Creating custom anisotropic Lagrange element
Hi all,
I am trying to use Basix for building a custom anisotropic finite element defined, in a rectangle, as product of order 2 elements in the x variable and order 1 elements in the y variable. Specifically, this element will be defined by evaluating Lagrange polynomials on the following points:
o---o---o
o---o---o
We have the following set of polynomials spanned by each element: { 1, y, x, xy, x^2, x^2y }.
For that, I followed the steps in Creating a custom element — Basix 0.10.0.0 documentation.
First, we define the following 6x9 matrix to store the coefficients
wcoeffs = np.zeros((6,9))
wcoeffs[0,0] = 1
wcoeffs[1,1] = 1
wcoeffs[2,3] = 1
wcoeffs[3,4] = 1
wcoeffs[4,6] = 1
wcoeffs[5,7] = 1
The Ciarlet functionals are, in this case, evaluations at the 4 corners and 2 edges of the quadrilateral.
# Nodes:
x = [ [], [], [], [] ]
# Corners
x[0].append(np.array([[0.0, 0.0]]))
x[0].append(np.array([[1.0, 0.0]]))
x[0].append(np.array([[0.0, 1.0]]))
x[0].append(np.array([[1.0, 1.0]]))
# Edges
x[1].append(np.array([[0.5, 0.0]]))
x[1].append(np.array([[0.5, 1.0]]))
x[1].append(np.zeros((0,2)))
# Empty array of points inside the 2d cell
x[2].append(np.zeros((0,2)))
As all the DOFs are point evaluations the matrices are all identity matrices for the entities that have a point:
M = [ [], [], [], [] ]
# 4 corners
for _ in range(4):
  M[0].append(np.array([[[[1.0]]]]))
# 2 edges
M[1].append(np.array([[[[1.0]]]]))
M[1].append(np.zeros((0, 1, 0, 1)))
# Inside cell
M[2].append(np.zeros((0, 1, 0, 1)))
Now we create the element
import basix
from basix import CellType, MapType, SobolevSpace, PolysetType
import basix.ufl
P2xP1 = basix.ufl.custom_element(
  cell_type=CellType.quadrilateral,
  reference_value_shape=[],
  wcoeffs=wcoeffs,
  x=x,
  M=M,
  interpolation_nderivs=0,
  map_type=MapType.identity,
  sobolev_space=SobolevSpace.H1,
  discontinuous=False,
  embedded_subdegree=1,
  embedded_superdegree=2,
  polyset_type=PolysetType.standard,
And compute the matrix for a Poisson problem in a single cell (a 1x1 mesh)
from dolfinx import fem, mesh
from ufl import dx, grad, inner
msh = mesh.create_rectangle(
    comm=MPI.COMM_WORLD,
    points=((0.0, 0.0), (1.0, 1.0)),
    n=(1,1),
    cell_type=mesh.CellType.quadrilateral,
V = fem.functionspace(msh, P2xP1)
u = ufl.TrialFunction(V)
# Matrix
import scipy
A=dolfinx.fem.assemble_matrix(dolfinx.fem.form(a))
As = scipy.sparse.csr_matrix((A.data, A.indices, A.indptr))
def my_print(A, float_formatter = "{:.1f}".format):
  np.set_printoptions(formatter={'float_kind':float_formatter})
  print(A)
A_arr = As.toarray()
print("Matrix shape:", A_arr.shape)
my_print(A_arr)
According to the number of degrees of freedom for this the element, I expected a 6x6 matrix. But, unexpectedly, I obtain a 8x6 matrix, where the two extra rows are composed by zeros. In particular, this the result of running the minimal script defined above:
Matrix shape: (8, 6)
[[0.9 0.1 0.3 0.1 -0.8 -0.5]
 [0.1 0.9 0.1 0.3 -0.8 -0.5]
 [0.3 0.1 0.9 0.1 -0.5 -0.8]
 [0.1 0.3 0.1 0.9 -0.5 -0.8]
 [-0.8 -0.8 -0.5 -0.5 2.3 0.4]
 [-0.5 -0.5 -0.8 -0.8 0.4 2.3]
 [0.0 0.0 0.0 0.0 0.0 0.0]
 [0.0 0.0 0.0 0.0 0.0 0.0]]
Any help would be appreciated!
Thanks!
There’s likely as assumption somewhere in Basix that each edge has the same number of DOFs associated with it. I’ll take a look and see if I can work out where this is (and how much stuff will break if I remove this assumption).
Hello again,
I have been testing a simpler anisotropic custom element, in this case the basis functions are constant (P0) in the x variable and order 1 polynomials (P1) in the y variable. That is, the element is defined by evaluating Lagrange polynomials on the following points:
----o----
----o----
Again, if I use Basix to compute the a FE matrix corresponding in a mesh defined by only one cell (the unit square), I obtain two rows more than expected.
Specifically, I expected a 2x2 matrix (the same than for P1 elements in an 1-dimensional interval in the y-axis, as the element is constant in the x-axis).
But, I obtain a 4x2 matrix, where again the two extra rows are composed by zeros!
Matrix shape: (4, 2)
[[1.0 -1.0]
 [-1.0 1.0]
 [0.0 0.0]
 [0.0 0.0]]
Interestingly, the elements of the matrix appear to be correct for a Laplace 1-d matrix. Maybe if there were any right way for “cutting” these two extra rows, everything would be solved…
Thank you!!
By the way: is there any way in Dolfinx for removing rows in a Matrix?
Maybe that would let me let cutting the two extra zero-rows and then building the linear system corresponding to my problem and then solving it (I am trying to program anisotropic Stokes elements).
Thanks again!
Rafa
Dear Matthew
do you have any update on this?
Thanks!
Pablo
