Background
I am trying to build a docker image that contains JupyterHub and a FEniCS installation, so that students can work with some FEniCS demos without going through the installation procedure. Within this container, FEniCS (2019.1) is installed via conda.
Behaviour
After installing fenics with conda, I run the following MWE:
u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
This results in the following error message:
dijitso failed to load existing file:
/home/admin/.cache/dijitso/lib/libdijitso-dolfin_expression_c49ebd8fd6c25a3c31b612f2a1752a2c.so
error is:
libmpicxx.so.12: cannot open shared object file: No such file or directory
AttributeError Traceback (most recent call last)
/opt/conda/lib/python3.7/site-packages/dolfin/jit/jit.py in compile_class(cpp_data, mpi_comm)
167 mpi_comm=mpi_comm)
--> 168 submodule = dijitso.extract_factory_function(module, "create_" + module_name)()
169 except Exception:
/opt/conda/lib/python3.7/site-packages/dijitso/jit.py in extract_factory_function(lib, name)
46 """
---> 47 function = getattr(lib, name)
48 function.restype = ctypes.c_void_p
AttributeError: 'NoneType' object has no attribute 'create_dolfin_expression_c49ebd8fd6c25a3c31b612f2a1752a2c'
<ipython-input-1-28e2f3e6f919> in <module>
1 from fenics import *
----> 2 u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
3
4 # Define boundary condition
/opt/conda/lib/python3.7/site-packages/dolfin/function/expression.py in __init__(self, cpp_code, *args, **kwargs)
398 raise KeyError("User parameter key must be a string")
399
--> 400 self._cpp_object = jit.compile_expression(cpp_code, params)
401 self._parameters = ExpressionParameters(self._cpp_object, params)
402
/opt/conda/lib/python3.7/site-packages/dolfin/function/jit.py in compile_expression(statements, properties)
156 'name': 'expression', 'jit_generate': jit_generate}
157
--> 158 expression = compile_class(cpp_data, mpi_comm=mpi_comm)
159 return expression
--> 170 raise RuntimeError("Unable to compile C++ code with dijitso")
171
172 if name == 'expression':
Observations:
libmpicxx.so.12 is present on my system. In fact, looking closer at the dijitso log-file, I can see the command it should execute:
c++ -Wall -shared -fPIC -std=c++11 -O3 -fno-math-errno -fno-trapping-math -ffinite-math-only \
-I/opt/conda/include -I/opt/conda/include/eigen3 -I/home/admin/.cache/dijitso/include dolfin_expression_c49ebd8fd6c25a3c31b612f2a1752a2c.cpp \
-L/opt/conda/lib -L/opt/conda/opt/conda/lib -L/home/admin/.cache/dijitso/lib \
-Wl,-rpath,/home/admin/.cache/dijitso/lib -lmpi -lmpicxx -lpetsc -lslepc -lz -lhdf5 -lboost_timer \
-ldolfin -olibdijitso-dolfin_expression_c49ebd8fd6c25a3c31b612f2a1752a2c.so
which contains -L/opt/conda/lib, and a find command reveals /opt/conda/lib/libmpicxx.so.12
Things I have tried:
- Copy
/opt/conda/lib/libmpicxx.so.12into.cache/lib: dijitso successfully compiles the code and FEniCS successfully runs the complete example script, but this is not a sustainable solution. - Manually run the compilation command the dijitso module displayed in the log-file: the compilation succeeds, but the resulting library file is not picked up by dijitso.
Other information:
- FEniCS version: 2019.1.0
- OS: Debian GNU/Linux 10
Has anyone encountered something like this before? Any help is much appreciated: even if I can circumvent this by using a different setup.
