Hello I have attached my .geo file here. I am trying to convert it to.xml I have tried with meshio but I am having issues downloading it. When I convert using dolfin-convert it does not give me the facets file I am confused as to what is wrong with my geo file.
// This code was created by pygmsh vunknown.
// All Points
p0 = newp;
Point(p0) = {-2261002.53339, 1275842.660948, 0.0, 10000.0};
p1 = newp;
Point(p1) = {-2253336.148649, 1273981.20777, 0.0, 10000.0};
p2 = newp;
Point(p2) = {-2244510.135135, 1269800.464527, 0.0, 10000.0};
p3 = newp;
Point(p3) = {-2236845.439189, 1264690.66723, 0.0, 10000.0};
p4 = newp;
Point(p4) = {-2231735.641892, 1262368.032095, 0.0, 10000.0};
p5 = newp;
Point(p5) = {-2228251.689189, 1262368.032095, 0.0, 10000.0};
p6 = newp;
Point(p6) = {-2222445.101351, 1263761.613176, 0.0, 10000.0};
p7 = newp;
Point(p7) = {-2218496.621622, 1264690.66723, 0.0, 10000.0};
p8 = newp;
Point(p8) = {-2214083.614865, 1265155.194257, 0.0, 10000.0};
p9 = newp;
Point(p9) = {-2212690.033784, 1264458.403716, 0.0, 10000.0};
p10 = newp;
Point(p10) = {-2211296.452703, 1260974.451014, 0.0, 10000.0};
p11 = newp;
Point(p11) = {-2209670.608108, 1255167.863176, 0.0, 10000.0};
p12 = newp;
Point(p12) = {-2209438.344595, 1249825.802365, 0.0, 10000.0};
p13 = newp;
Point(p13) = {-2207812.5, 1241696.579392, 0.0, 10000.0};
p14 = newp;
Point(p14) = {-2205141.469595, 1237457.77027, 0.0, 10000.0};
p15 = newp;
Point(p15) = {-2203980.152027, 1234206.081081, 0.0, 10000.0};
p16 = newp;
Point(p16) = {-2203399.493243, 1228922.086149, 0.0, 10000.0};
p17 = newp;
Point(p17) = {-2202354.307432, 1224857.474662, 0.0, 10000.0};
p18 = newp;
Point(p18) = {-2200496.199324, 1222883.234797, 0.0, 10000.0};
p19 = newp;
Point(p19) = {-2197360.641892, 1220792.863176, 0.0, 10000.0};
p20 = newp;
Point(p20) = {-2190973.39527, 1217134.712838, 0.0, 10000.0};
p21 = newp;
Point(p21) = {-2186095.861486, 1213302.364865, 0.0, 10000.0};
p22 = newp;
Point(p22) = {-2179824.746622, 1209121.621622, 0.0, 10000.0};
p23 = newp;
Point(p23) = {-2176108.530405, 1208076.435811, 0.0, 10000.0};
p24 = newp;
Point(p24) = {-2173089.10473, 1208889.358108, 0.0, 10000.0};
p25 = newp;
Point(p25) = {-2167747.043919, 1208657.094595, 0.0, 10000.0};
p26 = newp;
Point(p26) = {-2161961.376659, 1205977.444836, 0.0, 10000.0};
p27 = newp;
Point(p27) = {-2158467.233761, 1202414.789332, 0.0, 10000.0};
p28 = newp;
Point(p28) = {-2155795.242133, 1199400.234675, 0.0, 10000.0};
p29 = newp;
Point(p29) = {-2152301.099235, 1195974.604383, 0.0, 10000.0};
p30 = newp;
Point(p30) = {-2148669.931126, 1192823.024515, 0.0, 10000.0};
p31 = newp;
Point(p31) = {-2143291.691568, 1191178.721974, 0.0, 10000.0};
p32 = newp;
// Outside Rectangle
p515 = newp;
Point(p515) = {-2600000, 765000, 0.0, 10000.0};
p516 = newp;
Point(p516) = {-2600000, 1500000, 0.0, 10000.0};
p517 = newp;
Point(p517) = {900000, 1500000, 0.0, 10000.0};
p518 = newp;
Point(p518) = {900000, 765000, 0.0, 10000.0};
// Some Lines Start
l0 = newl;
Line(l0) = {p0, p1};
l1 = newl;
Line(l1) = {p1, p2};
l2 = newl;
Line(l2) = {p2, p3};
l3 = newl;
Line(l3) = {p3, p4};
l4 = newl;
Line(l4) = {p4, p5};
l5 = newl;
Line(l5) = {p5, p6};
l6 = newl;
Line(l6) = {p6, p7};
l7 = newl;
Physical Line(1) = {l0, l1, l2, l3, l4, l5, l6, l7, l8, l9, l10, l11, l12, l13, l14, l15, l16, l17, l18, l19, l20, l21, l22, l23, l24, l25, l26, l27, l28, l29, l30, l31, l32, l33, l34, l35, l36, l37, l38, l39, l40, l41, l42, l43, l44, l45, l46, l47, l48, l49, l50, l51, l52, l53, l54, l55, l56, l57, l58, l59, l60};
Physical Line(3) = {l75, l76, l77, l78, l79, l80, l81, l82, l83, l84, l85, l86, l87, l88, l89};
Physical Line(4) = {l90, l91, l92, l93, l94, l95, l96, l97, l98, l99, l100, l101, l102, l103, l104, l105, l106, l107, l108, l109, l110, l111, l112, l113, l114, l115, l116, l117};
Physical Line(5) = {l118, l119, l120, l121, l122, l123, l124, l125, l126, l127, l128, l129, l130, l131, l132, l133, l134, l135, l136, l137, l138, l139, l140, l141, l142, l143, l144, l145, l146, l147, l148, l149, l150, l151, l152, l153, l154, l155, l156, l157, l158, l159, l160, l161, l162, l163, l164, l165, l166, l167, l168, l169, l170, l171, l172, l173, l174, l175, l176, l177, l178, l179, l180, l181, l182, l183, l184, l185, l186, l187, l188, l189, l190, l191, l192, l193, l194, l195, l196, l197, l198, l199, l200, l201, l202, l203, l204, l205, l206, l207, l208, l209, l210, l211, l212, l213, l214, l215, l216, l217, l218, l219, l220, l221, l222, l223, l224, l225, l226, l227, l228, l229, l230, l231, l232, l233, l234, l235, l236, l237, l238, l239, l240, l241, l242, l243, l244, l245, l246, l247, l248, l249, l250, l251, l252, l253, l254, l255, l256, l257, l258, l259, l260, l261, l262, l263, l264, l265, l266, l267, l268, l269, l270, l271, l272, l273, l274, l275, l276, l277, l278, l279, l280, l281, l282, l283, l284, l285, l286, l287, l288, l289, l290, l291, l292, l293, l294, l295, l296, l297, l298, l299, l300, l301, l302, l303, l304, l305, l306, l307, l308, l309, l310, l311, l312, l313, l314, l315, l316, l317, l318, l319, l320, l321, l322, l323, l324, l325, l326, l327, l328, l329, l330, l331, l332, l333, l334, l335, l336, l337, l338, l339, l340, l341, l342, l343, l344, l345, l346, l347, l348, l349, l350, l351, l352, l353, l354, l355, l356, l357, l358, l359, l360, l361, l362, l363, l364, l365, l366, l367, l368, l369, l370, l371, l372, l373, l374, l375, l376, l377, l378, l379, l380, l381, l382, l383, l384, l385, l386, l387, l388, l389, l390, l391, l392, l393, l394, l395, l396, l397, l398, l399, l400, l401, l402, l403, l404, l405, l406, l407, l408, l409, l410, l411, l412, l413, l414, l415, l416};
Physical Line(6) = {l417, l418, l419, l420, l421, l422, l423, l424, l425, l426, l427, l428, l429, l430, l431, l432, l433, l434, l435, l436, l437, l438, l439};
ll0 = newll;
Line Loop(ll0) = {l0, l1, l2, l3, l4, l5, l6, l7, l8, l9, l10, l11, l12, l13, l14, l15, l16, l17, l18, l19, l20, l21, l22, l23, l24, l25, l26, l27, l28, l29, l30, l31, l32, l33, l34, l35, l36, l37, l38, l39, l40, l41, l42, l43, l44, l45, l46, l47, l48, l49, l50, l51, l52, l53, l54, l55, l56, l57, l58, l59, l60, l61, l62, l63, l64, l65, l66, l67, l68, l69, l70, l71, l72, l73, l74, l75, l76, l77, l78, l79, l80, l81, l82, l83, l84, l85, l86, l87, l88, l89, l90, l91, l92, l93, l94, l95, l96, l97, l98, l99, l100, l101, l102, l103, l104, l105, l106, l107, l108, l109, l110, l111, l112, l113, l114, l115, l116, l117, l118, l119, l120, l121, l122, l123, l124, l125, l126, l127, l128, l129, l130, l131, l132, l133, l134, l135, l136, l137, l138, l139, l140, l141, l142, l143, l144, l145, l146, l147, l148, l149, l150, l151, l152, l153, l154, l155, l156, l157, l158, l159, l160, l161, l162, l163, l164, l165, l166, l167, l168, l169, l170, l171, l172, l173, l174, l175, l176, l177, l178, l179, l180, l181, l182, l183, l184, l185, l186, l187, l188, l189, l190, l191, l192, l193, l194, l195, l196, l197, l198, l199, l200, l201, l202, l203, l204, l205, l206, l207, l208, l209, l210, l211, l212, l213, l214, l215, l216, l217, l218, l219, l220, l221, l222, l223, l224, l225, l226, l227, l228, l229, l230, l231, l232, l233, l234, l235, l236, l237, l238, l239, l240, l241, l242, l243, l244, l245, l246, l247, l248, l249, l250, l251, l252, l253, l254, l255, l256, l257, l258, l259, l260, l261, l262, l263, l264, l265, l266, l267, l268, l269, l270, l271, l272, l273, l274, l275, l276, l277, l278, l279, l280, l281, l282, l283, l284, l285, l286, l287, l288, l289, l290, l291, l292, l293, l294, l295, l296, l297, l298, l299, l300, l301, l302, l303, l304, l305, l306, l307, l308, l309, l310, l311, l312, l313, l314, l315, l316, l317, l318, l319, l320, l321, l322, l323, l324, l325, l326, l327, l328, l329, l330, l331, l332, l333, l334, l335, l336, l337, l338, l339, l340, l341, l342, l343, l344, l345, l346, l347, l348, l349, l350, l351, l352, l353, l354, l355, l356, l357, l358, l359, l360, l361, l362, l363, l364, l365, l366, l367, l368, l369, l370, l371, l372, l373, l374, l375, l376, l377, l378, l379, l380, l381, l382, l383, l384, l385, l386, l387, l388, l389, l390, l391, l392, l393, l394, l395, l396, l397, l398, l399, l400, l401, l402, l403, l404, l405, l406, l407, l408, l409, l410, l411, l412, l413, l414, l415, l416, l417, l418, l419, l420, l421, l422, l423, l424, l425, l426, l427, l428, l429, l430, l431, l432, l433, l434, l435, l436, l437, l438, l439};
Physical Line(7) = {l440, l441, l442, l443, l444, l445, l446, l447, l448, l449, l450, l451, l452, l453, l454, l455, l456, l457, l458, l459, l460, l461, l462, l463, l464};
ll1 = newll;
Line Loop(ll1) = {l440, l441, l442, l443, l444, l445, l446, l447, l448, l449, l450, l451, l452, l453, l454, l455, l456, l457, l458, l459, l460, l461, l462, l463, l464};
Physical Line(8) = {l465, l466, l467, l468, l469, l470, l471, l472, l473, l474, l475, l476, l477, l478, l479, l480, l481, l482, l483, l484, l485, l486, l487, l488, l489, l490, l491, l492, l493, l494};
ll2 = newll;
Line Loop(ll2) = {l465, l466, l467, l468, l469, l470, l471, l472, l473, l474, l475, l476, l477, l478, l479, l480, l481, l482, l483, l484, l485, l486, l487, l488, l489, l490, l491, l492, l493, l494};
Physical Line(9) = {l495, l496, l497, l498, l499, l500, l501, l502, l503, l504, l505, l506, l507, l508, l509, l510, l511, l512, l513, l514};
ll3 = newll;
Line Loop(ll3) = {l495, l496, l497, l498, l499, l500, l501, l502, l503, l504, l505, l506, l507, l508, l509, l510, l511, l512, l513, l514};
// Lines for Rectangle
l515 = newl;
Line(l515) = {p515, p516};
l516 = newl;
Line(l516) = {p516, p517};
l517 = newl;
Line(l517) = {p517, p518};
l518 = newl;
Line(l518) = {p518, p515};
Physical Line(10) = {l515, l516, l517, l518};
ll4 = newll;
Line Loop(ll4) = {l515, l516, l517, l518};
// Combining
s0 = news;
// ll4 - rectangle
Plane Surface(s0) = {ll0,ll1,ll2,ll3,ll4};
//Physical Surface(11) = {s0};
