I’m trying to implement the darcy flow in 3D. The analogue in 2D works fine, however in 3D it yields weird results. I would assume an evenly distributed inflow in contrast to what can be seen in the image. Using different boundary conditions (velocity Dirichlet-BC for the inflow) works in 3D as well, but I need the BCs to be as they are. So my question is, whether it is possible to realize that.
Here is the minimum working example:
class Bottom(SubDomain):
def inside(self,x, on_boundary):
return near(x[2],0) and on_boundary
class Top(SubDomain):
return near(x[2],1) and on_boundary
def wall(x, on_boundary):
return (near(x[0],0) or near(x[0],1) or near(x[1],0) or near(x[1],1)) and on_boundary
### MESH & FUNCTION SPACE ###
mesh = UnitCubeMesh(10,10,10)
Qe = FiniteElement("Lagrange", mesh.ufl_cell(), 1)
Be = FiniteElement("Bubble", mesh.ufl_cell(), 4)
Ve = VectorElement(NodalEnrichedElement(Qe, Be))
element = MixedElement(Ve,Qe)
W = FunctionSpace(mesh, element)
u,p = TrialFunctions(W)
v,q = TestFunctions(W)
### SUB-DOMAINS ###
bottom = Bottom()
top = Top()
sub_domains = MeshFunction('size_t', mesh, 1)
sub_domains.set_all(0)
bottom.mark(sub_domains, 1)
top.mark(sub_domains, 2)
ds = Measure('ds', domain=mesh, subdomain_data=sub_domains)
### BOUNDARY CONDITION ###
bc = DirichletBC(W.sub(0), Constant((0,0,0)), wall)
### VARIATIONAL FORMULATION ###
a = (dot(u,v) - div(v)*p - div(u)*q)*dx
L = -Constant(1)*dot(n,v)*ds(1) + Constant(2)*dot(n,v)*ds(2)
w = Function(W)
solve(a == L, w, bc, solver_parameters={'linear_solver': 'mumps'})
file = File("flow.pvd")
file << w.split()[0]
file = File("pressure.pvd")
file << w.split()[1]
file = File("subdomains.pvd")
file << sub_domains
The resulting flow looks like this:
