Hi there,
I’ve implemented a darcy flow problem, where I apply the pressure BC weakly, and the velocity BC strongly which results in a free slip flow. It works fine for geometries with perpendicular boundaries as shown in fig. 1 but results in unexpected velocity spikes for geometries where the pressure BC surface and it’s adjacent velocity BC surface are not perpendicular to each other as shown in fig. 2.
Is there a way to get rid of those velocity spikes?
Strong velocity BC is marked red. Weak pressure BC is marked green.
Fig 1:
Fig2:
Here is the code:
class Boundary(SubDomain):
def inside(self,x, on_boundary):
return on_boundary
class Inflow(SubDomain):
return (.3 <= x[0] <= .7) and x[1] < .001 and on_boundary
class Top(SubDomain):
return near(x[1],1) and on_boundary
domain_points = [Point(0, 0),
Point(1, 0),
Point(1, 1),
Point(0, 1),]
domain = Polygon(domain_points)
mesh = generate_mesh(domain, 50)
BDM1 = FiniteElement('BDM',triangle, 1)
DG0 = FiniteElement('DG',triangle, 0)
E = MixedElement(BDM1, DG0)
W = FunctionSpace(mesh,E)
u,p = TrialFunctions(W)
v,q = TestFunctions(W)
sub_domains = MeshFunction('size_t', mesh, 1)
sub_domains.set_all(0)
Boundary().mark(sub_domains, 3)
Top().mark(sub_domains, 2)
Inflow().mark(sub_domains, 1)
ds = Measure('ds', domain = mesh, subdomain_data = sub_domains)
a = (dot(u,v) - div(u)*q - div(v)*p)*dx
L = Constant(0)*dot(n,v)*ds(2) - Constant(1)*dot(n,v)*ds(1)
bc = DirichletBC(W.sub(0), Constant((0,0)),sub_domains,3)
w = Function(W)
solve(a == L, w,bc)
u,p = w.split()
plt.figure(dpi=400)
c = plot(u)
plt.colorbar(c)
plt.savefig("u.png")
