Cyipopt import error on pyadjoint:latest docker image
libipopt.so.1 cannot be found while importing cyipopt.
Can be tested using poisson-topology.py, which throws an error:
  File "/usr/local/lib/python3.6/dist-packages/pyadjoint/ipopt.py", line 11, in <module>
    import cyipopt  # noqa: F401
ImportError: libipopt.so.1: cannot open shared object file: No such file or directory
  File "/opt/project/box/box.py", line 132, in <module>
    solver = IPOPTSolver(problem, parameters=parameters)
  File "/usr/local/lib/python3.6/dist-packages/pyadjoint/optimization/ipopt_solver.py", line 31, in __init__
    self.__build_ipopt_problem()
  File "/usr/local/lib/python3.6/dist-packages/pyadjoint/optimization/ipopt_solver.py", line 37, in __build_ipopt_problem
    from pyadjoint.ipopt import cyipopt
  File "/usr/local/lib/python3.6/dist-packages/pyadjoint/ipopt.py", line 13, in <module>
    raise ImportError("You need to install cyipopt. It is recommended to install IPOPT with HSL support!")
ImportError: You need to install cyipopt. It is recommended to install IPOPT with HSL support!
Docker command used:
docker run -ti -v $(pwd):/home/fenics/shared quay.io/dolfinadjoint/pyadjoint:latest
try to change “latest” to “master”:
quay.io/dolfinadjoint/pyadjoint:master
it is also reproducible on the “master” image
strangely enough, in the master image, importing ipopt in bash:
$ python3 -c "from pyadjoint import ipopt"
gives another error:
ImportError: /usr/local/lib/libipopt.so.1: undefined symbol: MPI_Comm_rank
  File "<string>", line 1, in <module>
while giving the same error from the original post when run in PyCharm
see on this page if something can help you:
Hi Jafar,
I have the same problem when I install it on Ubuntu or Mac systems. Could you fix it? I’ll appreciate it if you can help me to make Ipopt work.
Thanks,
Milad
As far as I can remember, I ran the commands in the Dockerfile as Rafael_Ferro recommended, and it ended up working.
Although now I use Docker and no longer use a local installation. I recommend doing the same for a quick fix.
Thanks, Jafar for your reply. You mean I follow the following instructions:
run docker run -ti -v $(pwd):/home/fenics/shared Quay
Then in docker file type:USER root
RUN apt-get -qq update &&
apt-get -y install libjsoncpp-dev &&
apt-get -y install python-dev graphviz libgraphviz-dev &&
apt-get clean &&
rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/*
RUN /bin/bash -l -c “pip3 install --no-cache --ignore-installed scipy”
COPY --chown=fenics dolfin-adjoint.conf $FENICS_HOME/dolfin-adjoint.conf
ARG IPOPT_VER=3.12.9
RUN /bin/bash -l -c “source $FENICS_HOME/dolfin-adjoint.conf &&
update_ipopt &&
update_pyipopt”
ARG MOOLA_BRANCH=“master”
RUN /bin/bash -l -c “pip3 install --no-cache git+git://github.com/funsim/moola.git@${MOOLA_BRANCH}”
ARG DOLFIN_ADJOINT_BRANCH=“2019.1.0”
RUN /bin/bash -l -c “pip3 install --no-cache git+https://github.com/dolfin-adjoint/pyadjoint.git@${DOLFIN_ADJOINT_BRANCH}”
USER fenics
COPY --chown=fenics WELCOME $FENICS_HOME/WELCOME
RUN echo “source $FENICS_HOME/dolfin-adjoint.conf” >> $FENICS_HOME/.bash_profile
RUN /bin/bash -l -c “python3 -c “import fenics_adjoint””
RUN /bin/bash -l -c “python3 -c “import dolfin; import pyadjoint.ipopt””
USER root
