Hi everyone,
I am new to Fenics/dolfinx and I am struggling to solve a set of coupled equations. Here is a mathematical description of the problem which is the steady state Poisson-Nernst-Planck set of equations with two charged species, with variables to be solved \phi, c_1 and c_2.
(1) \quad -\nabla ^2 \phi = \frac{(c_1 - c_2)}{\varepsilon}
(2) \quad \nabla \cdot \left[ D_1 \nabla c_1 + \frac{D_1z_1q}{kT}c_1\nabla\phi\right] = 0
(3) \quad \nabla \cdot \left[ D_2 \nabla c_2 + \frac{D_2z_2q}{kT}c_2\nabla\phi\right] = 0
Then scaling the variables and simplifying I get,
(1) \quad -\nabla ^2 \bar{\phi} = (\bar{c}_1-\bar{c}_2)
(2) \quad \nabla^2\bar{c}_1 + \nabla\bar{c}_1\cdot \nabla\bar{\phi} +\bar{c}_1\nabla^2\bar{\phi} = 0
(2) \quad \nabla^2\bar{c}_2 + \nabla\bar{c}_2\cdot \nabla\bar{\phi} +\bar{c}_2\nabla^2\bar{\phi} = 0
where the bar represents the adimensional variable.
My first guess at the variational problem formulation is as follows
(1) \quad \int_\Omega \nabla\bar\phi \cdot \nabla v \, dx - \int_{\partial\Omega}\frac{\partial\bar\phi}{\partial n} v \, ds - \int_\Omega (c_1 - c_2) = 0
(2) \quad -\int_\Omega \nabla\bar{c}_1\cdot d_1 \, dx + \int_{\partial\Omega}\frac{\partial\bar{c}_1}{\partial n}d_1 \, ds + \int_\Omega \nabla \bar{c}_1\cdot \nabla\bar\phi \cdot d_1\, dx+ \int_\Omega \bar{c}_1\nabla^2\bar\phi \cdot d_1\, dx = 0
(3) \quad ....
However I am not sure if this is the correct formulation since when I implement it with a mixed element space and a newton solver it reaches the maximum number of iterations without converging.
The problem could still be elsewhere (I upload also the code below) but I thought I started asking for the most basic problem first.
#%% Import statements
from dolfinx.io import gmshio, XDMFFile
from dolfinx import mesh, fem
from dolfinx.fem import functionspace
from dolfinx import default_scalar_type, default_real_type
from dolfinx import geometry as gm
import pyvista
from dolfinx import plot
try:
except ImportError:
print("This demo requires gmsh to be installed")
exit(0)
import dolfinx.fem.petsc
import basix.ufl
#%% Generate mesh
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
#%% Define model
# Create connectivity
tdim = domain.topology.dim
fdim = tdim - 1
element_family = basix.ElementFamily.P
element_degree = 1
variant = basix.LagrangeVariant.equispaced
# Define the element using Basix
el1 = basix.ufl.element(element_family, domain.topology.cell_name(), element_degree, variant)
el2 = basix.ufl.element(element_family, domain.topology.cell_name(), element_degree, variant)
el3 = basix.ufl.element(element_family, domain.topology.cell_name(), element_degree, variant)
mel = basix.ufl.mixed_element(([el1, el2, el3]))
Z = fem.functionspace(domain, mel)
V = fem.functionspace(domain, ("Lagrange", 1))
C1 = fem.functionspace(domain, ("Lagrange", 1))
C2 = fem.functionspace(domain, ("Lagrange", 1))
# Define test functions
(v, d1, d2) = ufl.TestFunction(Z)
u = fem.Function(Z)
# Split mixed functions
phi, c1, c2 = ufl.split(u)
phi0, c10, c20 = ufl.split(u0)
# Zero u
u.x.array[:] = 0.0
# Variational formulation
F1 = ufl.inner(ufl.grad(phi), ufl.grad(v)) * ufl.dx - ufl.inner(c1-c2, v) * ufl.dx
F2 = ufl.inner(ufl.grad(c1), ufl.grad(d1)) * ufl.dx - ufl.inner(ufl.inner(ufl.grad(c1), ufl.grad(phi)), d1) * ufl.dx - ufl.inner(c1*ufl.div(ufl.grad(phi)), d1)*ufl.dx
F3 = ufl.inner(ufl.grad(c2), ufl.grad(d2)) * ufl.dx - ufl.inner(ufl.inner(ufl.grad(c2), ufl.grad(phi)), d2) * ufl.dx - ufl.inner(c2*ufl.div(ufl.grad(phi)), d2)*ufl.dx
F = F1 + F2 + F3
# %% SET BOUNDARY CONDITIONS
def bulk(x):
return np.isclose(x[0], 0)
def surface(x):
return np.isclose(x[0], 1)
def sides(x):
return np.logical_or(np.isclose(x[1], 0), np.isclose(x[1], 1))
def zerofunction(x):
return 0*x[0]
def onefunction(x):
return 1+0*x[0]
boundaries = [(1, bulk),
(2, surface),
(3, sides)]
facets = mesh.locate_entities(domain, fdim, locator)
facet_indices.append(facets)
facet_tag = mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tag)
class BoundaryCondition():
def __init__(self, type, marker, values, space, testfunction):
self._type = type
if type == "Dirichlet":
u_D = fem.Function(V)
u_D.interpolate(values)
facets = facet_tag.find(marker)
dofs = fem.locate_dofs_topological(space, fdim, facets)
self._bc = fem.dirichletbc(u_D, dofs)
elif type == "Neumann":
self._bc = ufl.inner(values, testfunction) * ds(marker)
elif type == "Robin":
self._bc = values[0] * ufl.inner(u-values[1], testfunction)* ds(marker)
raise TypeError("Unknown boundary condition: {0:s}".format(type))
@property
def bc(self):
return self._bc
@property
def type(self):
return self._type
# Define the Dirichlet conditions
zero_bulk_potential = zerofunction
applied_potential = onefunction
bulk_concentration = onefunction
# Define the Neumann conditions
noflux1 = fem.Function(C1)
noflux1.interpolate(zerofunction)
noflux2 = fem.Function(C2)
noflux2.interpolate(zerofunction)
no_charge = fem.Function(V)
no_charge.interpolate(zerofunction)
# Define boundary conditions
boundary_conditions = [BoundaryCondition("Dirichlet", 1, zero_bulk_potential, V, v),
BoundaryCondition("Dirichlet", 2, applied_potential, V, v),
BoundaryCondition("Dirichlet", 1, bulk_concentration, C1, d1),
BoundaryCondition("Dirichlet", 1, bulk_concentration, C2, d2),
BoundaryCondition("Neumann", 3, no_charge, V, v),
BoundaryCondition("Neumann", 3, noflux1, C1, d1),
BoundaryCondition("Neumann", 3, noflux2, C2, d2),
BoundaryCondition("Neumann", 2, noflux1, C1, d1),
BoundaryCondition("Neumann", 2, noflux2, C2, d2)
bcs = []
for condition in boundary_conditions:
if condition.type == "Dirichlet":
bcs.append(condition.bc)
F -= condition.bc
# %%Create nonlinear problem and Newton solver
problem = NonlinearProblem(F, u, bcs=bcs)
solver.rtol = np.sqrt(np.finfo(default_real_type).eps) * 1e-2
solver.max_it = 200
# We can customize the linear solver used inside the NewtonSolver by
# modifying the PETSc options
ksp = solver.krylov_solver
opts = PETSc.Options() # type: ignore
sys = PETSc.Sys() # type: ignore
# For factorisation prefer superlu_dist, then MUMPS, then default
if sys.hasExternalPackage("superlu_dist"):
opts[f"{option_prefix}pc_factor_mat_solver_type"] = "superlu_dist"
elif sys.hasExternalPackage("mumps"):
ksp.setFromOptions()
solver.solve(u)
Thank you in advance
