Mixed Poisson problem
Hello everyone,
I am using FEniCSX (fenics-dolfinx 0.9.0) with Linux (Ubuntu 24.04.2 LTS) which i installed with apt.
I create a custom made mesh using the code i found there Mesh generation
Now i modify the code from Mixed formulation for the Poisson equation.
from dolfinx import fem, io, mesh
from ufl import (Measure, SpatialCoordinate, TestFunctions, TrialFunctions,
div, exp, inner)
import pyvista
import basix.ufl
#domain = mesh.create_unit_square(MPI.COMM_WORLD, 32, 32, mesh.CellType.quadrilateral)
nodes = np.array([[1.0, 0.0], [2.0, 0.0], [3.0, 2.0], [1, 3]], dtype=np.float64)
connectivity = np.array([[0, 1, 2], [0, 2, 3]], dtype=np.int64)
c_el = ufl.Mesh(basix.ufl.element("CG", "triangle", 1, shape=(nodes.shape[1],)))
domain = dolfinx.mesh.create_mesh(MPI.COMM_SELF, connectivity, nodes, c_el)
k = 4
Q_el = element("BDM", domain.basix_cell(), k)
P_el = element("CG", domain.basix_cell(), k - 1)
V_el = mixed_element([Q_el, P_el])
V = fem.functionspace(domain, V_el)
(sigma, u) = TrialFunctions(V)
(tau, v) = TestFunctions(V)
x = SpatialCoordinate(domain)
f = 10.0 * exp(-((x[0] - 0.5) * (x[0] - 0.5) + (x[1] - 0.5) * (x[1] - 0.5)) / 0.02)
dx = Measure("dx", domain)
a = inner(sigma, tau) * dx + inner(u, div(tau)) * dx + inner(div(sigma), v) * dx
L = -inner(f, v) * dx
facets_top = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[1], 1.0))
Q, _ = V.sub(0).collapse()
dofs_top = fem.locate_dofs_topological((V.sub(0), Q), fdim, facets_top)
def f1(x):
values = np.zeros((2, x.shape[1]))
values[1, :] = np.sin(5 * x[0])
return values
f_h1 = fem.Function(Q)
f_h1.interpolate(f1)
bc_top = fem.dirichletbc(f_h1, dofs_top, V.sub(0))
facets_bottom = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[1], 0.0))
dofs_bottom = fem.locate_dofs_topological((V.sub(0), Q), fdim, facets_bottom)
def f2(x):
values[1, :] = -np.sin(5 * x[0])
return values
f_h2 = fem.Function(Q)
f_h2.interpolate(f2)
bc_bottom = fem.dirichletbc(f_h2, dofs_bottom, V.sub(0))
bcs = [bc_top, bc_bottom]
problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu",
"pc_factor_mat_solver_type": "mumps"})
try:
w_h = problem.solve()
except PETSc.Error as e: # type: ignore
if e.ierr == 92:
print("The required PETSc solver/preconditioner is not available. Exiting.")
print(e)
exit(0)
raise e
sigma_h, u_h = w_h.split()
with io.XDMFFile(domain.comm, "out_mixed_poisson/u.xdmf", "w") as file:
file.write_mesh(domain)
file.write_function(u_h)
For k=1 is working but once i increase the value of k i get the following error
  File "/home/vboxuser/Desktop/demo_mixed-poisson.py", line 82, in <module>
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/io/utils.py", line 252, in write_function
    super().write_function(getattr(u, "_cpp_object", u), t, mesh_xpath)
RuntimeError: Degree of output Function must be same as mesh degree. Maybe the Function needs to be interpolated?
Even when i interpolate the solution into a Function space with the code
V_out = fem.functionspace(domain, element("CG", domain.basix_cell(), k))
u_h_interp = fem.Function(V_out)
u_h_interp.interpolate(u_h)
i get the same
  File "/home/vboxuser/Desktop/demo_mixed-poisson.py", line 86, in <module>
    file.write_function(u_h_interp)
How can this be corrected?
Use another writer than xdmf, as suggested in: How to make Von Mises Stress look better - #10 by dokken
Please search for the error message on the forum before posting
https://fenicsproject.discourse.group/search?context=topic&context_id=17351&q=RuntimeError%3A%20Degree%20of%20output%20Function%20must%20be%20same%20as%20mesh%20degree.%20Maybe%20the%20Function%20needs%20to%20be%20interpolated%3F%20order%3Alatest&skip_context=true
as there are many posts on the same topic.
