I’m trying to solve a thermoelastic problem with constant delta_T but with a different alpha for each element.
When all elements are the same, the code works as I define
f = fem.Constant(domain, default_scalar_type((kappa, kappa, kappa))), where kappa = delta_T * (alpha*(2*mu + 3*lambda_))
As I understand, all I have to do is to define f as a vector function with 3 values per element, but I only managed to create kappa_local with a single value per element. I’m struggling hard with the documentation and all the examples/questions that I find seem to be outdated.
The code:
from dolfinx import mesh, fem, io, plot
# Define the box domain dimensions
Lx, Ly, Lz = 1.0, 1.0, 1.0 # Length in x, y, z directions
nx, ny, nz = 10, 10, 10 # Number of elements in x, y, z directions
# Create the box mesh
domain = mesh.create_box(MPI.COMM_WORLD,
[np.array([0.0, 0.0, 0.0]), np.array([Lx, Ly, Lz])],
[nx, ny, nz],
mesh.CellType.tetrahedron)
# Define the function space
# Define boundary condition
def clamped_boundary(x):
return np.isclose(x[0], 0)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
# Define material properties
E = 10.0 # Young's modulus
nu = 0.3 # Poisson's ratio
alpha = 1e-5 # Coefficient of thermal expansion
delta_T = -100 # Temperature change
lambda_ = (E * nu / ((1 + nu) * (1 - 2 * nu)))
mu = (E / (2 * (1 + nu)))
print(f"lambda = {lambda_}, mu = {mu}, kappa = {kappa}")
return ufl.sym(ufl.grad(u))
def sigma(u):
V0 = fem.functionspace(domain, ("DG", 0))
kappa_local = fem.Function(V0)
# Assign different kappa values to the elements
num_dofs = V.dofmap.index_map.size_local
# Replace the following with your actual method for generating kappa values
kappa_values = (kappa * np.random.rand(num_dofs) - 0.5) * 2
#kappa_values = np.tile(kappa_values[:, np.newaxis], (1, 3))
for i in range(num_dofs):
kappa_local.vector.setValue(i, kappa_values[i])
# Define the variational problem
u = ufl.TrialFunction(V)
#f = fem.Constant(domain, default_scalar_type((kappa, kappa, kappa)))
f = kappa_local
L = ufl.inner(f, v) * ufl.dx + ufl.dot(T, v) * ufl.Measure("ds", domain=domain)
# Solve the problem
uh = problem.solve()
