I have a problem similar to Conditional statement in ufl form, where I am trying to define a conditional ufl function so that it can be used as a fem.Function. In this case, this is my analytic solution that I will compare the numerical solution to. I’m currently getting an error, and I would really appreciate some insight into what is going wrong, how I could make the code better, or if there is a different way of approaching this problem.
My conditional function is defined on the unit interval [0,1] and is
where \alpha_1, \alpha_2, \beta_2, \beta_3 are predetermined constants, and \mathcal{I}_1 is a modified bessel function of the first kind.
Please see below for a minimum working example and the error. Many thanks in advance!
Katie
P.s. Please note that this performed using the complex dolfinx kernel.
from dolfinx import mesh, fem
domain = mesh.create_unit_interval(MPI.COMM_WORLD, 100)
V = fem.FunctionSpace(domain, ("Lagrange", 1))
analytic_A = fem.Function(V)
def analytic_rz(x):
# Simplified parameters for the problem
r1 = 0.1
r2 = 0.2
r3 = 0.3
mu0 = 4 * np.pi * 1e-7
C = 2e8
I = 100
gamma = np.sqrt(1j * C)
alpha2 = I # constants that are already known
beta1 = 0
alpha_ext = 0
alpha1 = (
mu0
* r2
* alpha2
/ (ufl.bessel_I(1, r1) + r1 * gamma * 0.5 * ( ufl.bessel_I(0, r1) + ufl.bessel_I(1, r1)))
beta2 = r1 * (alpha1 * ufl.bessel_I(1, r1) - 0.5 * mu0 * r1 * alpha2)
beta_ext = r2 * (beta2 / r2 - 0.5 * mu0 * r2 * alpha2)
A = ufl.conditional(ufl.And(0 <= x[0], x[0] <= r1), alpha1 * ufl.bessel_I(1, x[0] / gamma ), \
ufl.conditional(ufl.And(r1 <= x[0], x[0] <= r2), 0.5 * mu0 * x[0] * alpha2 + beta2 / x[0], beta_ext / x[0]))
return A
analytic_A.interpolate(analytic_rz)
TypeError Traceback (most recent call last)
File ~/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/dolfinx/fem/function.py:397, in Function.interpolate(self, u, cells, nmm_interpolation_data)
395 try:
396 # u is a Function or Expression (or pointer to one)
--> 397 _interpolate(u, cells)
398 except TypeError:
399 # u is callable
File ~/anaconda3/envs/env3-10-complex/lib/python3.10/functools.py:889, in singledispatch.<locals>.wrapper(*args, **kw)
886 raise TypeError(f'{funcname} requires at least '
887 '1 positional argument')
--> 889 return dispatch(args[0].__class__)(*args, **kw)
File ~/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/dolfinx/fem/function.py:373, in Function.interpolate.<locals>._interpolate(u, cells)
372 """Interpolate a cpp.fem.Function"""
--> 373 self._cpp_object.interpolate(u, cells, nmm_interpolation_data)
TypeError: interpolate(): incompatible function arguments. The following argument types are supported:
1. (self: dolfinx.cpp.fem.Function_complex128, f: numpy.ndarray[numpy.complex128], cells: numpy.ndarray[numpy.int32]) -> None
2. (self: dolfinx.cpp.fem.Function_complex128, u: dolfinx.cpp.fem.Function_complex128, cells: numpy.ndarray[numpy.int32], nmm_interpolation_data: Tuple[List[int], List[int], List[float], List[int]]) -> None
3. (self: dolfinx.cpp.fem.Function_complex128, expr: dolfinx::fem::Expression<std::complex<double>, double>, cells: numpy.ndarray[numpy.int32]) -> None
Invoked with: <dolfinx.cpp.fem.Function_complex128 object at 0x7f872bd772b0>, <function analytic_rz at 0x7f872bb07880>, array([ 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16,
17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33,
34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50,
51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67,
68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84,
85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99],
dtype=int32), ((), (), (), ())
Did you forget to `#include <pybind11/stl.h>`? Or <pybind11/complex.h>,
<pybind11/functional.h>, <pybind11/chrono.h>, etc. Some automatic
conversions are optional and require extra headers to be included
when compiling your pybind11 module.
ValueError Traceback (most recent call last)
Cell In[2], line 46
42 A = ufl.conditional(ufl.And(0 <= x[0], x[0] <= r1), alpha1 * ufl.bessel_I(1, x[0] / gamma ), \
43 ufl.conditional(ufl.And(r1 <= x[0], x[0] <= r2), 0.5 * mu0 * x[0] * alpha2 + beta2 / x[0], beta_ext / x[0]))
44 return A
---> 46 analytic_A.interpolate(analytic_rz)
File ~/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/dolfinx/fem/function.py:402, in Function.interpolate(self, u, cells, nmm_interpolation_data)
400 assert callable(u)
401 x = _cpp.fem.interpolation_coords(self._V.element, self._V.mesh.geometry, cells)
--> 402 self._cpp_object.interpolate(np.asarray(u(x), dtype=self.dtype), cells)
Cell In[2], line 42, in analytic_rz(x)
39 beta2 = r1 * (alpha1 * ufl.bessel_I(1, r1) - 0.5 * mu0 * r1 * alpha2)
41 beta_ext = r2 * (beta2 / r2 - 0.5 * mu0 * r2 * alpha2)
---> 42 A = ufl.conditional(ufl.And(0 <= x[0], x[0] <= r1), alpha1 * ufl.bessel_I(1, x[0] / gamma ), \
44 return A
File ~/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ufl/operators.py:500, in And(left, right)
498 def And(left, right):
499 """A boolean expression (left and right) for use with conditional."""
--> 500 return AndCondition(left, right)
File ~/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ufl/conditional.py:209, in AndCondition.__init__(self, left, right)
207 def __init__(self, left, right):
208 """Initialise."""
--> 209 BinaryCondition.__init__(self, "&&", left, right)
File ~/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ufl/conditional.py:50, in BinaryCondition.__init__(self, name, left, right)
48 def __init__(self, name, left, right):
49 """Initialise."""
---> 50 left = as_ufl(left)
51 right = as_ufl(right)
53 Condition.__init__(self, (left, right))
File ~/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ufl/constantvalue.py:501, in as_ufl(expression)
499 return IntValue(expression)
500 else:
--> 501 raise ValueError(
502 f"Invalid type conversion: {expression} can not be converted to any UFL type.")
ValueError: Invalid type conversion: [ True True True True True True True True True True True True
True True True True True True True True] can not be converted to any UFL type.
