Hello everyone,
Currently I am trying to write function in ufl form, which contains term that is depending on if-elif-else statement.
I could deal with simpler problem with ‘conditional’ method for if-else cases.
However, I couldn’t find some methods when it comes to more-than-two cases, like if-elif-else cases.
The motivation of doing so is because some term differs by distance from the origin,
def distance_function(P):
return sqrt(P[0]**2 + P[1]**2 + P[2]**2)
So, after writing this function for distance, I have to generate the distance-based term like
class map_function():
def __init__(self, impact_radii, sigma, eps_lower, eps_upper):
self.impact_radii = impact_radii
self.sigma = sigma
self.eps_lower = eps_lower
self.eps_upper = eps_upper
def __call__(self, r_hat):
dist = distance_function(r_hat)
if dist < a:
factor =
elif dist < b:
factor =
factor =
return factor * r_hat
As you can see, I am trying to control the variable factor depending on the condition of dist.
While writing this form, I recalled that the variable dist was in the ufl form, which cannot be used with logical operator ‘<’. (If it were if-else cases, I would simply use the conditional method)
How can I solve this issue?
Thanks!
