I’m trying to solve non-lineal Poisson’s equation with Dirichlet boundary conditions and what can be understood as two spherical sources. I am basically interested in the derivative of the solution. This is a simpler version of my code:
from numpy.random import random
# Sub domain for Dirichlet boundary condition. It is a boolean function
def boundary_boolean_function(x, on_boundary):
return on_boundary
PARAMETERS
Lam = 1.
mass = 20.
rs = 0.6 # Radius of the source
mpl = 1.
G = 1.0
m_ = mass * 4./3. * np.pi * rs**3
rstar = 1/Lam * (G * m_/(4 * np.pi * mpl))**0.5
# Function to deffine a mesh that follows a certain function
def symmetric_mesh3d(Nx, Ny, Nz, rstar):
# Create a cubic mesh
xmax = 11.
m = BoxMesh(Point(-xmax, -xmax, -xmax), Point(xmax, xmax, xmax), Nx, Ny, Nz)
x = m.coordinates()
# Modify the coordinates as desired
for i in range(len(x)):
if x[i, 0] != 0:
x [i, 0] = x [i, 0]
if x[i, 1] != 0:
x [i, 1] = x [i, 1]
if x[i, 2] != 0:
x [i, 2] = x [i, 2]
return m
# Define the mesh that we are going to use
mesh = symmetric_mesh3d(19, 19, 19, 6.) # The mesh should be more refined near the radius of the source
V = FunctionSpace(mesh, "CG", 2) # Second order: we should get goood results up to the first derivative.
# Define boundary condition
g = Constant(1.) # Impose that the field has a constant value in the limits
bc = DirichletBC(V, g, boundary_boolean_function)
# Initial guess
u = interpolate(Constant(-1.), V)
f = Expression("-20.*(sqrt(pow(x[1] - 1.05, 2) + pow(x[0], 2) + pow(x[2], 2)) < 0.6) - 20.*(sqrt(pow(x[1] + 1.05, 2) + pow(x[0], 2) + pow(x[2], 2)) < 0.6)", degree=2) # Density
F = inner((1./sqrt(1 + Lam**(-4)*inner(grad(u),grad(u))/2))*grad(u), grad(v))*dx - f*v*dx
# Compute solution
M = u * dx
du = TrialFunction(V)
J = derivative(F, u, du) # Jacobian
solve(F == 0, u, bc, J=J,
solver_parameters = {
"newton_solver": {
"linear_solver": "gmres",
"preconditioner": "ilu",
"relative_tolerance": 1e-6,
"absolute_tolerance": 1e-6
# Print a 2d slice of the solution
z = 0.0
N = 101
v_slice = np.zeros((N, N), dtype = "float")
xsol = np.zeros(N, dtype = "float")
x = mesh.coordinates()
for i in np.arange(N):
for j in np.arange(N):
x0 = -x[len(x)-1, 1] + 2 * x[len(x)-1, 1]/N*i
y0 = -x[len(x)-1, 1] + 2 * x[len(x)-1, 1]/N*j
v_slice[i, j] = u(x0, y0, z)
plt.figure()
plt.imshow(v_slice)
plt.colorbar()
plt.figure()
plt.plot(v_slice[:, int(N/2)])
# Derivative
vectorsol = np.zeros(N, dtype = "float")
z = - x[len(x)-1, 1] + 2 * x[len(x)-1, 0]/N*i # We start in 0 (center of the mesh)
vectorsol[i] = u(z, 0., 0.)
xsol[i] = z
vector_mod = vectorsol/(Lam**2)
r_mod = xsol
# PLOT THE DERIVATIVE (this is the important one)
der = np.zeros((N-1, N-1), dtype = "float")
h = 2 * x[len(x)-1, 1]/N
for i in np.arange(1, N-1):
for j in np.arange(1, N-1):
x0 = -x[len(x)-1, 1] + h*i
y0 = -x[len(x)-1, 1] + h*j
derx = (v_slice[i+1, j] - v_slice[i-1, j]) / (2 * h) # This is a first order method. I should probably improve it
dery = (v_slice[i, j+1] - v_slice[i, j-1])/ (2 * h)
derz = ( u(x0, y0, h) - u(x0, y0, -h) )/(2*h) # Second order method
der[i, j] = derx ** 2 + dery ** 2 + derz ** 2
#der[i, j] = dery**2
plt.figure()
plt.title('X')
plt.imshow(der)
plt.colorbar()
# Plot X in one axis
mind = int((N - 1)/2)
X_x = np.zeros((N-1), dtype = "float")
for i in np.arange(N-1):
X_x[i] = der[mind, i]
plt.figure()
plt.title('X along the axis that connects the masses')
plt.yscale("log")
plt.plot(X_x[1:])
As far as I’ve been able to notice, the implementation does not seem wrong. However, I am facing multiple convergence problems. First of all, if I increase the number of elements in the mesh by as little as 1 or 2, the code fails to coverge. This is a big problem, as a bigger number of elements would be, in principle, needed in order to properly deffine the matter distribution. Another issue is that a change in the number of elements seems to change the value of the derivative of the solution by even two orders of magnitude. I have reviewed the code over a thousand times and played endlessly with the parameters, but I haven’t been able to come to a solution to this problem.
Is my approach breaking down somewhere? What can I do in this situation?
Thank you so much! ![]()
