Convergence difficulties with 3D periodic BCs
There are several issues in this code.
  1. Trying to use an MPC to map to a DirichletBC:
If the solution is periodic, there should be no DirichletBC, i.e.
    def dirichlet_boundary_periodic(
        x: NDArray[Union[np.float32, np.float64]],
    ) -> NDArray[np.bool_]:
        return np.full_like(x[0], False, dtype=bool)
You need to be careful with the edge mappings. I attach a code that produces a sensible (and consistent) formulation:
from __future__ import annotations
from typing import Union
import dolfinx.fem as fem
from dolfinx import default_scalar_type, plot
from dolfinx.common import Timer
from dolfinx.fem import Function, assemble_scalar, form
from dolfinx.mesh import (
    CellType,
    create_unit_cube,
    locate_entities_boundary,
    meshtags,
    exterior_facet_indices,
from numpy.typing import NDArray
from ufl import (
    SpatialCoordinate,
    TestFunction,
    TrialFunction,
    derivative,
    dx,
    grad,
    inner,
    cos,
    sin,
    pi,
    div,
from dolfinx_mpc import NonlinearProblem, LinearProblem, MultiPointConstraint
def benchmark_periodic3D(celltype: CellType, N: int, periodic: bool):
    # Create mesh and finite element
    mesh = create_unit_cube(MPI.COMM_WORLD, N, N, N, celltype)
    tdim = mesh.topology.dim
    V = fem.functionspace(mesh, ("Lagrange", 2))
    tol = float(5e1 * np.finfo(default_scalar_type).resolution)
    print(
        f"\nTolerance: {tol}, Celltype: {celltype}, Nº cells: {mesh.topology.index_map(mesh.topology.dim).size_local}"
    def dirichlet_boundary_total(
        return np.logical_or(
            np.logical_or(
                np.logical_or(
                    np.isclose(x[0], 0.0, atol=tol), np.isclose(x[0], 1.0, atol=tol)
                np.logical_or(
                    np.isclose(x[1], 0.0, atol=tol), np.isclose(x[1], 1.0, atol=tol)
            np.logical_or(
                np.isclose(x[2], 0.0, atol=tol), np.isclose(x[2], 1.0, atol=tol)
    # Create Dirichlet boundary condition
    def u_ex(x):
        return (
            np.cos(2 * np.pi * x[0])
            * np.cos(4 * np.pi * x[1])
            * np.cos(2 * np.pi * x[2])
    u_L = Function(V)
    u_L.interpolate(u_ex)
    dirichletboundary = (
        dirichlet_boundary_periodic if periodic else dirichlet_boundary_total
    geometrical_dofs = fem.locate_dofs_geometrical(V, dirichletboundary)
    bc = fem.dirichletbc(u_L, geometrical_dofs)  # , V)
    bcs = [bc]
    print(f"Nº Dirichlet dofs: {len(geometrical_dofs)}")
    def PeriodicBoundary(axis):
        Full surface minus dofs constrained by BCs
        def complicated_mpc(x):
            condition = np.isclose(x[axis], 1.0, atol=tol)
            if axis == 0:
                return condition
            elif axis == 1:
                return np.logical_and(
                    condition, np.logical_and(x[0] > tol, x[0] < 1.0 - tol)
            elif axis == 2:
                    condition,
                    np.logical_and(
                        np.logical_and(x[0] > tol, x[0] < 1.0 - tol),
                        np.logical_and(x[1] > tol, x[1] < 1.0 - tol),
                raise RuntimeError("Axis should be 0, 1, or 2")
        return complicated_mpc
    def create_periodic_map(axis):
        def periodic_relation(x):
            out_x = x.copy()
            out_x[axis] = 0
            return out_x
        return periodic_relation
    with Timer("~~Periodic: Compute mpc condition"):
        mpc = MultiPointConstraint(V)
        for axis in range(3):
            mpc.create_periodic_constraint_geometrical(
                V, PeriodicBoundary(axis), create_periodic_map(axis), bcs, tol=tol
        mpc.finalize()
    # Define variational problem
    u = Function(mpc.function_space, name="Solution_u")
    x = SpatialCoordinate(mesh)
    u_soln = cos(2 * pi * x[0]) * cos(4 * pi * x[1]) * cos(2 * pi * x[2])
    f = -div(grad(u_soln))
    F = inner(grad(u), grad(v)) * dx - inner(f, v) * dx
    u_ = TrialFunction(V)
    a = inner(grad(u_), grad(v)) * dx
    L = inner(f, v) * dx
    # Sanity check that the MPC class has some constraints to impose
    num_slaves_global = mesh.comm.allreduce(len(mpc.slaves), op=MPI.SUM)
    num_masters_global = mesh.comm.allreduce(len(mpc.masters.array), op=MPI.SUM)
    assert (not periodic) | ((num_slaves_global > 0) & (num_masters_global > 0))
    print(
        f"Periodicity: {periodic}, Nº slaves: {num_slaves_global}, Nº masters: {num_masters_global}"
    tol = np.finfo(u.x.array.dtype).resolution
    petsc_options_nonlinear = {
        "snes_type": "ksponly",
        "ksp_type": "preonly",
        "pc_type": "lu",
        "pc_factor_mat_solver_type": "mumps",
        "snes_atol": tol,
        "snes_rtol": tol,
        "ksp_error_if_not_converged": True,
        "snes_error_if_not_converged": True,
        "snes_monitor": None,
    petsc_options_linear = {
        "mat_mumps_icntl_24": 1,
        "mat_mumps_icntl_25": 0,
        "pc_type": "lu",
    problem = LinearProblem(a, L, mpc, bcs=bcs, petsc_options=petsc_options_linear)
    u_h = problem.solve()
    u_avg_analytical = mesh.comm.allreduce(
        assemble_scalar(form(u_soln * dx)), op=MPI.SUM
    u_avg = mesh.comm.allreduce(assemble_scalar(form(u_h * dx)), op=MPI.SUM)
    u_h.x.array[:] -= u_avg - u_avg_analytical
    with dolfinx.io.VTXWriter(
        mesh.comm, f"linear_mpc_{periodic=}_{N}_3D.bp", [u_h]
    ) as writer:
        writer.write(0.0)
    l2_error_local = assemble_scalar(form((u_h - u_soln) ** 2 * dx))
    l2_error_global = mesh.comm.allreduce(l2_error_local, op=MPI.SUM)
    print(f" - Error L2 local: {l2_error_local}")
    print(f" - Error L2 global: {l2_error_global}")
    print("NONLINEAR:")
    J = derivative(F, u, TrialFunction(V))
    problem = NonlinearProblem(
        F, u, mpc=mpc, bcs=bcs, J=J, petsc_options=petsc_options_nonlinear
    _, converged, num_iterations = problem.solve()
    print(f" - Converged: {converged}, iterations: {num_iterations}")
    l2_error_local = assemble_scalar(form((u - u_soln) ** 2 * dx))
        mesh.comm, f"nonlinear_mpc_{periodic=}_{N}_3D.bp", [u]
    ) as writer:
        writer.write(0.0)
if __name__ == "__main__":
    celltypes = [CellType.tetrahedron, CellType.hexahedron]
    Ne = [5, 10, 20]
    for celltype, N in zip(celltypes, Ne):
        for periodic in [True, False]:
            benchmark_periodic3D(celltype, N, periodic)
    print("\n")
