Hi, I would like advice from the community regarding non trivial source terms.
I used info from this topic for the integrations.
The problem is the following: consider the 2D problem of the known FEniCSx tutorial:
- {\nabla ^2}u(x,y) = f(x,y) where x \in [0.1] and y \in [0.1] with \Omega = [0,1] \times [0,1], f(x,y)=-6 and Dirichlet BCs: u_{D}(x,y)=1+x^2+2y^2. With the known definitions for the trial and test functions the variational problem is \int_\Omega {{\rm{d}}x} \nabla u \cdot \nabla v = \int_\Omega {{\rm{d}}x} fv and the analytical solution is u(x,y)=1+x^2+2y^2.
Consider now that the problem changes with the addition of various non trivial source terms.
Firstly, say f(x,y)=-6+\theta(0.5-x)\theta(0.5-y). The new variational problem is:
\int_\Omega {{\rm{d}}x} \nabla u \cdot \nabla v = \int_\Omega {{\rm{d}}x} fv + \int_\Omega {{\rm{d}}x} \theta (0.5 - x)\theta (0.5 - y)v
How can I define the proper measure? Since this is a integration of the same spatial dimension as the problem I tried (full MWE in the end)
def facet_eq_2D(x):
tol=1e-6
less1 = x[0] < 0.5 + tol
less2 = x[1] < 0.5 + tol
return np.logical_and(less1, less2)
cells = dolfinx.mesh.locate_entities(domain, domain.topology.dim, facet_eq_2D)
tags = np.full_like(cells, 1)
cell_tags = dolfinx.mesh.meshtags(domain, domain.topology.dim, cells, tags)
dx1 = ufl.Measure('dx', domain, subdomain_data=cell_tags, subdomain_id=1 )
print(dolfinx.fem.assemble_scalar(dolfinx.fem.form(uh * dx1(1))))
L1 = source * v * ufl.dx + v * dx1(1)
problem = dolfinx.fem.petsc.LinearProblem(a, L1, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh1 = problem. Solve()
but it doesn’t work.
Still though the line print(dolfinx.fem.assemble_scalar(dolfinx.fem.form(uh * dx1(1)))) very accurately calculates the integral.
Same for the case f(x,y)=-6+\delta(x-0.5)\theta(0.5-y) for the source the following code fails. This is the case of a line integral so I tried
def facet_eq_1D(x):
tol=1e-6
close = np.isclose(x[0], 0.5)
less = x[1] < 0.5 + tol
return np.logical_and(close, less)
cells = dolfinx.mesh.locate_entities(domain, domain.topology.dim-1, facet_eq_1D)
cell_tags = dolfinx.mesh.meshtags(domain, domain.topology.dim-1, cells, tags)
dx2 = ufl.Measure("dS", subdomain_data=cell_tags, subdomain_id=1 )
print(dolfinx.fem.assemble_scalar(dolfinx.fem.form(uh * dx2(1))))
L2 = source * v * ufl.dx + v * dx2(1)
with no success.
Any help on how to define and solve those variational problem with FEniCSx is greatly appreciated.
MWE
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 10, 10, dolfinx.mesh.CellType.quadrilateral)
V = dolfinx.fem.FunctionSpace(domain, ("CG", 2))
uD = dolfinx.fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
boundary_facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
boundary_dofs = dolfinx.fem.locate_dofs_topological(V, domain.topology.dim-1, boundary_facets)
bc = dolfinx.fem.dirichletbc(uD, boundary_dofs)
source = dolfinx.fem.Constant(domain, ScalarType(-6))
#Solution of initial problem
u = ufl.TrialFunction(V)
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = source * v * ufl.dx
problem = dolfinx.fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
def facet_eq_2D(x):
tol=1e-6
uh1 = problem.solve()
def facet_eq_1D(x):
tol=1e-6
uh2 = problem.solve()
