Issue is that you need to use ghost update after doing this command.
n_bc.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
as vector is only the dofs owned by the given processor
Is necessary add the command after interpolation? (e.g., u_bc1.interpolate(u_bc_inlet))
I do not believe so. To be certain you can add it, it should at least not change anything to something wrong.
I add the command after n_bc.vector.set(1.0) and it is working, it was not necessary after u_bc1.interpolate(u_bc_inlet). Thank you again!
