Data output with parallel
I want to output the cell connectivity information, nodes coordinates, and calculated strain at each cell for post-processing. It turns out that those information are dependent on the number of cores used for mpirun. I have printed out the number of cells and nodes when reading mesh file in serial. But the number of cells and nodes outputted in those .txt files multiple cores are different from those printed out values from ‘print(mesh_from_file)’. Should I gather all the information to one processor and then save as the .txt files?
from ufl import nabla_div
import sys
#Scaled variables
E = 2.5e11
nv = 0.27
lambda_ = E * nv / ((1 + nv) * (1 - 2 * nv))
mu = 0.5 * E / (1 + nv)
#generate mesh...
mesh = Mesh()
with XDMFFile("tetra_mesh.xdmf") as infile:
     infile.read(mesh)
# Define boundary condition
# Define strain and stress
    #return sym(nabla_grad(u))
def sigma(u):
    return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u)
d = u.geometric_dimension()  # space dimension
f = Constant((0, 0, 0))
L = dot(f, v)*dx
# Compute solution
solve(a == L, u, bcs, solver_parameters = {'linear_solver':'mumps'})
strain = epsilon(u)
V_strain = TensorFunctionSpace(mesh, 'P', 1)
strain = project(strain, V_strain)
cells = mesh.cells()
mc_dof = V.tabulate_dof_coordinates()
mc_ms = mesh.coordinates()
num_cells = mesh.num_cells()
strain_at_centroid = []
# calculate strain_at_centroid ...
np.savetxt('mesh_connectivity_S1V8_test1.txt', cells, fmt='%6i')
np.savetxt('nodes_coordinate_S1V8_test1.txt', mc_ms)
np.savetxt('strain_centroid_S1V8_test1.txt', strain_at_centroid)
XDMFFile('S1_V8_test1_results/displacement_test1.xdmf').write(u)
# Hold plot
I recommend that you reduce your script to minimal working example. Your script contains more information than necessary, making it hard to read relevant part.
Regarding the difference between printing and saving as txt, I think you should not call np.savetxt from all the processors since all the processors will try to write to the same text file. You would want to gather the values to the root processor and save from only the root.
This is basically what you need to do
Thank you so much for the response and suggestion. I have simplified my script. I learnt from your mentioned post that you gathered vector values component-wise. Is it possible to gather it as a vector totally once? Or we have to do that for each component? Thanks.
