Custom Assembly of Linear Form
Hi everyone,
I have a program that numerically solves the conservative phase-field equation
\frac{\partial \phi}{\partial t} =\nabla\cdot(M(\phi)\nabla\phi).
Using a simple forward-Euler time discretization, we have
\phi^{n+1} = \phi^n - \Delta t \nabla\cdot(M(\phi^n)\nabla\phi^n).
Since the second term on the right-hand side is only non-zero in a small region of the domain (roughly corresponding to the set of points x \in \Omega for which \phi(x) \in (0.4, 0.6)), I would like to assemble the right-hand side vector conditionally - in other words, I only want to perform integration over quadrature points if \phi \in (0.4,0.6) on the given cell.
Is there a way to do this in legacy FEniCS? Find my program below. Here, the term I’m interested corresponds to lin_form2. Also, I know there are significant problems with the program, the program itself is only a stepping stone - I’m not using it for anything serious.
import fenics as fe
import os
import matplotlib
matplotlib.use("Agg")
import matplotlib.tri as tri
comm = fe.MPI.comm_world
rank = fe.MPI.rank(comm)
plt.close('all')
# Where to save the plots
WORKDIR = os.getcwd()
def plot_solution_1d(phi, mesh, t, step, outdir):
   Plot and save 1D phase-field solution
   # Get mesh coordinates and solution values
   x = mesh.coordinates().flatten()
   phi_vals = phi.vector().get_local()
   # Sort (important for plotting)
   idx = np.argsort(x)
   x = x[idx]
   phi_vals = phi_vals[idx]
   plt.figure(figsize=(6, 4))
   plt.plot(x, phi_vals, lw=2)
   plt.xlabel("x")
   plt.ylabel(r"$\phi$")
   plt.title(f"t = {t:.4f}")
   plt.ylim(-0.5, 1.5)
   plt.grid(True)
   filename = os.path.join(outdir, f"phi_{step:05d}.png")
   plt.savefig(filename, dpi=150, bbox_inches="tight")
   plt.close()
M_tilde = 0.005
outDirName = f"1D"
if rank == 0:
   os.makedirs(outDirName, exist_ok=True)
comm.Barrier()
class PeriodicBoundary(fe.SubDomain):
   # Left boundary is "target"
       return bool(on_boundary and fe.near(x[0], -1.0))
   # Map right boundary (x=1) to left (x=-1)
   def map(self, x, y):
       if fe.near(x[0], 1.0):
           y[0] = x[0] - 1.0
           y[0] = x[0]
pbc = PeriodicBoundary()
T = 100
N_pts = 100
mesh = fe.IntervalMesh(N_pts, -1, 1)
h = mesh.hmin()
eps = 0.7*h
dt = 0.1*h
num_steps = int(T/dt)
V = fe.FunctionSpace(mesh, "CG", 1, constrained_domain=pbc)
# Define trial and test functions, as well as
# finite element functions at previous timesteps
f_trial = fe.TrialFunction(V)
phi_n = fe.Function(V)
mu_nP1 = fe.Function(V)
v = fe.TestFunction(V)
phi_nP1 = fe.Function(V)
# Define Allen-Cahn mobility
def mobility(phi_n):
   grad_phi_n = fe.grad(phi_n)
   abs_grad_phi_n = fe.sqrt(fe.dot(grad_phi_n, grad_phi_n) + 1e-6)
   inv_abs_grad_phi_n = 1.0 / abs_grad_phi_n
   mob = M_tilde*( 1 - 4*phi_n*(1 - phi_n)/eps * inv_abs_grad_phi_n )
   return mob
# Initialize \phi
phi_init_expr = fe.Expression(
   "0.5 * (1.0 + tanh((x[0] - x0)/(sqrt(2)*eps)))",
   degree=4,
   eps=eps,
   x0=0.0
phi_n = fe.project(phi_init_expr, V)
bilin_form_AC = f_trial * v * fe.dx
lin_form1 = phi_n * v * fe.dx
lin_form2 = - dt*fe.dot(fe.grad(v), mobility(phi_n)*fe.grad(phi_n))*fe.dx
phi_mat = fe.assemble(bilin_form_AC)
phi_solver = fe.KrylovSolver("cg", "hypre_amg")
phi_solver.set_operator(phi_mat)
prm = phi_solver.parameters
prm["absolute_tolerance"] = 1e-14
prm["relative_tolerance"] = 1e-8
prm["maximum_iterations"] = 1000
prm["nonzero_initial_guess"] = False
outfile = fe.XDMFFile(comm, f"{outDirName}/solution.xdmf")
outfile.parameters["flush_output"] = True
outfile.parameters["functions_share_mesh"] = True
outfile.parameters["rewrite_function_mesh"] = False
# Timestepping
t = 0.0
for n in range(num_steps):
   if n % 10 == 0:  # plot every 10 steps
       outfile.write(phi_n, t)
       if rank == 0:
           plot_solution_1d(phi_n, mesh, t, n, outDirName)
   rhs_AC = fe.assemble(lin_form1) + fe.assemble(lin_form2)
   phi_solver.solve(phi_nP1.vector(), rhs_AC)
   # Update previous solutions
   phi_n.assign(phi_nP1)
Consider the following mwe (using DOLFINx)
from ufl import dx, And, conditional, gt, lt, SpatialCoordinate
x = SpatialCoordinate(mesh)
lower_bound = gt(x[0], 0.25)
upper_bound = lt(x[0], 0.8)
domain = And(lower_bound, upper_bound)
conditional_expr = conditional(domain, x[0], 0.0)
f = conditional_expr * dx(metadata={"quadrature_degree": 25})
print(dolfinx.fem.assemble_scalar(dolfinx.fem.form(f)))
print((0.8**2 - 0.25**2) / 2.0)
Note that the approach with conditional should work for you in legacy dolfin as well
try:
except ModuleNotFoundError:
    from ufl_legacy import dx, And, conditional, gt, lt, SpatialCoordinate
mesh = UnitSquareMesh(10, 10)
print(assemble(f))
Note that i picked high quadrature degree to try to capture the discontinuity that you are adding.
