Line Integral of Vector Field
Hi everyone!
Please consider a calculation of a vector field \mathbf{u}, for example via the solution of the static Stokes equations with zero Dirichlet Boundary Conditions with Taylor-Hood finite elements.
from dolfinx import fem, mesh
import basix, basix.ufl_wrapper
import matplotlib.pylab as plt
import warnings
warnings.filterwarnings("ignore")
from ufl import (VectorElement, FiniteElement,
                 SpatialCoordinate, TrialFunction, TestFunction,
                 as_vector, cos, sin, inner, div, grad, dx, pi)
def u_ex(x):
    sinx = sin(pi * x[0])
    siny = sin(pi * x[1])
    cosx = cos(pi * x[0])
    cosy = cos(pi * x[1])
    c_factor = 2 * pi * sinx * siny
    return c_factor * as_vector((cosy * sinx, - cosx * siny))
def p_ex(x):
    return sin(2 * pi * x[0]) * sin(2 * pi * x[1])
def source(x):
    u, p = u_ex(x), p_ex(x)
    return - div(grad(u)) + grad(p)
def create_bilinear_form(V, Q):
    u, p = TrialFunction(V), TrialFunction(Q)
    v, q = TestFunction(V), TestFunction(Q)
    a_uu = inner(grad(u), grad(v)) * dx
    a_up = inner(p, div(v)) * dx
    a_pu = inner(div(u), q) * dx
    return fem.form([[a_uu, a_up], [a_pu, None]])
def create_linear_form(V, Q):
    domain = V.mesh
    x = SpatialCoordinate(domain)
    f = source(x)
    return fem.form([inner(f, v) * dx,
                     inner(fem.Constant(domain, 0.), q) * dx])
def create_velocity_bc(V):
    domain = V.mesh
    g = fem.Constant(domain, [0., 0.])
    tdim = domain.topology.dim
    domain.topology.create_connectivity(tdim - 1, tdim)
    bdry_facets = mesh.exterior_facet_indices(domain.topology)
    dofs = fem.locate_dofs_topological(V, tdim - 1, bdry_facets)
    return [fem.dirichletbc(g, dofs, V)]
def create_nullspace(rhs_form):
    null_vec = fem.petsc.create_vector_nest(rhs_form)
    null_vecs = null_vec.getNestSubVecs()
    null_vecs[0].set(0.0)
    null_vecs[1].set(1.0)
    null_vec.normalize()
    nsp = PETSc.NullSpace().create(vectors=[null_vec])
    return nsp
def create_preconditioner(Q, a, bcs):
    p, q = TrialFunction(Q), TestFunction(Q)
    a_p11 = fem.form(inner(p, q) * dx)
    a_p = fem.form([[a[0][0], None],
                    [None, a_p11]])
    P = fem.petsc.assemble_matrix_nest(a_p, bcs)
    P.assemble()
    return P
def assemble_system(lhs_form, rhs_form, bcs):
    A = fem.petsc.assemble_matrix_nest(lhs_form, bcs=bcs)
    b = fem.petsc.assemble_vector_nest(rhs_form)
    fem.petsc.apply_lifting_nest(b, lhs_form, bcs=bcs)
    for b_sub in b.getNestSubVecs():
        b_sub.ghostUpdate(addv=PETSc.InsertMode.ADD,
                          mode=PETSc.ScatterMode.REVERSE)
    spaces = fem.extract_function_spaces(rhs_form)
    bcs0 = fem.bcs_by_block(spaces, bcs)
    fem.petsc.set_bc_nest(b, bcs0)
    return A, b
def create_block_solver(A, b, P, comm):
    ksp = PETSc.KSP().create(comm)
    ksp.setOperators(A, P)
    ksp.setType("minres")
    ksp.setTolerances(rtol=1e-9)
    ksp.getPC().setType("fieldsplit")
    ksp.getPC().setFieldSplitType(PETSc.PC.CompositeType.ADDITIVE)
    nested_IS = P.getNestISs()
    ksp.getPC().setFieldSplitIS(("u", nested_IS[0][0]),
                                ("p", nested_IS[0][1]))
    # Set the preconditioners for each block
    ksp_u, ksp_p = ksp.getPC().getFieldSplitSubKSP()
    ksp_u.setType("preonly")
    ksp_u.getPC().setType("gamg")
    ksp_p.setType("preonly")
    ksp_p.getPC().setType("jacobi")
    # Monitor the convergence of the KSP
    ksp.setFromOptions()
    return ksp
def solve_stokes(u_element, p_element, domain):
    V = fem.FunctionSpace(domain, u_element)
    Q = fem.FunctionSpace(domain, p_element)
    lhs_form = create_bilinear_form(V, Q)
    rhs_form = create_linear_form(V, Q)
    bcs = create_velocity_bc(V)
    nsp = create_nullspace(rhs_form)
    A, b = assemble_system(lhs_form, rhs_form, bcs)
    assert nsp.test(A)
    A.setNullSpace(nsp)
    P = create_preconditioner(Q, lhs_form, bcs)
    ksp = create_block_solver(A, b, P, domain.comm)
    u, p = fem.Function(V), fem.Function(Q)
    w = PETSc.Vec().createNest([u.vector, p.vector])
    ksp.solve(b, w)
    assert ksp.getConvergedReason() > 0
    u.x.scatter_forward()
    p.x.scatter_forward()
    return (u, p)
domain = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10, mesh.CellType.triangle)
element_u = VectorElement("CG", "triangle", 3)
element_p = FiniteElement("CG", "triangle", 2)
u, p = solve_stokes(element_u, element_p, domain)
Consider now that I need to know the value of a line integral of the vector field I found:
I=\int_c{d\mathbf{x}\cdot \mathbf{u}}
For example consider the path c to be a straight line from point \mathbf{x_0} to \mathbf{x_1} where those points are points of the mesh that may or may not be in the boundary.
What is the easiest way to do this, that may also apply if I have a custom 3d mesh from PyMesh, for example?
Thanks in advance!!!
If the lines do not align with the mesh, you would have to set up a custom integral, i.e.
Define the quadrature scheme (points and weights). Assuming that the quadrature points have been pushed to the physical space, then evaluate u at these points, multiply by the quadrature weight an sum the contributions.
Thanks for the suggestion. I could parametrise the line integral, define a proper quadrature scheme and evaluate u at the quadrature points as explained, for example, here Implementation — FEniCSx tutorial and procced accordingly
However, considering that we have a line aligned in the mesh, i.e. in a unit square a line from (0.5,0) to (1,0.5) is there a way to define the integral with the help of ufl.dx?
The line integral would then be a ds = ufl.Measure("ds", subdomain_data=facet_tags, subdomain_id=5 ) where facet_tags is a mesh-tag marking the facets who intersect the line (0.5,0), (1, 0.5).
i.e. something along the lines of
def facet_eq(x):
    return np.isclose(x[1], x[0]-0.5)
facets = dolfinx.mesh.locate_entities(mesh, mesh.topology.dim-1, facet_eq)
facet_tags = dolfinx.mesh.meshtags(mesh, mesh.topology.dim-1, facets, np.full_like(facets, 5))
Thanks for the help so far. I would like to try the line integral with the help of ufl.measure. The idea is that I may need to add this integral as a constrain (with a lagrange multiplier) in a FEniCSx calculation in the next part of the model I am trying to make.
So, consider a simple example. Lets say I want to calculate the line integral of the scalar field u(x,y)=1+x^2+2y^2 in a somewhat trivial path from (x=0.5,y=0) to (x=0.5,y=1). The minimal code is as follows
domain = mesh.create_unit_square(MPI.COMM_WORLD, 100, 100, mesh.CellType.triangle)
mesh=domain
V = dolfinx.fem.FunctionSpace(domain, ("Lagrange", 1))
u_test = dolfinx.fem.Function(V)
u_test.interpolate(lambda x: 1 + x[0]**2 + 2*x[1]**2)
# Points of the domain
points = domain.geometry.x
def facet_eq(x):
    return np.isclose(x[0], 0.5)
# Make sure you are in the right line by printing the points
for i in range(len(points)):
 a=facet_eq(points[i])
 if a == True : print(points[i])
# Define the measure
#Calculate the integral
intergal = dolfinx.fem.form(u_test * ufl.ds)
print(fem.assemble_scalar(intergal))
Running the code outputs approximately 9 that is not the actual result, that is approximately 1.92.
Please , if you could provide more feedback I would appreciate it.
You are not using the ds you defined in your integral, so it is currently integrating over all exterior facets.
intergal = dolfinx.fem.form(u_test * ds)
would be correct
Thank you very much!!
Turns out there was one more mistake, the right _integral_types command would be dS with capital S, I shouldn’t have missed that one. So, I post the complete code in case somebody needs a similar line integral calculation. By the way the integral is calculated very accurately.
Thanks again!
mesh=domain
def facet_eq(x):
    return np.isclose(x[0], 0.5)# & np.isclose(x[1], 0.5))
ds = ufl.Measure("dS", subdomain_data=facet_tags, subdomain_id=5 )
Hopefully a final followup question. Seems that the 3d version of the previous code is not as easy as I thought. Let me consider the line integral of the scalar function u=1+x^2+2y^2+3z^2 across a trivial straight line starting from (0.5,0.5,0) to (0.5,0.5,1). I changed the dimensions accordingly and also the _integral_types to dx but if I print the facets seems that no facet is found, therfore obviously the integral is zero, which is not correct. Minimal code follows:
domain = dolfinx.mesh.create_unit_cube(MPI.COMM_WORLD, 10, 10, 10, dolfinx.mesh.CellType.tetrahedron)
u_test.interpolate(lambda x: 1 + x[0]**2 + 2*x[1]**2 + 3*x[2]**2)
def facet_eq(x):
 return np.logical_and(np.isclose(x[0], 0,5), np.isclose(x[1], 0,5))
facets = dolfinx.mesh.locate_entities(domain, domain.topology.dim, facet_eq)
facet_tags = dolfinx.mesh.meshtags(domain, domain.topology.dim, facets, np.full_like(facets, 5))
ds = ufl.Measure("dx", subdomain_data=facet_tags, subdomain_id=5)
print(facets,dolfinx.fem.assemble_scalar(intergal))
A line integral in 3D is not an integral over facets, but edges. This integration measure has not been fully implemented in Dolfinx (one would have to either use @jpdean’s Mixed dimensional branch).
or interpolate from then parent mesh to a sub mesh of the edges in question.
