Defining a piecewise constant parameter over all elements
Hello everyone,
I have a parameter (that I call gamma) in my pde for which I want to take a different constant value in each element of the mesh. To be precise, I want it to have a constant value of 0.8 in each element if z-coordinate of the centroid of the element is greater than 0.15 and a random constant value otherwise. I am not sure exactly how to achieve that. Currently I have this code:
randvalues=np.random.rand(numelem,1)   #numelem is the total number of elements
class Gam(UserExpression):
	def __init__(self, mesh, **kwargs):
		self.mesh = mesh
		super().__init__(**kwargs)
	def eval_cell(self, value, x, ufc_cell):
		cell = Cell(self.mesh, ufc_cell.index)
		if (cell.midpoint().z() > 0.15):
			value[0]=0.8
			value[0] = 0.8+(1-0.8)*randvalues[ufc_cell.index]
elem = FiniteElement('DG', triangle, 0) #Actual finite element for PDE is CG1
gamma = Gam(mesh,element=elem)
Y= FunctionSpace(mesh, "CG", 1)
y  = TestFunction(Y)             # Test function
z  = Function(Y)
R_z = gamma*y*2*z*(psi1)*dx
Does this look correct? I am not sure about whether the expression is being evaluated at the nodes or the quadrature points and if there is any interpolation involved.
Thanks!
During assembly gamma is evaluated at the quadrature points given by the quadrature rule and the polynomial degree of R_z. Based on the rule some of the quadrature points may coincide with nodes. This is easy to test
from random import random
        self.mesh = mesh
        if (cell.midpoint().x() > 0.5):
            value[0]=0.8
            value[0] = random()
        print('Eval at %r of cell %d -> %g' % (x, ufc_cell.index, value[0]))
mesh = UnitIntervalMesh(10)
gamma = Gam(mesh, degree=3)  # Change degree here to change degree of R_z
v  = TestFunction(V)
L = gamma*v*dx   # Polyn degree of L is 1 + degree
assemble(L)
You are on a right track with your solution.
Thank you for your reply, Miroslav. I just want to clarify one thing with you. I ran this same code in 2D by changing to UnitSquareMesh. The print command:
prints x as the nodal coordinates (and not the coordinates of the Gauss quadrature points) corresponding to the degree for degree>0. So does that mean the Expression is first being interpolated into a finite element space?
For my problem, I just want a constant value for the parameter gamma, so I guess I can put degree=0. But I am just curious about how exactly UserExpressions work.
Btw do you know how to get the actual ufc_cell.index in parallel? It shows the index for the cell allocated in each process.
Thanks again!
