0.5)**2)
# Sanity check that the MPC class has some constraints to impose
num_slaves_global = mesh.comm.allreduce(len(mpc.slaves), op=MPI.SUM)
num_masters_global = mesh.comm.allreduce(len(mpc.masters.array), op=MPI.SUM)
assert (not periodic) | ((num_slaves_global > 0) & (num_masters_global > 0))
print(f'Periodicity: {periodic}, Nº slaves: {num_slaves_global}, Nº masters: {num_masters_global}')
tol = np.finfo(u.x.array.dtype).resolution
petsc_options_nonlinear = {
"snes_type": "ksponly",
"ksp_type": "preonly",
"pc_type": "lu",
"snes_atol": tol,
"snes_rtol": tol,
"ksp_error_if_not_converged": True,
"snes_error_if_not_converged": True,
"snes_monitor": None,
petsc_options_linear = {"ksp_type": "preonly", "pc_type": "lu"}
print('LINEAR:')
problem = LinearProblem(a, L, mpc, bcs=bcs, petsc_options=petsc_options_linear)
u_h = problem.solve()
l2_error_local = assemble_scalar(form((u_h - u_soln) ** 2 * dx))
l2_error_global = mesh.comm.allreduce(l2_error_local, op=MPI.SUM)
print(f' - Error L2 local: {l2_error_local}')
print(f' - Error L2 global: {l2_error_global}')
print('NONLINEAR:')
problem = NonlinearProblem(F, u, mpc=mpc, bcs=bcs, J=J, petsc_options=petsc_options_nonlinear)
_, converged, num_iterations = problem.solve()
print(f" - Converged: {converged}, iterations: {num_iterations}")
l2_error_local = assemble_scalar(form((u - u_soln) ** 2 * dx))
if __name__ == "__main__":
celltypes = [CellType.hexahedron, CellType.tetrahedron]
Ne = [8, 12]
for celltype, N in zip(celltypes, Ne):
for periodic in [False, True]:
benchmark_periodic3D(celltype, N, periodic)
print('\n')
And this is the output obtained:
Tolerance: 5e-13, Celltype: CellType.hexahedron, Nº cells: 512
Periodicity: False, Nº slaves: 0, Nº masters: 0
LINEAR:
- Error L2 local: 7.650468866454569e-32
- Error L2 global: 7.650468866454569e-32
NONLINEAR:
0 SNES Function norm 2.837973414409e+00
1 SNES Function norm 5.700934760166e-16
- Converged: 5, iterations: 1
- Error L2 local: 9.398975198597027e-32
- Error L2 global: 9.398975198597027e-32
Periodicity: True, Nº slaves: 768, Nº masters: 768
LINEAR:
- Error L2 local: 3.342374098344129e-05
- Error L2 global: 3.342374098344129e-05
NONLINEAR:
0 SNES Function norm 2.117728887619e+00
1 SNES Function norm 2.236806980910e-01
- Error L2 local: 3.34237409834424e-05
- Error L2 global: 3.34237409834424e-05
Tolerance: 5e-13, Celltype: CellType.tetrahedron, Nº cells: 10368
LINEAR:
- Error L2 local: 1.1490127105419507e-32
- Error L2 global: 1.1490127105419507e-32
NONLINEAR:
0 SNES Function norm 4.230216839918e+00
1 SNES Function norm 3.326986410762e-16
- Error L2 local: 1.3933664178418828e-32
- Error L2 global: 1.3933664178418828e-32
Periodicity: True, Nº slaves: 1728, Nº masters: 1728
LINEAR:
- Error L2 local: 4.449450735450615e-05
- Error L2 global: 4.449450735450615e-05
NONLINEAR:
0 SNES Function norm 3.104222328289e+00
1 SNES Function norm 4.605991868480e-01
- Error L2 local: 4.4494507354511916e-05
- Error L2 global: 4.4494507354511916e-05
As far as I am concerned, the multipointconstraint does not create canonical equations for master-slave relations, but, instead, simplifies the assembled matrix by substituting the slave dofs relations by the master ones and eliminating the slave dofs during computation. Shouldn’t both types of problems (with and without periodicity) be theoretically analogous? And if so, shouldn’t they reach the same level of numerical precision? Am I missing something?
Thank you very much in advance.
EDIT: I was mistaken, I did not take into account the compatibility condition of the source term, i.e., its volume integral should be 0. I was so focused on having a poisson problem with an analytical solution to compare the periodicity performance with, that I totally slipped. Sorry for the silly post ![]()
