I am solving a linear elasticity problem in every loop of an optimization procedure. Even tiny differences may potentially lead to fairly different results after many loops which makes the replication of optimization results difficult.
Running mpirun -np 1 python3 demo_elasticity.py gives identical results between repeated runs as confirmed by the output:
Solution vector norm: 0.05007291838351104
Naively I would have expected the results to be identical also between repeated runs in parallel
However, mpirun -np 3 python3 demo_elasticity.py shows tiny differences (last digit) between repeated runs as confirmed by the output:
Solution vector norm: 0.05007291839575202
Solution vector norm: 0.05007291839575208
What is the reason for this dynamic behaviour in parallel and is there anything to do about it?
