Hi fenics experts!
I would like to be able to have sympy expressions to define source terms to go into the variational formulation
There used to be a way around this in legacy fenics by doing the following:
Expression(sp.printing.ccode(sympy_expression), t=0, degree=2)
Is there an equivalent workaround in fenicsx since the depreciation of the expression function?
I have attached an example code of what I would like to be able to do.
import sympy as sp
from dolfinx.mesh import create_rectangle
from dolfinx.fem import (
Constant,
Function,
FunctionSpace,
from dolfinx.fem.petsc import (
NonlinearProblem,
mesh = create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])], [10, 10])
V = FunctionSpace(mesh, ufl.FiniteElement("CG", mesh.ufl_cell(), 1))
xx = sp.Symbol("x[0]")
source_1 = 2 * sp.exp(2 * xx)
source_2 = (
sp.Piecewise(
(2 * xx, xx < 0.5),
(3 * xx, True),
F = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
F += source_1 * v * ufl.dx
F += source_2 * v * ufl.dx
problem = NonlinearProblem(F, u, bcs=[])
solver.solve(u)
