PETSc problem when solving mixed 3D nonlinear variational problem
We are using fenics for solving the equations below (which describes the electric field inside a pn junction):
\mathrm{\nabla}^2U=\frac{-e_0}{\varepsilon\varepsilon_0}\left(N_D-N_A+p-n\right)
-\frac{k_BT}{e_0}\nabla^2n+\nabla n\cdot \nabla U = 0
\frac{k_BT}{e_0}\nabla^2p+\nabla p\cdot \nabla U = 0
But we encountered an error which said:
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F’.
Newton iteration 0: r (abs) = 7.736e+07 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
RuntimeError:
*** Error: Unable to successfully call PETSc function ‘MatSetValuesLocal’.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside ./dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** Git changeset: unknown
Here is the minimal executable code:
import fenics
e0 = 1.60217733e-19
perm_mat = 11.7
perm0 = 8.854187817e-12   #F/m
kboltz=8.617385e-5 #eV/K
u_T = kboltz * 300/1 # u_T = kT/q
n_i = 6.95e-3 #Silicon, um^-3
mesh3D = fenics.BoxMesh(fenics.Point(0, 0, 0),
                        fenics.Point(1300, 1300, 55),
                        5, 5, 2000)
P1 = fenics.FiniteElement('P', fenics.tetrahedron, 1)
element = fenics.MixedElement([P1, P1, P1])
V = fenics.FunctionSpace(mesh3D, element)
funcs = fenics.Function(V)
u, p, n = fenics.split(funcs) # Electric Potential, Electron Density, Hole Density
v_u, v_p, v_n = fenics.TestFunctions(V)
Neff = fenics.Expression("x[2] < 1 - tol? 1e6 : (x[2] < 2 - tol ? -5 : (x[2] < 3 + tol ? -1.917e4 : (x[2] < 53 + tol ? -5 : -1e6)))", degree = 0, tol = 1e-14)
Neff_0 = eval("1e6 if (z < 1) else (-5 if (z < 2) else (-1.917e4 if (z < 3) else -5 if (z < 53) else -1e6))".replace("z","0"))
Neff_end = eval("1e6 if (z < 1) else (-5 if (z < 2) else (-1.917e4 if (z < 3) else -5 if (z < 53) else -1e6))".replace("z","55"))
u_D = fenics.Expression('x[2]<tol ? p_1:p_2',
                        degree = 2, tol = 1E-14,
                        p_1 = 200, p_2 = 0)
p_D = fenics.Expression('x[2]<tol ? p_1:p_2',
                        p_1 = 0.5*(-Neff_0 + (Neff_0**2 + 4*n_i**2)**0.5),
                        p_2 = 0.5*(-Neff_end + (Neff_end**2 + 4*n_i**2)**0.5))
n_D = fenics.Expression('x[2]<tol ? p_1:p_2',
                        p_1 = 0.5*(Neff_0 + (Neff_0**2 + 4*n_i**2)**0.5),
                        p_2 = 0.5*(Neff_end + (Neff_end**2 + 4*n_i**2)**0.5))
def boundary(x, on_boundary):
    return abs(x[2])<1e-14 or abs(x[2]-55)<1e-14
u_bc = fenics.DirichletBC(V.sub(0), u_D, boundary)
p_bc = fenics.DirichletBC(V.sub(1), p_D, boundary)
n_bc = fenics.DirichletBC(V.sub(2), n_D, boundary)
g_expression = fenics.Constant(0)
a_u = fenics.dot(fenics.grad(u), fenics.grad(v_u))*fenics.dx
a_p = fenics.dot(fenics.grad(p), fenics.grad(v_p))*u_T*fenics.dx
a_n = fenics.dot(fenics.grad(n), fenics.grad(v_n))*(-u_T)*fenics.dx
L_u = ((Neff+n-p)*1e6*e0/perm0/perm_mat)*v_u*fenics.dx
L_p = (fenics.inner(fenics.grad(u),fenics.grad(p))+g_expression)*v_p*fenics.dx
L_n = (fenics.inner(fenics.grad(u),fenics.grad(n))+g_expression)*v_n*fenics.dx
funcs_ = fenics.Function(V)
fenics.solve(a_u+a_p+a_n - L_u+L_p+L_n == 0 , funcs_, [u_bc, p_bc, n_bc])
You are solving a non-linear problem wrt the variable funcs
And thus should call:
fenics.solve(a_u+a_p+a_n - L_u+L_p+L_n == 0 , funcs, [u_bc, p_bc, n_bc])
Because to solve a non-linear problem, one has to compute the jacobian of your residual, and one has to know what variable should be differented wrt.
Thank you, the Newton iterator works normally after I applied your code by changing the last two lines into
fenics.solve(a_u+a_p+a_n-L_u-L_p-L_n == 0 , funcs, [u_bc, p_bc, n_bc])
(the equation was wrong before), but a new error appeared:
UMFPACK V5.7.9 (Oct 20, 2019): ERROR: out of memory
*** Error: Unable to successfully call PETSc function ‘KSPSolve’.
*** Reason: PETSc error code is: 76 (Error in external library).
*** Where: This error was encountered inside ./dolfin/la/PETScKrylovSolver.cpp.
*** Process: 0
Is this a bug or a math problem that requires me to adjust the conditions of the solver?
Change the underlying solver of your problem (as UMFPACK, the default LU solver is running out of memory). See for instance: UMFPACK error: out of memory despite system having free memory - #2 by plugged
Thank you, and… the solution indeed failed to converge after I changed the solver.
*** Reason: Solution failed to converge in 0 iterations (PETSc reason DIVERGED_PC_FAILED, residual norm ||r|| = -1.000000e+00).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
Note that non-linear solvers should have suitable initial conditions to ensure convergence. Having a Zero initial guess might be too far away from a physical solution.
