Custom made non uniform mesh
Hello everyone,
I am using fenics-dolfinx 0.9.0 with Linux (Ubuntu 24.04.2 LTS).
I am trying to create a custom mesh to solve the mixed Poisson problem, following the approach described here: Mixed formulation for the Poisson equation.
I followed the steps outlined in this tutorial: Mesh generation, but when I try to plot_mesh the domain, the process takes too long and never finishes.
Here is my code:
import pyvista
import basix.ufl
nodes = np.array([[1.0, 0.0], [2.0, 0.0], [3.0, 2.0], [1, 3]], dtype=np.float64)
connectivity = np.array([[0, 1, 2], [0, 2, 3]], dtype=np.int64)
c_el = ufl.Mesh(basix.ufl.element("Lagrange", "triangle", 1, shape=(nodes.shape[1],)))
domain = dolfinx.mesh.create_mesh(MPI.COMM_SELF, connectivity, nodes, c_el)
def plot_mesh(mesh: dolfinx.mesh.Mesh, values = None):
    Given a DOLFINx mesh, create a `pyvista.UnstructuredGrid`,
    and plot it and the mesh nodes.
    Args:
        mesh: The mesh we want to visualize
        values: List of values indicating a marker for each cell in the mesh
    Note:
        If `values` are given as input, they are assumed to be a marker
        for each cell in the domain.
    # We create a pyvista plotter instance
    plotter = pyvista.Plotter()
    # Since the meshes might be created with higher order elements,
    # we start by creating a linearized mesh for nicely inspecting the triangulation.
    V_linear = dolfinx.fem.functionspace(mesh, ("Lagrange", 1))
    linear_grid = pyvista.UnstructuredGrid(*dolfinx.plot.vtk_mesh(V_linear))
    # If the mesh is higher order, we plot the nodes on the exterior boundaries,
    # as well as the mesh itself (with filled in cell markers)
    if mesh.geometry.cmap.degree > 1:
        ugrid = pyvista.UnstructuredGrid(*dolfinx.plot.vtk_mesh(mesh))
        if values is not None:
            ugrid.cell_data["Marker"] = values
        plotter.add_mesh(ugrid, style="points", color="b", point_size=10)
        ugrid = ugrid.tessellate()
        plotter.add_mesh(ugrid, show_edges=False)
        plotter.add_mesh(linear_grid,style="wireframe", color="black")
        # If the mesh is linear we add in the cell markers
            linear_grid.cell_data["Marker"] = values
        plotter.add_mesh(linear_grid,show_edges=True)
    # We plot the coordinate axis and align it with the xy-plane
    plotter.show_axes()
    plotter.view_xy()
    if not pyvista.OFF_SCREEN:
        plotter.show()
pyvista.start_xvfb(1.0)
plot_mesh(domain)
Am I missing something? Do I need to make any modifications?
Thanks in advance!
You say you are running DOLFINx on linux.
How did you install DOLFINx, is it with conda, spack, apt or through docker?
Secondly, what happens if you remove the line:
@dokken thank you very much. Removing the line pyvista.start_xvfb(1.0) it worked.
Let me ask one more question. How can i refine my mesh ? i found the function
refined_domain_uniform = dolfinx.mesh.refine(domain)
using that
plot_mesh(domain)
plot_mesh(refined_domain_uniform)
i get the following
  File "/home/vboxuser/Desktop/mixpoisson2.py", line 68, in <module>
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/mesh.py", line 571, in refine
    mesh1, parent_cell, parent_facet = _cpp.refinement.refine(
RuntimeError: Edges must be initialised
Also i install DOLFINx with apt.
As the error message states, you need to initialize the edges of the mesh to be able to compute a refinement.
Edges are those topological entities of dimension 1.
See table 1 in: https://dl.acm.org/doi/pdf/10.1145/3524456
You can initialize these by calling
domain.topology.create_entities(1)
prior to calling refine.
@dokken thank you for your response but i still getting an error
this is the code
import basix
import pyvista
from dolfinx import fem, io, mesh
from ufl import (Measure, SpatialCoordinate, TestFunctions, TrialFunctions,
                 div, exp, inner)
    Args:
    Note:
    V_linear = dolfinx.fem.functionspace(mesh, ("CG", 1))
    plotter.show_axes()
    plotter.view_xy()
        plotter.show()
c_el = ufl.Mesh(basix.ufl.element("CG", "triangle", 1, shape=(nodes.shape[1],)))
plot_mesh(domain)
and this is the error
  File "/home/vboxuser/Desktop/mixpoisson2.py", line 71, in <module>
  File "/home/vboxuser/Desktop/mixpoisson2.py", line 36, in plot_mesh
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/function.py", line 607, in functionspace
    dtype = mesh.geometry.x.dtype
AttributeError: 'tuple' object has no attribute 'geometry'
Thank you again for your help
Well, now you need to check the output type of refine.
Refine returns the mesh, plus two optional arrays (used to map meshtags from one mesh to the other).
Thank you again for your help.
