NonlinearMPCProblem: error with periodic structure and nonlinear material
I’m been playing around with revising constraining across all axis (ref: Convergence difficulties with 3D periodic BCs - #2 by dokken)
which I’ve applied to your example:
from dolfinx import fem, io, mesh
import petsc4py.PETSc as PETSc
from ufl import grad, ln, tr, det, variable, derivative, TestFunction, TrialFunction
from dolfinx_mpc import NonlinearProblem, MultiPointConstraint
# Mesh Generation
comm = MPI.COMM_WORLD
# Generate simple rectangular mesh
length_plate = 1.0
n_elem = 30
domain = mesh.create_rectangle(
    comm=comm,
    points=((0.0, 0.0), (length_plate, length_plate)),
    n=(n_elem, n_elem),
    cell_type=mesh.CellType.triangle,
dim = domain.topology.dim
# Boundary Conditions and Function Spaces
def bot_left_corner(x):
    return np.logical_and(np.isclose(x[0], 0.0), np.isclose(x[1], 0.0))
# Space for the periodic fluctuation field 'u'
V = fem.functionspace(domain, ("P", 1, (dim,)))
# Fix displacement at bottom-left corner (to remove rigid body motions)
pinned_dofs = fem.locate_dofs_geometrical(V, bot_left_corner)
u_zero = fem.Constant(domain, np.array([0.0, 0.0], dtype=PETSc.ScalarType))
bcs = []  # [fem.dirichletbc(u_zero, pinned_dofs, V)]
# Initialize MultiPointConstraint
tol = 1e-10
def PeriodicBoundary(axis):
    Full surface minus dofs constrained by BCs
    def complicated_mpc(x):
        condition = np.isclose(x[axis], length_plate, atol=tol)
        if axis == 0:
            return condition
        elif axis == 1:
                condition, np.logical_and(x[0] > tol, x[0] < length_plate - tol)
        elif axis == 2:
                condition,
                np.logical_and(
                    np.logical_and(x[0] > tol, x[0] < length_plate - tol),
                    np.logical_and(x[1] > tol, x[1] < length_plate - tol),
            raise RuntimeError("Axis should be 0, 1, or 2")
    return complicated_mpc
def create_periodic_map(axis):
    def periodic_relation(x):
        out_x = x.copy()
        out_x[axis] = 0
        return out_x
    return periodic_relation
mpc = MultiPointConstraint(V)
for axis in range(2):
    mpc.create_periodic_constraint_geometrical(
        V, PeriodicBoundary(axis), create_periodic_map(axis), bcs, tol=1e-10
mpc.finalize()
# Variational Formulation (Fluctuation Method)
V_mpc = mpc.function_space
u = fem.Function(V_mpc, name="Fluctuation")
# Macroscopic Deformation Gradient
F_macro_data = np.array([[1.0, 0.0], [0.0, 1.0]], dtype=PETSc.ScalarType)
F_macro = fem.Constant(domain, F_macro_data)
# Kinematics: Total F = F_macro + grad(u_fluctuation)
F = variable(F_macro + grad(u))
# Material Properties
E_1 = 20.0
nu_1 = 0.3
mu_1_val = E_1 / (2 * (1 + nu_1))
lmbda_1_val = E_1 * nu_1 / ((1 + nu_1) * (1 - 2 * nu_1))
# Strain Energy Density Function (Neo-Hookean)
C = F.T * F
I1 = tr(C)
J = det(F)
psi = (mu_1_val / 2) * (I1 - 3 - 2 * ln(J)) + (lmbda_1_val / 2) * (J - 1) ** 2
# Total Potential Energy
dx = ufl.Measure("dx", domain=domain)
E_pot = psi * dx
# Derivatives
du = TrialFunction(V)
Residual = derivative(E_pot, u, v)
Jacobian = derivative(Residual, u, du)
# Problem Setup
problem = NonlinearProblem(
    Residual,
    u,
    mpc,
    bcs=bcs,
    J=Jacobian,
    petsc_options={
        "snes_monitor": None,
        "ksp_type": "preonly",
        "pc_type": "lu",
        "pc_factor_mat_solver_type": "mumps",
        "mat_mumps_icntl_24": 1,
        "mat_mumps_icntl_25": 0,
        "snes_type": "newtonls",
        "snes_linesearch_type": "none",
        "snes_rtol": 1e-8,
        "snes_atol": 1e-10,
        "snes_max_it": 50,
solver = problem.solver
# specific solvers omitted from MWE - they appear to give the same issues as default
# Simulation Loop and Output
# Aux space for visualization of total displacement
W = fem.functionspace(domain, ("P", 1, (dim,)))
u_total_vis = fem.Function(W, name="Total_Displacement")
x_coords = fem.Function(W)
x_coords.interpolate(lambda x: x[:2])  # Capture reference coords
# Output file
out_file = "MWE_output.xdmf"
with io.XDMFFile(domain.comm, out_file, "w") as xdmf:
    xdmf.write_mesh(domain)
    for n, eps in enumerate(np.linspace(0, 0.4, 21)):
        if n == 0:
            continue
        # Update Macroscopic Gradient (Uniaxial Compression in Y)
        current_F_macro = np.array(
            [[1.0, 0.0], [0.0, 1.0 - eps]], dtype=PETSc.ScalarType
        F_macro.value[:] = current_F_macro
        print(f"Step {n}: eps = {eps:.4f}")
        # Solve the nonlinear problem
        u_mpc, converged, iters = problem.solve()
        if converged > 0:
            print(f"Converged reason: {converged} in {iters} iterations.")
            print(f"Failed to converge. Reason: {converged}, after {iters} iterations.")
        # Update ghost values
        u.x.scatter_forward()
        # Reconstruct Total Displacement: u_total = u_fluc + (F_macro - I) * X
        F_minus_I = current_F_macro - np.eye(2)
        x_array = x_coords.x.array.reshape((-1, 2))
        affine_disp = x_array @ F_minus_I.T
        u_total_vis.x.array[:] = u.x.array + affine_disp.flatten()
        # Save to file
        xdmf.write_function(u_total_vis, n)
which yields a solution for every step and the final solution
which looks better, but something weird (although periodic) happens at the corners. I don’t have more time to look at this atm.
