MPI demo in dolfinx
Hello there,
I’m new to dolfinx and trying to reproduce the tutorial (DOLFINx in Parallel with MPI — NewFrac FEniCSx Training) in the latest version, but cannot get through the example 04-mpi-dolfinx.py.
I couldn’t find the alternative of “mesh.topology.create_connectivity_all()” so I deleted this line. When I run
mpirun -n 2 python3 04-mpi-dolfinx.py
I have the results
Rank 0: Number of local cells: 2
Rank 0: Number of global cells: 2
Rank 0: Number of local vertices: 4
Rank 0: Cell (dim = 2) to vertex (dim = 0) connectivity
Rank 0: <AdjacencyList> with 2 nodes
  0: [0 1 2 ]
  1: [0 3 2 ]
Rank 1: Number of local cells: 0
Rank 1: Number of global cells: 2
Rank 1: Number of local vertices: 0
Rank 1: Cell (dim = 2) to vertex (dim = 0) connectivity
Rank 1: <AdjacencyList> with 0 nodes
which is different from the tutorial where two nodes assemble the mesh cooperatively.
Here is my code (just minimal changes from the tutorial).
import dolfinx.io
comm = MPI.COMM_WORLD
def mpi_print(s):
    print(f"Rank {comm.rank}: {s}")
mesh = dolfinx.mesh.create_unit_square(comm=comm, nx=1, ny=1, ghost_mode=dolfinx.mesh.GhostMode.none, diagonal=dolfinx.mesh.DiagonalType.right)
#mesh.topology.create_connectivity_all()
mpi_print(f"Number of local cells: {mesh.topology.index_map(2).size_local}")
mpi_print(f"Number of global cells: {mesh.topology.index_map(2).size_global}")
mpi_print(f"Number of local vertices: {mesh.topology.index_map(0).size_local}")
mpi_print("Cell (dim = 2) to vertex (dim = 0) connectivity")
mpi_print(mesh.topology.connectivity(2, 0))
Could you help me out? Thanks!
I cannot reproduce this locally.
I get:
Rank 0: Number of local cells: 1
Rank 0: Number of local vertices: 2
Rank 0: <AdjacencyList> with 1 nodes
  0: [2 0 1 ]
Rank 1: Number of local cells: 1
Rank 1: Number of local vertices: 2
Rank 1: <AdjacencyList> with 1 nodes
  0: [0 1 2 ]
How did you install DOLFINx?
What happens if you use a bigger mesh (say 5x5)?
Hi dokken, thanks for your reply. I installed DOLFINx by conda following GitHub - FEniCS/dolfinx: Next generation FEniCS problem solving environment. If I use a 5x5 mesh, it works fine! Rank 0 and 1 have 25 local cells each.
