I’m really at a loss here. I have two versions of what is essentially the same Stokes channel flow script, one written in the new API, one in the legacy API. Both run, but the legacy produces correct results whereas the other one does not. I just cannot find the error and I would really appreciate some help.
This is the DOLFINx script:
from dolfinx import io
from dolfinx.fem import (
Constant,
Function,
FunctionSpace,
dirichletbc,
locate_dofs_geometrical,
petsc,
from dolfinx.mesh import create_rectangle
from ufl import (
FiniteElement,
TestFunctions,
TrialFunctions,
VectorElement,
div,
dx,
grad,
inner,
# Numerical parameters
nx, ny = 90, 30
# Geometry definition
L = 3
H = 1
domain = create_rectangle(
MPI.COMM_WORLD,
[np.array([0, 0]), np.array([L, H])],
[nx, ny],
# Physical parameters
mu = Constant(domain, 1.0)
f = Constant(domain, (0.0, 0.0))
# Define the function spaces
V_el = VectorElement("P", domain.ufl_cell(), 2)
Q_el = FiniteElement("DG", domain.ufl_cell(), 0)
W = FunctionSpace(domain, V_el * Q_el)
V, _ = W.sub(0).collapse()
# Define the boundary conditions
def inlet(x):
return np.isclose(x[0], 0)
def outlet(x):
return np.isclose(x[0], L)
def walls(x):
# Top wall
loc_top = np.isclose(x[1], H)
# Bottom wall
loc_bot = np.isclose(x[1], 0)
return np.any([loc_top, loc_bot], axis=0)
def inlet_v(x):
return np.vstack([-4 * x[1] * (x[1] - 1), np.zeros(x.shape[1])])
u_inlet = Function(V)
u_inlet.interpolate(inlet_v)
inlet_dofs = locate_dofs_geometrical(V, inlet)
bc_inlet = dirichletbc(u_inlet, inlet_dofs)
u_noslip = np.array([0.0, 0.0], dtype=PETSc.ScalarType)
wall_dofs = locate_dofs_geometrical(V, walls)
bc_noslip = dirichletbc(u_noslip, wall_dofs, V)
bcs = [bc_inlet, bc_noslip]
# Forming and solving the linear system
u, p = TrialFunctions(W)
v, q = TestFunctions(W)
a = mu * inner(grad(u), grad(v)) * dx - p * div(v) * dx + q * div(u) * dx
L = inner(v, f) * dx
problem = petsc.LinearProblem(a, L, bcs=bcs)
wh = problem.solve()
uh, ph = wh.split()
uh.name = "velocity"
ph.name = "pressure"
# External post-processing
with io.XDMFFile(domain.comm, "output.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
xdmf.write_function(uh)
xdmf.write_function(ph)
This is the legacy script (taken from a course on finite elements).
# Problem parameters
# Fluid parameters
mu = Constant(1) # dynamic viscosity
# External force
f = Constant((0,0))
# Geometry setup and meshing
# Create domain
domain = Rectangle(Point(0, 0), Point(3, 1))
# Specify boundaries
def wall(x, on_boundary):
return on_boundary and (near(x[1], 0) or near(x[1],1))
def inlet(x, on_boundary):
def outlet(x, on_boundary):
return on_boundary and near(x[0], 3)
# Create mesh-triangulation
mesh = generate_mesh(domain, 64)
plot(mesh, title='Mesh')
# Set up discrete setting
# Finite Element degree
deg_velocity = 2
deg_pressure = 0
# Define Elements
V_el = VectorElement("P", mesh.ufl_cell(), deg_velocity)
Q_el = FiniteElement("DG", mesh.ufl_cell(), deg_pressure)
W_el = MixedElement([V_el, Q_el])
# Define function spaces
V = VectorFunctionSpace(mesh, "P", deg_velocity)
Q = FunctionSpace(mesh, "DG", deg_pressure)
W = FunctionSpace(mesh, W_el)
(u,p) = TrialFunctions(W)
(v,q) = TestFunctions(W)
# Define solution (functions)
w_sol = Function(W)
u_sol = Function(V)
p_sol = Function(Q)
# Set up boundary data
# Define boundary values
bv_inlet = Expression(('-4*(x[1]-0)*(x[1]-1)','0'), degree=2)
bv_wall = Constant((0,0))
# Define boundary conditions
bc_inlet = DirichletBC(W.sub(0), bv_inlet, inlet)
bc_wall = DirichletBC(W.sub(0), bv_wall, wall)
bcs = [bc_inlet, bc_wall]
F = ( mu*inner(grad(u), grad(v)) - div(v)*p + q*div(u) - inner(v, f))*dx
a = lhs(F)
L = rhs(F)
# Solve linear system
solve(a==L, w_sol, bcs)
# Split the mixed solution
(u_sol, p_sol) = w_sol.split()
# Plot solution
plot(u_sol, title='Velocity')
plot(p_sol, title='Pressure')
u_sol.rename('velocity', 'u')
p_sol.rename('pressure', 'p')
vtkfile = File('Stokes_velocity.pvd')
vtkfile << u_sol
vtkfile = File('Stokes_pressure.pvd')
vtkfile << p_sol
I can only post one media file, but the legacy version produces the correct results. I’m running both programs on their respective Docker containers.
All help is appreciated!
