Creating a custom PETScSNESSolver
I have a couple of questions.
  • Following the creation of a custom NewtonSolver as described here, is it possible to do a similar setup for a custom PETScSNESSolver.? Peeking at the underlying PETScSNESSolver.cpp I don’t see a solver_setup method (Am I missing anything)?
In that case, would simply instantiating the solver, and setting PETScOptions work ? Is there a minimum snippet in the demos anywhere (I couldn’t find), because
solver = PETScSNESSolver(mesh.mpi_comm(), "default")
# Setting the preconditioner options: ***********************
PETScOptions.set("pc_type", "gamg") # ?
PETScOptions.set("mg_levels_esteig_ksp_type", "cg")
PETScOptions.set("mg_levels_ksp_chebyshev_esteig_steps", 50)
solver.set_from_options()
is different from
snes_solver_parameters = {"linear_solver": "gmres",
                            "preconditioner": "petsc_amg"}
solver.parameters.update(snes_solver_parameters)
  • Isn’t PETSc’s algebraic multigrid referenced as gamg? Is there an alias for preconditioners from PETSc ?
Did you manage to solve this problem?
I am trying to setup a custom PETScSNESSolver where I supply the null space for the linear system. I am able to do this with a NewtonSolver using this code, however I have not managed to convert this to PETScSNESSolver.
Cheers,
K
You could just use petsc4py directly, see Using petsc4py.PETSc.SNES directly - #12 by nate
Indeedn, it is much easier to directly deal with petsc4py.PETSc.SNES directly instead of the wrapper, and that is what I ended up doing.
Thanks for your reply.
Currently within the NewtonSolver code the nullspace is attached in the solver block, but I’m not sure how to insert the nullspace within the snes solver.
NewtonSolver syntax:
class CustomSolver(NewtonSolver):
    def __init__(self, mesh, nullspace):
        NewtonSolver.__init__(self, mesh.mpi_comm(),
                              PETScKrylovSolver(), PETScFactory.instance())
        self.nullspace = nullspace
    def solver_setup(self, A, P, problem, iteration):
        as_backend_type(A).set_nullspace(self.nullspace) # What is the equivalent for the direct SNES code?
        self.linear_solver().set_operator(A)
        self.linear_solver().set_from_options()
Looking at the PETSc documentation I think snes.setDM sets the nullspace, is this correct? If so can you let me know how to convert from dolfin.cpp.la.VectorSpaceBasis (which is how nullspaces are typically constructed in fences) to petsc4py.PETSc.DM as required by the function. I’ve copied the code from Nate’s example and added a nullspace constructor below.
Many thanks,
K
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
Created on Tue Apr 25 07:12:48 2023
               "eliminate_zeros": True, \
               "precompute_ip_const": True}
mesh = UnitCubeMesh(24, 16, 16)
# Mark boundary subdomians
left =  CompiledSubDomain("near(x[0], side) && on_boundary", side = 0.0)
right = CompiledSubDomain("near(x[0], side) && on_boundary", side = 1.0)
# Define Dirichlet boundary (x = 0 or x = 1)
c = Expression(("0.0", "0.0", "0.0"), degree=2)
r = Expression(("scale*0.0",
                "scale*(y0 + (x[1] - y0)*cos(theta) - (x[2] - z0)*sin(theta) - x[1])",
                "scale*(z0 + (x[1] - y0)*sin(theta) + (x[2] - z0)*cos(theta) - x[2])"),
                scale = 0.5, y0 = 0.5, z0 = 0.5, theta = pi/3, degree=2)
def create_nullspace(w, W):
    nullspace_basis = [w.vector().copy() for i in range(3)]
    W.sub(0).dofmap().set(nullspace_basis[0], 1.0)
    W.sub(1).dofmap().set(nullspace_basis[1], 1.0)
    W.sub(2).dofmap().set(nullspace_basis[2], 1.0);
    for x in nullspace_basis:
        x.apply("insert")
    nullspace = VectorSpaceBasis(nullspace_basis)
    nullspace.orthonormalize()
    return nullspace
bcl = DirichletBC(V, c, left)
bcr = DirichletBC(V, r, right)
bcs = [bcl, bcr]
# Define functions
du = TrialFunction(V)            # Incremental displacement
v  = TestFunction(V)             # Test function
u  = Function(V)                 # Displacement from previous iteration
B  = Constant((0.0, -0.5, 0.0))  # Body force per unit volume
T  = Constant((0.1,  0.0, 0.0))  # Traction force on the boundary
# Kinematics
d = u.geometric_dimension()
I = Identity(d)             # Identity tensor
F = I + grad(u)             # Deformation gradient
C = F.T*F                   # Right Cauchy-Green tensor
Ic = tr(C)
J  = det(F)
# Elasticity parameters
E, nu = 10.0, 0.3
mu, lmbda = Constant(E/(2*(1 + nu))), Constant(E*nu/((1 + nu)*(1 - 2*nu)))
psi = (mu/2)*(Ic - 3) - mu*ln(J) + (lmbda/2)*(ln(J))**2
# Total potential energy
Pi = psi*dx - dot(B, u)*dx - dot(T, u)*ds
# Compute first variation of Pi (directional derivative about u in the direction of v)
F = derivative(Pi, u, v)
class SNESProblem():
    def __init__(self, F, u, bcs):
        V = u.function_space()
        self.L = F
        self.a = derivative(F, u, du)
        self.bcs = bcs
        self.u = u
    def F(self, snes, x, F):
        x = PETScVector(x)
        F  = PETScVector(F)
        assemble(self.L, tensor=F)
        for bc in self.bcs:
            bc.apply(F, x)
    def J(self, snes, x, J, P):
        J = PETScMatrix(J)
        assemble(self.a, tensor=J)
        for bc in self.bcs:
            bc.apply(J)
u  = Function(V)
nullspace = create_nullspace(u, V)
print (u.vector()[:])
problem = SNESProblem(F, u, bcs)
import petsc4py, sys
petsc4py.init(sys.argv)
b = PETScVector()  # same as b = PETSc.Vec()
J_mat = PETScMatrix()
snes = PETSc.SNES().create(MPI.comm_world)
snes.setFunction(problem.F, b.vec())
snes.setDM(nullspace) # TypeError: Argument 'dm' has incorrect type (expected petsc4py.PETSc.DM, got dolfin.cpp.la.VectorSpaceBasis)
snes.setJacobian(problem.J, J_mat.mat())
snes.solve(None, problem.u.vector().vec())
# from vtkplotter.dolfin import plot
# plot(u, mode="displace")
